Fordson WOT 3 - 30cwt 4 x 2
KitMaker: 14,499 posts
Armorama: 11,675 posts
Posted: Thursday, June 03, 2010 - 08:13 PM UTC
'Action this Day'
Winston Spencer Churchill
Posted: Thursday, June 17, 2010 - 08:53 AM UTC
'Action this Day'
Grumpyoldman
ConsigliereFlorida, United States
KitMaker: 15,338 posts
Armorama: 7,297 posts
Posted: Thursday, June 17, 2010 - 09:10 AM UTC
Character is what you do when no one is looking.
Few things are harder to put up with than a good example.- Mark Twain
Make yourself an honest man, and then you may be sure that there is one less scoundrel in the world.--Thomas Carlyle
Posted: Thursday, June 17, 2010 - 05:46 PM UTC
Hi Dave,
Am I right in thinking you did a build of this one some time ago?
Thanks
Al
'Action this Day'
Victoria, Australia
KitMaker: 10,889 posts
Armorama: 3,245 posts
Posted: Thursday, June 17, 2010 - 06:15 PM UTC
Interesting build, Al. Are you going OOTB? Or perhaps a small conversion? Could one portee this truck, or is it too small?
Rudi
p.s. apologies for not posting sooner, I must have missed it. BTW, is it posted at our other local?
Beware the populist demagogues at the head of private armies
Posted: Friday, June 18, 2010 - 03:22 AM UTC
Hi Rudi, yes, it's on the local. This will be OOB but maybe with a tarp added.
I've been doing some research into the vehicle and it is an interesting one. No opportunity for a portee conversion but some were built with van type bodies.
Al
'Action this Day'
Posted: Saturday, June 19, 2010 - 12:46 AM UTC
Some more cleaned parts.
The side poanels are a bit warpped one mor ethan the other.
The pour stubs require careful removal the bottom of the doors, and the rim cleaned out a bit.
Also one of the wheels had a poor join in the entre and needed sanded down a good bit to remove the offending line.
Al
'Action this Day'
Posted: Tuesday, June 22, 2010 - 06:39 AM UTC
Hi Guys
Well I was looking forward to a nice straight forward build,but I have to say given the price they charge for the kit these are some of the worst instructions I've seen for a while. Even through the looking glass I found them difficult to read so if you're doing this one I hope you have 20/20 vision!
To add to this the part numbers that are on the casting blocks are nearly invisible too!!!
Given the price they charge for these you'd think they could produce a half decent set of instructions!! Did I say that already!!!
Sample
Al
'Action this Day'
Posted: Wednesday, June 23, 2010 - 05:22 AM UTC
The Rear Suspension.
You need to fit 4 small brackets on to the frame to hold the suspension arms. Parts 17/18. There are no location points so this is Mk 1 eye ball stuff. The cross member into which the drive shaft fits needed cleaned up and the drive shaft itself was warped, so I straightened it out as best I could.
There are 6 small fittings for the front suspension.
Al
'Action this Day'
Posted: Friday, June 25, 2010 - 11:58 PM UTC
After some head scratching and breaking a couple of parts I got the front suspension on. I've strengthened the fixes with some Mr Surface.
Also added the central drive shaft.
Al
'Action this Day'
Posted: Monday, July 12, 2010 - 03:48 AM UTC
Update 12.07.2010
Al
'Action this Day'
Posted: Monday, July 19, 2010 - 04:06 AM UTC
'Action this Day'
Posted: Friday, July 23, 2010 - 10:14 PM UTC
Update 24.07.2010
Al
'Action this Day'
Aarhus, Denmark
KitMaker: 3,377 posts
Armorama: 1,088 posts
Posted: Friday, July 23, 2010 - 11:42 PM UTC
nice progress, hows the general fit ?
Too bad on the instructions- how hard can it be printing it in a decent size.. ?
Cheers/Jan
It“s happy days for modellers...
Posted: Saturday, July 24, 2010 - 12:13 AM UTC
Hi Jan,
Yip, given the price I don't think decent instructions are too much to ask for.
Fit wise so far there was a large gap either side underneath bonnet and between the chassis, which I filled with L beam. The bonnet to the firewal fit left the firewall jutting out too much so I filed that down a bit. Everything else so far seems pretty good. The cream resin is hard to photograph so apologies if any of the pics a a little off.
Al
'Action this Day'
#003
Donegal, Ireland
KitMaker: 9,763 posts
Armorama: 7,444 posts
Posted: Saturday, July 24, 2010 - 12:46 AM UTC
Its starting to take shape now Al. Bad instructions can really take the fun out of a build ... one can live with the faults in the kit itself, as mostly they can be easily fixed ...
as long as you know where the darmned parts go Ive only built one complete resin kit in my life ... Verlindens 1/16 2cm Flak ... and I knew right away, resin kits are not for me!
But its a cool looking little truck ... it might be just worth the hassle?
IPMS Stockholm
Posted: Saturday, July 24, 2010 - 03:19 AM UTC
Hi Frank,
It's a highly detailed kit, apart from the poor instructions the cream coloured resin doesn't show up detail well until you painted it, so identifying faint parts numbers and fixing points can be hard. My watch makers eyeglass is getting a lot of use!!
Hopefully it will turn out OK, it''s an interesting vehicle, one that could easily be done in palstic!
Al
'Action this Day'
KitMaker: 241 posts
Armorama: 199 posts
Posted: Saturday, July 24, 2010 - 03:48 AM UTC
Hi Al, Having fun following along on this one. How does the detail compare to a Resincast kit ?
randy
Posted: Saturday, July 24, 2010 - 06:47 AM UTC
Hi Randy,
The detail on the truck is excellent, where there would be a noticable diifferance is in some of the truck parts which are quite thick, for example the rear wall of the cab corners. This shouldn't effect the finish but it's noticeable.
There is much fine detail too so it would be hard to say, it compares very favourable in many ways, it's a high quality kit. The PE is very fine to work with, easy to damage, but I'm hopeful I'll get a good truck out of it, providing I don't drop and brake any more bits as I did this morning
I would have rated it higher in the review if the instructions weren't so 'c--p'. This will doubel the build time, but I'm moving along slowly. Undecided whether NWE or S Africa for a finish.
What is odd is that they give you a very nicely detailed engine and a bonnet that doesn't open!
Al
'Action this Day'
Posted: Saturday, July 24, 2010 - 11:11 PM UTC
Hi Guys,
I did a review of the kit here:
https://armorama.kitmaker.net/review/5384 I don't have a large amount of references for this one but here are some pictures I found scattered around the net.
This first one is possible the restored vehicle the kit was modeled on, but I'm not sure about that, just a guess given the finish.
The next two privately owned:
This one from a recent movie, whos name escapes me at the moment
and this one a wartime photo showing one of several camo styles used on the trucks
Build wise I'm getting close to finishing the engine and fitting the bonnet.
Al
'Action this Day'
Posted: Sunday, August 15, 2010 - 12:45 AM UTC
Update
Pedals have me a bit baffled!
Al
'Action this Day'
Posted: Sunday, August 15, 2010 - 02:29 AM UTC
'Action this Day'
Posted: Thursday, October 18, 2012 - 05:08 AM UTC
Hi folsk,
Hard to believe I started this one 2 years ago
I managed to break off the LHS window screen support, not a problem I though I'll just glue it back on but it was one of those pieces of resin that just didn't want to grip. After repeated attempts and failures I decided to pin it but this just caused it to disintegrate completely so with frustration levels rising I set it aside and got on with other things.
Its been sitting now for over two years so I though I best make an effort to try and finish it before I lost any of the parts. added the wheels, some pedals in the cab and the rear of the cab with some glass in. Just working on getting the doors to fit reasonable well and then I'll do the window screes and hopefully fit a filler part at that point.
Its quite a nice kit but poor and small instructions make it a pain to build.
If it works out reasonable well then I'll add a fuel load, if not then maybe a shot up or crashed truck. If it doesn't get done this year then it might never get built!
Al
'Action this Day'
Canada
KitMaker: 902 posts
Armorama: 788 posts
Posted: Thursday, October 18, 2012 - 11:11 AM UTC
Posted: Saturday, October 20, 2012 - 02:19 AM UTC
Hi folks,
A bit more work on the truck. Still some patching up to do where I snapped the support for the cab and some small fitting to add.
Al
'Action this Day'
