Mick,
A few suggestions politely offered, feel free to ignore them and accuse me of being a rivet counter.
The right hand sponson radio shelf is too far forward. It should be back so that it is almost touching the jerry cans on top of the battery box.
Also most carriers would normally have no more than 3 radios fitted. Command net, Admin net and the Infantry net = 3 radios. Although from the looks of some of your other posts, you seem to be one for the research, so please feel free to rebut my assertion with a war memorial photograph or something.
Love the sandbag improvised belly armour. Expect to see about 20 diggers sitting on top of the finished product with SLRs, M60s and wombat guns at the ready.
W
Damn, you know when to chime in!
Just weathered the interior:
And sealed it up!
Anyway, not a big deal ... your advice does make sense considering that the starboard side aerials are set back - the liquid glue holding the hull top on was still soft (if it had hardened it would be staying where it was).
It was easy enough to shift the radios back and patch the spot where they had been, which wasn't that visible anyway.
That little bump in the road out of the way ...
The hull top's now back on, and I managed to seal all the gaps, although some glue cleanup will be needed, but that's no big deal on these "slab" vehicles.
I respect your call on the three radios, but the AWM pics of the vehicle I am modelling clearly shows four aerials although one could be a spare. It is also possible that an extra Brit radio set was installed to talk to the Centurion tanks ... once again, no big deal as there's little chance of finding deatiled shots of the interior, and what I have done is just to convincingly clutter what can be seen through the rear top hatch.
The driver is a resin figure from Firestorm.
I've started on the outside bits. A glaring innaccuracy with the Tamiya kit is the trim vane is too short, but that's easy enough fixed..
Wayne, I was looking at doing a 3 Cav "Niner" vehicle in Vietnam 1966-68 ... do you have any pointers on what the ammo stowage on the top deck would be? The Aussie vehicles were new then, and the impromptu mods such as the sandbag floor started as experience was gained. Obviously, the mod program became more formalised later on, but the early vehicles were essentially standard Yank issue buckets.
Thanks for your advice ... I was just thinking it was hard to see those radios placed forward like I had them!
