Hobby boss AAVP7a1 WIP
skyhawk
KitMaker: 1,095 posts
Armorama: 743 posts
Posted: Tuesday, February 24, 2009 - 02:26 AM UTC
Oh, something else....the inside of the top hatches should also be the same darker green you have on the inside of the rear ramp (same dark green as on the exterior), not the "seafoam green".
Posted: Tuesday, February 24, 2009 - 05:45 AM UTC
Thanks for that Andy, the paint job would have been a bit tighter but I didn't realise how much my airbrush needed a good deep clean until after I had started, by then it was a little to late. I assumed the hatches would have been painted a dark colour but didn't have the references at the time to do it and painting the whole interior the same was just a little easier in the time I had.
I should post a couple more images in the next few days once I have finished the storage, it has taken me nearly two weeks to paint it all
cheers
Keith
cheers
Keith
newfish
KitMaker: 2,329 posts
Armorama: 2,110 posts
Posted: Tuesday, February 24, 2009 - 05:48 AM UTC
cheers
Keith
What stowage have you used?.
And where you on sunday you wern't at crew well i didnt see you
jon_a_its
KitMaker: 1,336 posts
Armorama: 1,137 posts
Posted: Tuesday, February 24, 2009 - 05:49 AM UTC
Nice work, mate
What were the tracks like?
Posted: Tuesday, February 24, 2009 - 06:23 AM UTC
H i all,
Great job so far Keith ! i've been following this blog with great interest. I am currently working on the Dragon 1/72 AAV7 with EEAK. There have been questions about the AAVs up north having the EEAK . I don't know for sure if this is 100% correct, but in Concord publications "Marines on the Ground", page 38 has a picture of two AAVs, one with and one without the EEAK. The caption says it's at the Olympic Stadium in the capital. I also did a search of the AAvs in Iraq on the web and have seen a few other pics of them up north with the EEAK. You probably already know this.....anyway, I have one question for you. My Dragon model has what I believe is a smoke generator right behind the TC's hatch. Does Hobby Boss give you the option in the kit? Thanks -and again great job !! -Rich
Posted: Tuesday, February 24, 2009 - 07:32 AM UTC
H i all,
Hi Rich
I think the item you are talking about is the engine exhaust of the RAMS/RS upgraded AAVP7, you can tell if it is has the upgrade as the tracks have a set of return rollers as the tracks are based on the M2a1 Bradley running gear (if not the same as), those with out the RAMS/RS upgrades don't have the return rollers and the exhaust is a small vertical stack (as in this Hobby boss Kit). This AAVP site has some semi decent line drawings of the various versions.
This release of the Hobby Boss kit has the parts for the RAMS/RS exhaust (apart from the P/e screen over it) but its not in the instructions, although Hobby Boss have a RAMS/RS version listed for release at soem point this year.
Keith
Posted: Tuesday, February 24, 2009 - 07:35 AM UTC
Nice work, mate
The tracks are single links, and are designed to be clipped together, but i found the plastic a little to soft so they kept parting as you built the lengths. in the end I built them up glued them around the wheels on the hull then once dry removed the whole wheel/track assembly for painting.
cheers
Keith
Posted: Tuesday, February 24, 2009 - 07:38 AM UTC
And where you on sunday you wern't at crew well i didnt see you![]()
I have used the Real Model stowage set plus some other parts. I now just have to start the figures all 10 of them for the diorama, luckily the base is done ready for paint.
Couldn't make Crewe in the end so will be at Cosford and Hinckly
cheers
Keith
skyhawk
Armorama: 743 posts
Posted: Tuesday, February 24, 2009 - 08:39 AM UTC
... My Dragon model has what I believe is a smoke generator right behind the TC's hatch...
Rich, Keith is correct about the RAM/RS exhaust.
Now if your currious, every AAV has a smoke generation unit. It is integral with the exaust and is enternal. There is a manual switch accessable from the troop compartment (small hand size door on the left side of larger access panel that faces the troop compartment inside). This turns the smoke generator on/off. The actual smoke is then generated by a toggle switch in the turret (if I remember right). Smoke comes out the exhaust.
It works by spraying oil onto some manifold within the exaust system...works pretty dang good too.
Andy
newfish
Posted: Tuesday, February 24, 2009 - 08:46 AM UTC
Nice
. Can we have a sneak peak of that base?
Cool I will be at both of those
Posted: Tuesday, February 24, 2009 - 09:28 AM UTC
hi Keith,
Thanks for your reply-and keep up the good work ! I look forward to seeing the dio when you're done. BTW, what figures will you use ?
Posted: Saturday, February 28, 2009 - 10:13 PM UTC
ok
I have finally managed to finish adding the storage from real model, and have the weathering to do. I also added some straps along the length of the model so the storage actually looks like it is hanging of something.
Now I can start on the figures and finish the base
cheers
Keith
cheers
Keith
newfish
Posted: Saturday, February 28, 2009 - 10:24 PM UTC
Kieth that looks superb with all the stowage on!.
The camo you've painted on them is superb!
jimz66
KitMaker: 1,165 posts
Armorama: 1,105 posts
Posted: Monday, March 09, 2009 - 02:09 AM UTC
Great job on this one Keith. What do the Marines actually call this thing? There has to be a nickname for it no?
Frenchy
KitMaker: 12,719 posts
Armorama: 12,507 posts
Posted: Monday, March 09, 2009 - 04:14 AM UTC
One is "Tuna boat", but there are probably others
Frenchy
stufer
KitMaker: 416 posts
Armorama: 342 posts
Posted: Wednesday, April 29, 2009 - 06:03 AM UTC
a friendly bump for this excellent model.....any updates MrForsyth?
good work fella!
good work fella!
Posted: Wednesday, April 29, 2009 - 07:00 AM UTC
well the diorama is finished and will be published in an up and coming issue of SMMI, and once that is done I will add a photo feature here for all to see, but as a taster
cheers
Keith
cheers
Keith
KitMaker: 17,694 posts
Armorama: 13,742 posts
Posted: Wednesday, April 29, 2009 - 07:08 AM UTC
Looks awesome. Can't wait to see the feature. The whole dio looks great.
stufer
KitMaker: 416 posts
Armorama: 342 posts
Posted: Wednesday, April 29, 2009 - 07:49 AM UTC
wow!!the weathering to tie it all in is fantastic!
great inspiration
time to hang around WHSmiths
great inspiration
GSPatton
KitMaker: 1,411 posts
Armorama: 609 posts
Posted: Wednesday, April 29, 2009 - 08:43 AM UTC
Sweet - Very nicely done.
Hisham
KitMaker: 6,856 posts
Armorama: 6,363 posts
Posted: Wednesday, April 29, 2009 - 09:36 AM UTC
WOW! What a great looking diorama.
Hisham
Hisham
bulivyf
Vendor
KitMaker: 2,450 posts
Armorama: 2,409 posts
Posted: Wednesday, April 29, 2009 - 09:50 AM UTC
Excellent job!!!!
Miloslav
Miloslav
martyncrowther
KitMaker: 1,548 posts
Armorama: 1,407 posts
Posted: Wednesday, April 29, 2009 - 10:13 AM UTC
Hi Keith great stuff mate. Good to see this one finished. I was looking forward to seeing this.
skyhawk
Armorama: 743 posts
Posted: Wednesday, April 29, 2009 - 10:31 AM UTC
that rocks Keith! Great work! Im looking forward to seeing the feature as well!
Andy
Andy
DeskJockey
KitMaker: 1,558 posts
Armorama: 1,159 posts
Posted: Wednesday, April 29, 2009 - 01:51 PM UTC
Very nice dio, Keith! Can't wait to see the whole photo feature!
