You're gonna want to sand the guide horn sides on the tracks so they'll fit between the road wheels. Mine wouldn't sit all the way and the ones around the idler and sprocket didn't want to cooperate much either.
He was quite right about this- the guide horns on the tracks are too thick- they won't go in between the road wheels very much, they kind of bounce out if you try and force them in. So, like he said, sand the guide horns down a bit on each side and they fit just fine.
Each run of track (one side at a time) was airbrushed in Vallejo Black- it seems that when clean the T-64's tracks appeared black until they got used and the steel started to show through and mud/dirt coated them. So I always start with what they look like when clean, hence using black first.
Once that was done I gave them a fairly heavy drybrushing with Andrea Gun Metal and then a final, more abbreviated, dryrbrushing with Vallejo Natural Steel.
This, the wheels and the hull tub were then given a coat of Matt Varnish to protect the paint. Prior to this the very outside of each roadwheel and the return rollers were painted Dark Rubber.
So then it was on to fitting the tracks. The idler run, top track run and the sprocket run all went on fine. I ran into a slight problem with the bottom run of track. Because I had deviated from the instructions by adding one more link to the idler and sprocket runs I was left with a bottom run roughly half a link too big. This is, unfortunately, the risk you run when you don’t follow the instructions! Its also the reason I prefer metal tracks! Here is where the problem arose:
I’ve had to deal with this problem before and in this case I needed to remove one whole link from the bottom run and since the track is big and sturdy this is very easy. Once that was done I needed to add roughly 1-2mm onto the very end of the idler track run so I cut the very tips off one track pad and glued them to the end of each side- as can be seen in the photos highlighted with red lines.
This gave me the extra length to make the track run fit nicely and it’s a very small alteraration its not all that noticeable. Here's how it ended up (still has to be touched up with paint):
There are pros and cons to both sides of doing plastic indi or link and length tracks- you can follow the instructions and then paint everything once its all in place or deviate and hope it doesn't present any problems. Those are probably some of the reasons metal tracks are so popular !
I just have to snug the upper run down onto the return rollers now and then add the left hand fenders- more on this soon!
Thanks for reading.
-KARL187-
