I went back to complete steps 10, 13, and 14, which cover the fender assemblies and the tow cables.
- The instructions show a mix of solid and skeletal reinforcing brackets. Per 4bogreen.com, this matches many photos of late Model 1941 vehicles, so I simply followed the instructions here. My only gripe is that most of the brackets don't join neatly to the side of the hull once the fenders are installed. The fenders have tabs to help you line them up against the hull, so I'm pretty sure this isn't just sloppy assembly work on my part. If Trumpeter had just made the brackets a touch longer this would be a non-issue as the modeller could simply sand down any excess. Ironically, Trumpeter provided plenty of excess brackets in the box … plenty of too small brackets.
- I used a razor saw to hack off the front portion of the left fender and then used a chisel to thin the remaining fender at the front and rear where I wanted to bend it. The missing portion may or may not be realistic, but I thought it was a good way to show off the tracks on this beast. I went easier on the right fender primarily because I had become aware of the fit issue with the first fender / brackets and wanted to get the best fit possible.
- Next up was the applique armor that attaches to the side of the hull beneath the turret. I missed the instructions in step 0 to pre-drill these holes, so I shaved the mating pins off and glued the parts on flat. No visual difference as far as I can tell.
- The spare links that go on the rear engine deck needed to be cleaned up. Per 4bogreen.com, the tracks show four attachment brackets but should only have three. The front outermost brackets need to be shaved off, so I did that.
- The tow cables were easy enough, but one of the attachment hooks broke when I tried to clean it up. My fault for being clumsy, but damn Trumpeter, try helping us out with smaller attachment points on the fine parts. I managed to fix the attachment hook, but given the damage to the fender on the left side decided to leave the tow cable off. If something sheared off the entire left front fender, then it's probably not a stretch to think that a tow cable might have gone missing somewhere along the way.
So that's about it for construction. Next steps will be to clean up the seams and gaps and to apply some Mr. Surfacer to the turret. Then it's prime time.
Here's where the model stands now. The tracks aren't fixed and the spare links and chain are just tossed on for effect.
