Are you considering hand painting the entire tank?
Jan, I will probably do a lot more painting by brush than with an airbrush. My airbrush equipment is quite basic or crude and my skills in it's use extremely limited..
dutchboyinohio, I wish I could have found a Comet. It looks more appropriate to my skill levels.
I spent the better part of three hours just trying to get one track on (and breaking suspension pieces).
In the last few days I stumbled along and made more progress. The biggest pain was filling in more areas where gaps had existed because of poor fit. I tried Testors putty but it was a pain because it shrinks and then I tried Squadron putty but it spreads quite poorly.
I think that this particular kit was cursed as while trying to mix the Squadron putty in it's tube by kneading it the back of the tube burst and the contents oozed all over my work area.
The good thing is that the turret is finally built and all assembly should be done today.
In the pictures below you can see the one remaining area with the white putty that needs a bit of cleaning up. I believe it's a searchlight box and it had quite a nasty gap to be filled. I noticed in pictures that there is a door that covers a sight on the commanders cupola so I used some scrap plastic to add some missing detail. The ribs or whatever they are appera a bit on the thick side in the pictures but I'll try to sand them down to a more appropriate size.
To who ever is also going to build this beast, you are in for "loads" of FUN!
AJ
