Bronco Campaign 2020 - Active
TacFireGuru
KitMaker: 3,770 posts
Armorama: 2,263 posts
Posted: Thursday, July 16, 2020 - 09:55 AM UTC
I've finally been able to get some bench time - this time a bit more on the 37mm ATG. Talk about fiddley!! I had to search a few times for teeny tiny pieces that decided to warp to the floor or behind something on my desk.
Pretty much all that is left is assembling the wheel/tires and touch-up paint, assembling the trails, frame, and gun shield, and some detail painting on a couple of things.
Mike
justsendit
KitMaker: 3,033 posts
Armorama: 2,492 posts
Posted: Thursday, July 16, 2020 - 12:02 PM UTC
Holy 37mm ATG flash-back! Progress looks great, Mike. Though it looks harmless enough in that photo, you and I both know better.😅
—mike
petbat
KitMaker: 3,353 posts
Armorama: 3,121 posts
Posted: Thursday, July 16, 2020 - 03:26 PM UTC
Very Nice David. I am actually tempted to get this kit myself.
Mike, great to see some more being done. By your comments, I guess you will be happy to see this one done..
House
KitMaker: 55 posts
Armorama: 53 posts
Posted: Thursday, July 16, 2020 - 04:05 PM UTC
Looking very good David. I can't wait to see those AA ratchet straps installed. I have used them on several kits and I think you will like the end result. Once you get the ammo cans secured consider shock cords to hold the driver's weapon in place. I used solder on mine. Ended up fairly convincing. This has been an enjoyable build to watch.
ayovtshev
#490
Sofiya, Bulgaria
KitMaker: 1,432 posts
Armorama: 1,390 posts
Posted: Friday, July 17, 2020 - 02:56 AM UTC
The QuadBike looks pretty cool, David! Let's see those straps attached!
A picture is worth a thousand words,Mike and those subassemblies show the miriad of tiny details you managed to fix and align!
Well done!
Petro
Connecticut, United States
KitMaker: 984 posts
Armorama: 846 posts
Posted: Saturday, July 18, 2020 - 12:22 PM UTC
I have a question regarding the Bronco workable tracks.
What’s the best glue to use to assemble the pins.? Any other advice?
With a little luck i might finally have a picture update in a week or two.
petbat
Posted: Saturday, July 18, 2020 - 05:53 PM UTC
I presume they are like Model Kasten ones and you push the pin in the hole on each side of the link. Kasten click in place, but I am not sure about Bronco's. If they are held by a pin each side, I would push the pin in, clip off the sprue holding the pin, then use a TOUCH of Tamiya extra thin - wipe the applicator brush on the side of the bottle a couple of times, then just touch where the pin is - do not flood it. You only want the pins to hold after all.
After applying the glue make sure the tracks articulate. Sometimes it pays to wiggle the track links back and forward for a few seconds to make sure the glue hasn't travelled to the link join.
ayovtshev
#490
Sofiya, Bulgaria
Posted: Monday, July 20, 2020 - 05:42 AM UTC
I can't answer your question,Marc...
Although I'm a big fan of Bronco kits, I have to admit I've never dealt with Bronco's workable tracks sofar.
Some progress on my build(Kdo.Ger.40 with towing truck from Bulgarian Royal Army):
Based on a picture and a sketch from Werner Müller's splendid book "Guns,Radars and Telemeters of the Heavy Flak" I've built the operations switchboard(Betriebsschaltkasten):
In operation, the switchboard was placed upon the battery cage:
I also built an open storage case for one of the 12x60 binoculars(I need to build another 3 cases, but they'll be closed, so less hassle):
Paid some attention to the load bed of the MB 4500S truck:
-Increased the height of its forward wall, where two cable reels were mounted,
-built 2 benches for Kdo.Ger.40 crew,
-added rails, on which the telemeter case slides in and out of the load bed,
-made a cutout in the rear wall:
And here is the combo:
petbat
Posted: Monday, July 20, 2020 - 07:57 AM UTC
Just gorgeous Angel. The attention to detail is inspiring.
SpeedyJ
Bangkok, Thailand / ไทย
KitMaker: 1,617 posts
Armorama: 1,150 posts
Posted: Monday, July 20, 2020 - 03:02 PM UTC
Well done Angel it all looks the part.
justsendit
Posted: Tuesday, July 21, 2020 - 09:51 AM UTC
Really superb work, Angel!🍺
—mike
panamadan
Minnesota, United States
KitMaker: 1,513 posts
Armorama: 1,449 posts
Posted: Tuesday, July 21, 2020 - 10:32 AM UTC
I’ve put a dab of glue at the end of the pin and then push it in.
Dan
TacFireGuru
Posted: Tuesday, July 28, 2020 - 02:22 PM UTC
The ATG's carriage is done - wheels installed and dried "true." I just need to paint the wooden rods on each trail and (still) need to attach the shield to the gun (I really do NOT like this part....).
Mike
SpeedyJ
Posted: Tuesday, July 28, 2020 - 11:31 PM UTC
Nice work everybody. I had to wait for After Market, a metal barrel, so I can continue the build of the gun. Bronco piece is just not nice. Still a long way to go, but such a nice piece of metal really motivates me.
Until next time, when there is progress.
justsendit
Posted: Wednesday, July 29, 2020 - 02:57 PM UTC
... need to attach the shield to the gun (I really do NOT like this part....).
I totally agree. That step brings out the AT Gun's true fiddliness!
—mike
TacFireGuru
Posted: Saturday, August 01, 2020 - 11:43 AM UTC
I'm calling this little pop-gun done. Turns out the shield wasn't as worrisome as I thought.
Mike
ayovtshev
#490
Sofiya, Bulgaria
Posted: Sunday, August 02, 2020 - 03:40 AM UTC
Nice tiny gun, Mike! Really well done!
Thanks also for your comments on my project, gentlemen!
It's abnormally hot here in the last 3 weeks, so modelbuilding was reduced to mere couple of hours a week, in the late night hours...
Still I managed to build the Kabelwagen, the Gestell 38 and 3 closed transport cases for the binoculars:
I had to rearrange the load bed of the MB L4500S truck to fit all accessories:
Construction(less some tarps) is finished, next will be priming and painting,
petbat
Posted: Sunday, August 02, 2020 - 08:21 AM UTC
The 'pop gun' looks very nice Mike. Glad the shield was easier than you thought.
Angel, you get more done in a few hours than I do in a few weeks! This one is just getting better and better.
Petro
KitMaker: 984 posts
Armorama: 846 posts
Posted: Sunday, August 02, 2020 - 08:30 AM UTC
I was thinking the same thing
TacFireGuru
Posted: Tuesday, August 04, 2020 - 02:12 PM UTC
Dayum Angel...that is looking SWEET. Really nice.
Mike
TacFireGuru
Posted: Tuesday, August 04, 2020 - 02:15 PM UTC
I neglected to post a final picture of my Bronco 37mm ATG.
Mike
p.s. - Dragon's 1/6 37mm ATG.
justsendit
Posted: Tuesday, August 04, 2020 - 03:05 PM UTC
Double WOW!! 🤩
—mike
ayovtshev
#490
Sofiya, Bulgaria
Posted: Wednesday, August 05, 2020 - 12:46 AM UTC
Impressive line-up, Mike!
phil2015
Illinois, United States
KitMaker: 502 posts
Armorama: 325 posts
Posted: Sunday, August 09, 2020 - 11:10 AM UTC
The KV-85 is done. I plan to stick it on a base, but for now, I'm calling it done.
I'm going to do a post soon on my first 5 completed 1/35 builds. Of my first 5 this was my favorite one to build. It's a great kit. The tracks are awesome. It makes me want to do another KV series Bronco kit.
Petro
KitMaker: 984 posts
Armorama: 846 posts
Posted: Sunday, August 09, 2020 - 11:34 AM UTC
Good work Phil.
Those tracks have the pins for the separate links?
I did my first set for panzer III and thought they were easier to do then they looked.
