Paris, France
KitMaker: 2,315 posts
Armorama: 2,158 posts
Posted: Tuesday, December 23, 2008 - 09:47 AM UTC
Looks Good
It seems that the M2 barrel is wired ???
the pics still sucks my man
APO, United States
KitMaker: 349 posts
Armorama: 202 posts
Posted: Tuesday, December 23, 2008 - 10:14 AM UTC
You will be adding another coat or two of the final color before clear coating right?
The paint looks splotchy to where you can see the under laying colors. A good weathering tip is after you do your clear coat take some tamiya black and thin it down and place it on areas you want to high light then wipe it off with a damp cloth. Clean up is easy because of the clear coat layer it does a good job at high lighting panel recess areas and bolts.
Other then that your stryker is coming along good!
KitMaker: 136 posts
Armorama: 132 posts
Posted: Tuesday, December 23, 2008 - 11:08 AM UTC
hi guys
Seb am doing my best with pictures,M2 barrelswired dont quite understand this one
walt yes it will get another coat light in back roon not that good looked ok there but under my desk lamp abit patchy
thanks for the advise guys
Merry Christmas to you all
darren
Kildare, Ireland
KitMaker: 3,212 posts
Armorama: 2,807 posts
Posted: Thursday, January 01, 2009 - 07:56 AM UTC
Very good work so far Darren.
I hope to start mine in the next few weeks and will be using your build log here for ref.
Thsnks,
Sean
KitMaker: 136 posts
Armorama: 132 posts
Posted: Sunday, January 04, 2009 - 06:54 AM UTC
APO, United States
KitMaker: 349 posts
Armorama: 202 posts
Posted: Sunday, January 04, 2009 - 09:48 AM UTC
Looking good like the weathering just the right amount really for a street used vehicle. Don't forget to paint the smoke popper heads and add some black wash to the exhaust other things to touch up are the bolt heads on the two shackles i use red but you could use blue, green make then high visible so if you drop them in the dirt, sand, snow. As far as gear goes i advise staying with in shades of green with a few black or dark grays your best bet is google search for any american vehicle in iraq so you can see the gear and take your paint guide from there.
KitMaker: 136 posts
Armorama: 132 posts
Posted: Sunday, January 04, 2009 - 02:39 PM UTC
thanks walt
just quickie the pic of the i/r cam shows lens as a gold looking color .Any idea what to do it
darren
APO, United States
KitMaker: 349 posts
Armorama: 202 posts
Posted: Sunday, January 04, 2009 - 02:54 PM UTC
The picture i posted is showing a reflection of the object in front of it which happens to be sand showing that golden look to the lens. A blackish / blue will work fine for the lens you can use tamiya transparent blue first on the lens then a coat of black onto of the blue. Or if you can find some Mylar confetti in a local arts & craft store or local retail chain store in the arts & crafts department they sell some real nice shiny reflective confetti that is great for things like this and it also works great on vision blocks just match the color you need.
KitMaker: 136 posts
Armorama: 132 posts
Posted: Monday, January 05, 2009 - 12:22 AM UTC
Thanks again Walt you have been so helpful thanks
Darren
APO, United States
KitMaker: 349 posts
Armorama: 202 posts
Posted: Tuesday, January 06, 2009 - 04:18 PM UTC
Just doing what i can for ya Darren
Maryland, United States
KitMaker: 1,132 posts
Armorama: 1,123 posts
Posted: Thursday, January 08, 2009 - 04:53 AM UTC
Lot's of work there Darren, looking good! Thanks for sharing your work with this one, can't wait to see it finished.
Cheers -
Tim
Current projects:
AFV 8.8cm Flak 18 (35088) (paint stage)
Academy Warrior MCV (OIF) (final touches...then paint)
Next up:
Revell A-6E Intruder (?)
CMOT
Editor-in-ChiefEngland - South West, United Kingdom
KitMaker: 10,954 posts
Armorama: 8,571 posts
Posted: Thursday, January 08, 2009 - 06:20 AM UTC
Very nice work Darren and with Walt's help this turning into an excellent build.
Correze, France
KitMaker: 5,329 posts
Armorama: 5,204 posts
Posted: Thursday, January 08, 2009 - 09:02 AM UTC
Thanks for your pretty comprehensive build log and congrats for your fine model.
A question for Pete EPI, is the slat armor package standard to all the variants of Stryker ? My guess is not but !? Hence is any AM slat armor set useable on this kind of variant ?
TIA
Olivier
Visit my site Click the banner
"La reine des batailles, j'ai nommé l'infanterie"
Napoléon
KitMaker: 588 posts
Armorama: 490 posts
Posted: Thursday, January 08, 2009 - 10:04 AM UTC
This model is a cracker; I am building it at the moment First time I have built a Trumpeter model. I have got to stage 12, building the grenade launchers. I appreciate all the details for the wiring Darren. I was wondering Walt where does the cabling for the LRAS3 connect to on your photo.
Cookie
APO, United States
KitMaker: 349 posts
Armorama: 202 posts
Posted: Thursday, January 08, 2009 - 12:26 PM UTC
Cookie you can see the circled box this is the starting point for the two cables which go to the two front mount plugs on the LRAS3 had to use darrens pictures since i don't have access to mine. Most pictures of the LRAS3 have the wires routed under it through the yoke then into the box.
KitMaker: 136 posts
Armorama: 132 posts
Posted: Friday, January 09, 2009 - 08:26 AM UTC
Hi all
Thanks for the nice coments,she is still in the process of having the stoage put on at the moment.
Cookie if you go to page 2 and look at the third from last pictufe you can just see the cables go underneath!
Like I have said before Walt you are ture star very helpfulthanks a million
hopefully she will be finished soon them there sticky tie downs look like there a bit a bind(lol) see you soon
Darren
APO, United States
KitMaker: 349 posts
Armorama: 202 posts
Posted: Saturday, January 10, 2009 - 06:21 PM UTC
Darren if this doesn't get to you to late you can by pass those sticky straps and go for PE ones like these EDUTP515 US Tie Downs and Straps or EDUTP513 German Tie Down and Straps they come prepainted and look very nice and there are many strap sets also made just for the stryker. EDU36001 Stryker stowage belts you can find these and a few more at sites like greatmodels, spruebrothers and others.
I don't think i will be around to see this girl finished after this coming thursday i will be on my way back to the east coast and with out net access for a while. But seeing where you are right now with this one i know it will be a great finished model.
KitMaker: 247 posts
Armorama: 127 posts
Posted: Saturday, January 10, 2009 - 09:26 PM UTC
Looking good. I've just started mine. One thing I found was with parts B31 and A33s. I should've dry fit B31 and then A33 as I found one of the A33s was leaning to the left due to B31 not sitting quite central. It didn't site flat so I had to trim the locating tabs. Then fit parts C11 / C12. It's fixed now but if I had changed the sequence I would've picked this up sooner.
You thoughts on this would be appreciated.
Gravity is a myth. The Earth sucks.
KitMaker: 136 posts
Armorama: 132 posts
Posted: Sunday, January 11, 2009 - 12:20 AM UTC
Hi all
just a quickie as Walt is off the dark side LOL.Sorry to see youre off Walt you've been a great help to me on this build.I went with the trump tie downs ,as i said at begining it was a cedit chrunch build.What a night mere they were to white glue was used here and there .but I got there in the end
Hope you like it so far just got to put some weathering to underside them its done.
Shane i had on problems with any of parts expect ones I have stated ealier on in the build. are you sure you got the part B31 (the front armour) the right way up.
some photos so far of stoage
So Its 95% done just needs the weathering to wheels and bottom of her hope you like thanks
Darren
KitMaker: 136 posts
Armorama: 132 posts
Posted: Sunday, January 11, 2009 - 12:39 AM UTC
Me again
Here some more
Forgot to say the main part of the stoage comes from the tamiya modern U.S equipment set (35266) i've had this lying around for ages,this is afr better than the stuff supplied by trumpeter .
The last one may be on pervious ones sorry if it is thank
Darren
APO, United States
KitMaker: 349 posts
Armorama: 202 posts
Posted: Sunday, January 11, 2009 - 08:33 AM UTC
Hey Darren the straps look good but a little hard to tell the color of them from the pictures i forgot you we're doing a budget build up. Don't forget to add tie down straps to the gas and water cans and it looks like you painted all the raised areas on the hatches black if so only one of them is the bump stop the one in the rear center of each hatch. Also it looks like you left off the bolt heads on the gun shield if you don't want to use the pe bolt heads if i am remembering right this kit has a second side panel not used for this vehicle set up...or was that the M1130? you might be able to slice off some plastic bolt heads to add to the gun shield but it a noticeable item missing. And if you want a fast way to do the vision block the confetti works wonders for that myself i use red transparent styrene with a silver back for all my vision blocks. But over all Darren your build is looking great and will make for a real nice display.
I still got a few days before i go cold
KitMaker: 136 posts
Armorama: 132 posts
Posted: Sunday, January 11, 2009 - 10:40 AM UTC
Hi all
Walt the color of straps are abuff color the rear ones are painted and wiil be on soon P/E parts supplied by trump.The rear hatch bolts aren't pianted just looks it in the photo will get the bolt heads done (poss stretched spur) or I've got an old Academy set some where (where attached to spur if i remember) Will try to get vision port done to .Thanks again Walt shame your off ,you will be missed
Darren
APO, United States
KitMaker: 349 posts
Armorama: 202 posts
Posted: Sunday, January 11, 2009 - 01:51 PM UTC
When you get it done try some out door pictures the real light will give it a whole new look.
I hope not to be off to long as i need the net for work just need to get set up again and I'm happy i could be a help to you Darren.
Paris, France
Posted: Sunday, January 11, 2009 - 02:19 PM UTC
Look good despite the blurry pics Darren
Kildare, Ireland
Posted: Wednesday, January 21, 2009 - 08:05 PM UTC
Looks great Darren.
I see you left off the exaust deflector. I'm currectly doing one of these also. I'm going to use the drivers compartment windows things on an AFV kit as there is more detail on the underside of the hatch with the vision blocks...not sure that they'd be visable anyway, but it struck me as a good idea. I made a complete dog's dinner of the PE wheel strut guards so ended up using the plastic ones instead
Sean
