This is the initial look that I was going for but while experimenting I found that this was too extreme and fragile, way too flakie.
![](../../../i46.photobucket.com/albums/f137/Gothicriver/post5.jpg)
Here is a strip of styrene with different methods used. The base paint is a mix of Tamiya dark brown and black, Sort of a dark umber or vandyke brown color I use under rust. Gloss and flat represent Testors acrylic clear coats and "paint" is the color to be applied over the crackle, here Tamiya flat white.
![](../../../i46.photobucket.com/albums/f137/Gothicriver/Picture013-3.jpg)
![](../../../i46.photobucket.com/albums/f137/Gothicriver/66.jpg)
![](../../../i46.photobucket.com/albums/f137/Gothicriver/Picture016-3.jpg)
![](../../../i46.photobucket.com/albums/f137/Gothicriver/Picture017-3.jpg)
![](../../../i46.photobucket.com/albums/f137/Gothicriver/Picture018-2.jpg)
Just playing around to find what works best.
![](../../../i46.photobucket.com/albums/f137/Gothicriver/Picture020-1.jpg)
To simulate the thick rust encrusted metal I switched back and forth with the
paint and crackle twice then gave everthing a wash of Vandyke brown and black oils. When this was almost dry I applied lots of ochra umbra mixed with my rust powder.The result was a nice thick rust.
![](../../../i46.photobucket.com/albums/f137/Gothicriver/Picture014-4.jpg)
![](../../../i46.photobucket.com/albums/f137/Gothicriver/Picture015-2.jpg)
I went with the last method in the test strip and I am sumwhat happy with the result. I added some rust "weathering" but still have to do some more after the model is set in groundwork, then add some earth dust to tone everything down.
![](../../../i46.photobucket.com/albums/f137/Gothicriver/Picture033-1.jpg)
![](../../../i46.photobucket.com/albums/f137/Gothicriver/Picture034-1.jpg)
![](../../../i46.photobucket.com/albums/f137/Gothicriver/Picture035-1.jpg)
![](../../../i46.photobucket.com/albums/f137/Gothicriver/Picture036-3.jpg)
![](../../../i46.photobucket.com/albums/f137/Gothicriver/Picture037-3.jpg)
![](../../../i46.photobucket.com/albums/f137/Gothicriver/Picture038-3.jpg)
![](../../../i46.photobucket.com/albums/f137/Gothicriver/Picture039-3.jpg)
![](../../../i46.photobucket.com/albums/f137/Gothicriver/Picture041-1.jpg)
![](../../../i46.photobucket.com/albums/f137/Gothicriver/Picture042-3.jpg)
![](../../../i46.photobucket.com/albums/f137/Gothicriver/Picture046-2.jpg)
![](../../../i46.photobucket.com/albums/f137/Gothicriver/Picture047-1.jpg)
Sorry for the long post but I have to get as much in as possible. I have to use my wife's office PC to go on line, so when she's taking a break, then I have take advantage of the time I have on it.
And yes I do have a lot of time to build at the moment, I was laid of work in November,Commission models are done, so after the house work and dogs are taken care of it's time to build. I have one more month before I go back to work so I will try to get as much done as possible.
Any comments or suggestions you have are most welcome.
Rob
