So far, I have started on the Suburban. The scenario is an IED blast that has disabled the vehicle and now the VIP and his Protective Detail are ditching from the truck and seeking cover until they can be extracted.
For the Suburban, I found what was listed as a die-cast 1/32 Cadillac Escalade on eBay for $10. It looked pretty good in the photos. When I received it, I measured it and it was actually 1/34 scale and very well detailed inside and out. Here is how it started life, with a 1/35 figure for scale.
I disassembled the Escalade and started changing it into a Suburban. First, I swapped out the wheels and tires for a set of beefier ones that I got from another 1/32 die-cast truck. I also added 3 scale inches of lift to accommodate the larger wheels and to show the heavier 4-wheel drive vehicles (the Escalade was already a 4 wheel drive, just low) these armored Suburbans are built on. Next, I ground off all the Cadillac badges and rebuilt the grill into a late-model Chevy Suburban style with A&B Putty.
I also cut open the right side rear door and removed all the over-sized hinges on the doors, hood, and back hatch. I also rebuilt the B pillar between the front and rear right side door.
Next, I moved on to the rear and added the inner armor plate that is fitted inside the rear hatch since this area is difficult to armor. The door on the plate will be opened with the rear hatch open and the interior fully detailed.
After the rear was taken care of, I moved on to adding some battle damage from the IED. The left side will be struck by the IED. I ground down the outer panels and smoothed them out to represent dented and shred panels from the blast. The area around the rear wheel took the majority of the hit and the rear tire was also shred to show the blast. I also dented in the front right fender and grill to represent the damage from impacting a road barrier that will be in the dio.
Next will be off to the paint booth for a shot of color and then some detail painting and weathering.
Let me know what you think so far and I'll keep you posted.
