King Campaign
Jagdtiger46
Missouri, United States
KitMaker: 291 posts
Armorama: 256 posts
KitMaker: 291 posts
Armorama: 256 posts
Posted: Tuesday, April 02, 2013 - 02:10 AM UTC
Nice looking King, Lucas. I'll look forward to its completion.
panzerfan76
South Carolina, United States
KitMaker: 21 posts
Armorama: 18 posts
KitMaker: 21 posts
Armorama: 18 posts
Posted: Thursday, April 04, 2013 - 12:28 AM UTC
Thanks, guys. I really appreciate it.
Hey Marc, I had a couple of ?s for you. I was checking out the pins (then I priced them and almost had a stroke- $10 for a box of straight pins?! ) Anyway, did you run them in a dremel to file them down? Also, I have never seen the ones that you put on your exhaust housings before. That sent me scouring my references. A provision for sheet steel covers that was never installed, perhaps?
Last couple questions. The scratched texture on your paint is crazy good- how did you achieve the effect- low grit in random directions on the primer coat? Weld seams- looks like your doing same as I am on the heavy plates (perpendicular gouges)- but the join seams are looking good too. Putty with a sharpened implement of some sort? I also spotted the casting line on the mantlet. Was that done in a similar way to the weld seams?
Anyway, thanks again, guys!
bulivyf
Vendor
Praha, Czech Republic
KitMaker: 2,450 posts
Armorama: 2,409 posts
Posted: Friday, April 05, 2013 - 02:51 AM UTC
Hi all,
I started Dragon Kingtiger with Atak Zimmerit.
wing_nut
KitMaker: 1,212 posts
Armorama: 674 posts
Armorama: 674 posts
Posted: Friday, April 05, 2013 - 11:54 AM UTC
Hey Lucas
Seems like a lot for a box of pins, especially f you just need a few. I used them for the Friul tracks and still had 1/2 a box left so it was worth it in my case. The pins on either side of the muffler guards are lifting lugs.
What I did for the pins was to put the pin in... what else... a pin vise . It was easy then to spin the head against a grinding wheel in the Dremel.
I made a few tools in different sizes that I saw in the tutorial below and different putties depending on the situation.
https://armorama.kitmaker.net//features/220&page=2
The rolled steel texture was done by stippling Bondo body putty that was thinned with lacquer thinner to about the consistency of thinned paint. After it hardened sanded very lightly with a sanding block to just smooth the high spots.
Nito74
Lisboa, Portugal
KitMaker: 5,386 posts
Armorama: 4,727 posts
Posted: Friday, April 05, 2013 - 12:36 PM UTC
That's a nice choice Miloslav !
panzerfan76
KitMaker: 21 posts
Armorama: 18 posts
KitMaker: 21 posts
Armorama: 18 posts
Posted: Friday, April 05, 2013 - 01:06 PM UTC
Good stuff Marc, thanks!
I got the Dragon #222 BoB kit because of the subject matter, and the added goodies were a plus (magic tracks, figs, etc). I was thinking about springing for friuls, but they can get a bit steep.
I saw that tutorial a few months back, and have been working w/ a modified hypo needle procured from a drug store (got some weird looks over that one- "honestly sir, I'm not going to use this for drugs...")
I think that I'm going to use vallejo cavalry brown for primer, then hairspray method w/ tamiya dk yellow, deep green, maybe red brown toned down a bit w/ NATO brown. Too far along in my build for troweling on bondo- I might lay the undercoat on a bit thick, then sand w/ a med grit on some of the bigger surfaces to get the same effect going.
Got some off time, hopefully I can get some progress pics up by the end of this weekend!
Posted: Friday, April 05, 2013 - 09:14 PM UTC
Marc, Lucas,
I use a curved chisel bit from Mission Models for my weld seams works great!
Cheers Rob.
Cheers Rob.
Posted: Friday, April 05, 2013 - 10:18 PM UTC
It is good to see you join in Miloslav
wing_nut
Armorama: 674 posts
Armorama: 674 posts
Posted: Monday, April 08, 2013 - 12:29 AM UTC
Good idea Rob. never thought of that. Not sure if you know, but I just found out the Mission Modles is out of biz. So if oyu see extra tips at a show or or LHS probably a good idea to buy 'em. I just got both sizes at out show on Saturday.
Posted: Thursday, April 11, 2013 - 05:43 AM UTC
wrenchy
Saskatchewan, Canada
KitMaker: 140 posts
Armorama: 46 posts
KitMaker: 140 posts
Armorama: 46 posts
Posted: Thursday, April 11, 2013 - 04:41 PM UTC
Looks good Cam, I've got some catching up to do!
Posted: Friday, April 12, 2013 - 03:00 AM UTC
It is great to see some new Tigers taking shape here.
Posted: Friday, April 12, 2013 - 03:38 PM UTC
woltersk
Utah, United States
KitMaker: 1,026 posts
Armorama: 654 posts
Armorama: 654 posts
Posted: Friday, April 12, 2013 - 06:03 PM UTC
Now that I found the time, the slow-setting glue, and the nerve, I finally took the plunge and assembled a run if tracks. What a PITA.
Thanks to everyone who posted indy-track tutorials, gave advice and pointers, and encouraged the hesitant (like me) to get r done.
Nice work being done all around. Lots of Dragon kits in the mix.
Keith
Keith
Posted: Saturday, April 13, 2013 - 01:58 AM UTC
Keith; I think you will agree the pain is worth it judging by the look of the tracks on the vehicle.
Cam; A duel colour instead of tri-colour, I quite like the look almost tiger stripe in appearance.
woltersk
Utah, United States
Armorama: 654 posts
Armorama: 654 posts
Posted: Saturday, April 13, 2013 - 07:56 AM UTC
Whoo-hoo! It does indeed work! One side done and the other in progress...
Keith
Keith
bulivyf
Vendor
Posted: Sunday, April 14, 2013 - 04:58 AM UTC
Posted: Sunday, April 14, 2013 - 06:05 AM UTC
Miloslav what adhesive did you use for the zimmerit as I notice it has been very cleanly applied with only a couple of spots where the resin hasn't stuck down?
bulivyf
Vendor
Posted: Sunday, April 14, 2013 - 06:17 AM UTC
Darren, I used to most parts five-minute epoxy. For front and rear I used superglue.
woltersk
Utah, United States
Armorama: 654 posts
Armorama: 654 posts
Posted: Thursday, April 18, 2013 - 03:11 PM UTC
@Cam--nice airbrushing job!! I'm at that point too.
@Miloslav--good work on that Zimm. Can't wait to see it painted.
I've had a few firsts--first attempt at painting that wavy pattern on the gun barrel. It
needs some touching up. First time I didn't finish airbrushing on a color in one session. My hand was cramping up and I got tired of cleaning out the airbrush nozzle.
Keith
Keith
Posted: Thursday, April 18, 2013 - 03:46 PM UTC
I like the camo pattern Keith
woltersk
Utah, United States
Armorama: 654 posts
Armorama: 654 posts
Posted: Friday, April 19, 2013 - 01:34 AM UTC
Thanks Darren! It was a lot of fun. I probably won't get a chance to finish the green until next Tuesday and won't start the brown until sometime after that. And then there's the modulation of all three colors! Hmmm....looking at the top view pic the gun barrel 'wave' needs to be brought down a bit on the left side. There's always something!
Keith
bulivyf
Vendor
Posted: Saturday, April 20, 2013 - 03:59 AM UTC
woltersk
Utah, United States
Armorama: 654 posts
Armorama: 654 posts
Posted: Sunday, April 21, 2013 - 10:31 AM UTC
@Miloslav--Wow! That is a beautifully rendered camo and wash job! What colors did you use? And you got the decals laid down into the zimm nicely. Can't wait to see more!
Keith
Keith
bulivyf
Vendor
Posted: Sunday, April 21, 2013 - 10:59 AM UTC
Keith
I used AK Interactive Color Set Germany 1944-45
About decals. I add decal to model and used special czech decals water.
