Trumpeter 10cm s.K. 18 cannon
Gorizont
Sachsen, Germany
KitMaker: 1,462 posts
Armorama: 1,289 posts
Posted: Wednesday, December 03, 2008 - 09:25 AM UTC
Now I have received my kit (from ebay).
I planned to build a diorama which shows a snowy scene, comparable to the very impressive 1/72 ACE-kit boxart of this gun.
(For me) ... a lonely piece, without personnel and ammunition.
greetings...
Soeren
ACE-models very impressive boxart of their 1/72 scale kit.
Gorizont
Sachsen, Germany
Posted: Thursday, December 04, 2008 - 09:49 AM UTC
Some in-progress pictures will follow as soon as possible. Also this is my first dio. ;-)
greetings
Soeren
CMOT
Staff MemberEditor-in-Chief
KitMaker: 10,954 posts
Armorama: 8,571 posts
Posted: Thursday, December 04, 2008 - 10:25 AM UTC
I look forward to what you come up with.
Gorizont
Sachsen, Germany
Posted: Thursday, December 11, 2008 - 09:27 AM UTC
Now Iīve begun to build the gun.
I started with "glueing" (?) the parts of the wheels. I took one wheel for the limber and one main-wheel. The other two will follow later.
I read in another Build-blog of Robert Blokker, that he at first glued the wheel-parts together and then attached the rubber-parts. I also made it like this. I didnīt glued the rubber-rims.
The other part which I built, was one of the spades. Also I changed the working-surface, from a darker paper to a lighter one. The darker is better for finding small parts, but I get very dark fingers... and parts too. ;-) But after painting, this should not be visible.
I will upload the photos later.
Thats all for now.
Soeren
CMOT
Posted: Thursday, December 11, 2008 - 11:07 AM UTC
Soeren some pictures would help the people here form an opinion on your work, you will not get a lot of feedback on your efforts from words alone. If you need help with any aspect of placing pictures in your post please shout.
SGTJKJ
#041
Kobenhavn, Denmark
KitMaker: 10,069 posts
Armorama: 4,677 posts
Posted: Thursday, December 11, 2008 - 08:22 PM UTC
Soeren, sounds interesting.
I am looking forward to see pictures of your build.
Gorizont
Sachsen, Germany
Posted: Thursday, December 11, 2008 - 08:36 PM UTC
Hi Darren, youīre right. Photos are very useful to show progress... and errors too. ;-)
I built the parts until late evening and I didnīt had an idea, how to include the pics into the forum. (it was too late) ;-)
Now I have added 4 pics. Two for the 2 different wheels, and 2 for the shovel. They also can be found in my gallery.
I cleaned the shovel after some time from glue-rests.
Gorizont
Sachsen, Germany
Posted: Friday, December 12, 2008 - 08:48 AM UTC
One more update.
Today I built the other limber-wheel and spade/shovel.
I made an "error" with the first spade, which has some inaccuracies. But perhaps I can fill it later with "dirt". Also the new one looks much cleaner. ;-)
Soeren
Gorizont
Sachsen, Germany
Posted: Sunday, December 14, 2008 - 03:59 AM UTC
two lattices (for the shovels), which are attached to the limber when travelling; 2 parts for the limber itself and the incompleted breech
all 4 wheels
dryfitting the (incomplete) limber-parts
Soeren
Gorizont
Sachsen, Germany
Posted: Monday, December 15, 2008 - 09:16 AM UTC
the barrel with its large grooves
the breechblock itself needs some correction, additions were made and more parts are complete...
the breechblock after "correction"; the 2 half-parts look better after rework
the nearly completed limber
Gorizont
Sachsen, Germany
Posted: Wednesday, December 17, 2008 - 08:58 AM UTC
the breech after one more sanding-session
test-fitting the gun-barrel
the limber (wheels are not glued)
both hole-plates ready for mating with the limber
at first, I planned to build the gun in firing-position, but the kit is only for the towed version.
so I made some modifications on the limber and the "hole-plates", which get attached on the spades.
this was my first try, to make changes on a model kit ever! ;-)
but the problem is, how to get this parts later together.
one reworked part and the material, which I used for
the other reworked part
filled with plastic from parts of the sprues and cut later
building the towing device for the limber - part 1
building the towing device for the limber - part 2
building the towing device for the limber - part 3
test-build of the limber (wheels are not glued)
CMOT
Posted: Wednesday, December 17, 2008 - 07:41 PM UTC
Looks like you are getting there bud.
Gorizont
Sachsen, Germany
Posted: Saturday, December 20, 2008 - 07:44 AM UTC
a new part...
some very small parts are to combine...
the parts are to wide; I shortened both sides
(difference between shortened and original can be seen) that should help a bit
Gorizont
Sachsen, Germany
Posted: Sunday, December 21, 2008 - 09:00 AM UTC
Unfortunely I made an mistake with the incompleted "wheel part" - I filed them...
Now I will see, how to fix the problem and I have to use superglue for adding the main-wheels.
Gorizont
Sachsen, Germany
Posted: Monday, December 22, 2008 - 10:39 AM UTC
some smaller parts (hydraulic-fluid storage?)
a handbrake for the gun
added to the "chassis"
holder for the gun cradle (with lower parts for the height-mechanism)
upper parts for the height-mechanism-cylinders
brass parts are not glued yet
Gorizont
Sachsen, Germany
Posted: Wednesday, December 24, 2008 - 04:01 AM UTC
the next step
some parts were glued...
... and added later to the gun
one "missing" part was added (center, between the lower parts of the "hydraulic-tubes")
the new part looks better after refining, but not perfect; also the brass-tube needs some cleaning
some glue was removed...
Gorizont
Sachsen, Germany
Posted: Monday, December 29, 2008 - 11:11 AM UTC
In the last days Iīve built more parts.
the optical system...
... and attached to the "gun"
some of the many parts to add to the trail-arms...
first parts are completed
one side...
the other side
both trail-arms...
and finally... all completed parts so far...
Gorizont
Sachsen, Germany
Posted: Sunday, January 04, 2009 - 04:51 AM UTC
A small update today.
I glued the wheels to its axles and after a dryingphase of more than 12 hours I made some photos of the gun.
The trailarms are not glued onto the carriage, also the gun-cradle with the barrel part is not glued yet.
testbuild - firing mode
testbuild - travelling mode
note: the holder-part which connects the trailarms to the limber, doesnt fit. but I will build my model in firing mode.
Gorizont
Sachsen, Germany
Posted: Wednesday, January 07, 2009 - 07:38 AM UTC
next update:
holders (blue-marked) and attachment-points (red) for the gun-cradle; also when the barrel is elevated a bit, they would not fit
result: instable barrel while in travelling-position
above the breech-block was a small rod, which I removed for a "cleaner" fit of the barrel to the gun-cradle
big and small (Ace-models s.K.18 - tested for my first try for the diorama one year ago)
idea for the dio - overview, using an DIN-A4-sized picture-frame
(trail-spades are not glued, also one of them is not completed)
idea for the dio - looks like the Ace-models-boxart ;-)
Gorizont
Sachsen, Germany
Posted: Monday, January 12, 2009 - 08:43 AM UTC
the gun is completed now, but one of the wheels broke away and was glued again.
also I did not attach the "transmission-part" for elevating the barrel. my plan, removing the rubber-rims while painting, is not possible; but for the limber I will try this.
for the diorama, I think about some "terraforming". I dont have the idea, which materials I should use. real earth-dirt would be the best, but the problem could be the small animals inside. ;-)
CMOT
Posted: Monday, January 12, 2009 - 10:14 AM UTC
Soeren as you have done most of the needed work already why not send in a build feature to us here at Armorama when you get finished, after all we don't get that many field gun builds. great work so far.
wbill76
KitMaker: 5,425 posts
Armorama: 4,659 posts
Posted: Monday, January 12, 2009 - 11:11 AM UTC
Been following along with this one for a while Soeren, nice to see it get this far along...looking forward to see it placed in the dio.
Gorizont
Sachsen, Germany
Posted: Sunday, January 18, 2009 - 09:28 PM UTC
After the update on the Nasa-forum (russian-space), the next update here. ;-)
I reworked the trail-spades by removing the lower parts.
As a result, itīs easier to show, that they are "digged" deeper into the ground.
I had to be careful, the spades can break! I broke away small parts from the first one.
With the other, I tried an other technique.
I made 2 cuts at the two vertical holders (the things with the holes), and 2 cuts on the sides of the spades.
After that, itīs easy to bend (and break) the un-wanted part. One "session" with the sanding-tool/ filer later, they have a cleaner look.
Also I added the connection-rod for elevating the barrel, but I cut it into two pieces.
(can be seen on the lower picture, next to the wheel on the left side)
Darren, itīs a fine idea, with the kit-build-feature! I will try this later. ;-)
For the dio, my idea was using fine sand (mixed with wood-glue) as a base and the (white/grey) content from cat-toilets, for small stones. ;-)
Later, all gets a dark-brown color and a covering with snow.
Soeren
Gorizont
Sachsen, Germany
Posted: Saturday, January 24, 2009 - 09:16 AM UTC
Good evening to all.
Here is the next update.
Some time ago, I bought a grass-mat, which I tested. ;-)
I used my shaver and an older blade to make some tests with the mat. The result should be a ground, partly free of grass and get covered with earth/dirt later.
Iīm not sure with the result or the base itself. Because this is my first diorama and try for it, I had some problems to find "good" material and a ground, which I could use for.
I would use the partly shaved grass-mat, because itīs very strong.
Also I found some fine stuff from the model-tramway-part, which I could use. A mixed darker earth would be the best at first.
The damaged blades of the shaver. Do not strike, please! ;-)
I also made an "artwork" of the unfinished set, using some photos and the gun.
I will delete some pictures in my gallery, because I donīt have enough store-space.
Soeren
Gorizont
Sachsen, Germany
Posted: Sunday, February 01, 2009 - 09:01 AM UTC
The next update, after deleting some pictures from my gallery.
I bought 2 small bags of gravel (for model-trains) and glued it using wood glue.
the materials...
Later I will buy fine sand, for smoothing the "rough" surface and I try to remove some parts.
Test of the gun on its place.
