Best paint for hand brushing?
Ranchhand
KitMaker: 289 posts
Armorama: 257 posts
Posted: Wednesday, September 15, 2010 - 09:54 AM UTC
here is another vote for Vallejo. first time i brushed it on i was shocked by how well it covered.
Belt_Fed
KitMaker: 1,388 posts
Armorama: 1,325 posts
Posted: Wednesday, September 15, 2010 - 10:03 AM UTC
Vallejo. Its not toxic or anything so you shouldnt have trouble with import restrictions. Its a bit expensive, but will last forever.
Mohawk73
KitMaker: 388 posts
Armorama: 73 posts
Posted: Wednesday, September 15, 2010 - 09:37 PM UTC
In Holland € 2,25
Sometimes € 2,40
Sometimes € 2,40
tnichols
KitMaker: 66 posts
Armorama: 50 posts
Posted: Friday, September 17, 2010 - 06:15 PM UTC
I think I lost my manners. Sorry for the slow response. Really appreciate the assistance and info. Thanks again. Ted Nichols
jaberwaki
KitMaker: 109 posts
Armorama: 97 posts
Posted: Monday, October 11, 2010 - 01:10 PM UTC
Ron, for me model master acrylic paints are best for hand brushing. it goes on smooth and covers well. best of luck.
Posted: Tuesday, October 26, 2010 - 02:17 AM UTC
hi have you tried CITADEL paints from the games workshop excellent range a bit more expensive than say tamiya etc but superb quality.they have got one or two what will maybe seem strange sounding names but give them a try .go to the games workshop website select canada in the region box and it will list your nearest suppliers.
Removed by original poster on 11/26/10 - 09:38:47 (GMT).
dubik2005
KitMaker: 40 posts
Armorama: 34 posts
Posted: Wednesday, February 16, 2011 - 11:31 PM UTC
Guys why you like vallejo paints that much? It separates immediately. I have to mix it every time I dip brush. It's especially bad when I draw little detail, which can't mix paint so I have to take bigger brush....Reaper's paints and Andrea paints work much better. They don't separate and have nice coverage.
Big-John
KitMaker: 731 posts
Armorama: 711 posts
Posted: Friday, March 25, 2011 - 01:46 PM UTC
Winsor & Newton brushes. I have the Cirrus series. They are high quality Kolinsky Sable, leave no brush marks, and will last forever.
Use rounds for lines, points for detail, and flats for areas.
Matt, Where are you getting your Cirrus brushes from? I have been trying to find them but am having no luck.
I have a few and wanted to pick up some more, but it seams my sorce has discontenued them.
raffrecon
KitMaker: 266 posts
Armorama: 258 posts
Posted: Monday, May 30, 2011 - 03:34 AM UTC
Vallejo, by far. I just bought the 72 color military set and it includes 3 brushes as well. I really like these brushes too.
I like Tamiya and MM Acryl fro airbrushing.
Dan
Dan
Middle_Franconian
KitMaker: 279 posts
Armorama: 30 posts
Posted: Saturday, June 11, 2011 - 06:49 AM UTC
Hello!
I prefer Revell Aqua Color for applying paint by brush. It is odourless and one cup lasts very long. First I used it only for brush painting of details because I was not content with the results when using it in the airbrush and thinning it with water or Isopropyl alcohol. But since Revell has issued a thinner especially made for these colors I can handle the Aqua colors easily in the airbrush.
Servus,
Sebastian
Servus,
Sebastian
vonHengest
KitMaker: 5,854 posts
Armorama: 4,817 posts
Posted: Saturday, June 11, 2011 - 07:25 AM UTC
Sergiy, I have only ever experienced this problem once with Vallejo, one of the dark brown colors. Vallejo paints have otherwise been stellar to work with and are my favorite paints for brush painting.
imatanker
KitMaker: 1,654 posts
Armorama: 1,565 posts
Posted: Monday, July 18, 2011 - 07:01 AM UTC
So let me get this straight,Vallejo can be brushed right out of the bottle with good results,with out having to mess with retarders and flow enhancers? Thanks,Jeff
dubik2005
KitMaker: 40 posts
Armorama: 34 posts
Posted: Monday, July 18, 2011 - 08:01 AM UTC
Technically you can, but I wouldn't suggest. It's very hard to paint. Just add one drop of water, it will be much easier. (1:1 paint:water). Retarders and flow enhancers are completely optional. Some also may suggest distilled water, my tap water is pretty good.
retiredyank
KitMaker: 11,610 posts
Armorama: 7,843 posts
Posted: Monday, July 18, 2011 - 09:58 AM UTC
I use taklon brushes. They seem to resist "feathering" and are great with enamels. I have heard good things about Vallejo and Humbrol paints. But, due to difficulty of finding either here, I stick with MM enamels. For airbrushing, I use either Tamiya acrylics or MM enamels. MM acrylics are nice, as well. You will need to add a couple of drops of glass cleaner, if you use MM acrylics.
Removed by original poster on 07/18/11 - 22:38:05 (GMT).
imatanker
Posted: Monday, July 18, 2011 - 11:55 AM UTC
Sergiy,thank you.I assume you can clean up with water?Does anything work better? Windex,isopropyl alcohol Quoted TextSo let me get this straight,Vallejo can be brushed right out of the bottle with good results,with out having to mess with retarders and flow enhancers?
Does anyone else have a preference as to what to thin (for brushing) and clean up Vallejo acrylics with?What ratios?Thanks,Jeff
Tarok
KitMaker: 10,889 posts
Armorama: 3,245 posts
Posted: Monday, July 18, 2011 - 02:00 PM UTC
Practically you can as well. You just need to ensure that it doesn't seperate
Jeff: my preferance for thinning Vallejo Model Colour is distilled water for the reasons above. For thinning Vallejo Model Air: I don't, I spray straight from the bottle (well, bottle, to AB cup...). When painting (Model Colour) I clean the brushes using tap water, however at the end of the session I use Vallejo's brush cleaner and restorer - acrylics (or vinyl as in the Vallejo case) paints can be heavy wearing on brushes.
My 2c...
R~
Phil_H
KitMaker: 546 posts
Armorama: 442 posts
Posted: Monday, July 18, 2011 - 02:50 PM UTC
It's hard to suggest a specific thinning ratio for Vallejo ModelColor because the paints can vary considerably in consistency from one colour to another. Some colours are quite watery and some extrude from the jar almost in strings.
As already noted, distilled water works quite well.
And as always, shake till you think you've shaken it too much, then shake it some more.
dubik2005
KitMaker: 40 posts
Armorama: 34 posts
Posted: Monday, July 18, 2011 - 06:48 PM UTC
As Tarok already wrote, you clean brush with the water during paint session and use airbrush cleaner if you see some color on it after cleaning with water.
Regarding thinning ratio....It depends on your painting style. There are 2 (there are of course more, but these are quite popular) ways: slow color change - relatively thick paint (requires good sense of color), or very thin paint but colors can be completely different (requires a lot of patient and self control!).
This is the example of first approach:
http://www.youtube.com/watch?v=TMDWfDkap0w
and this is the example of second:
http://www.youtube.com/watch?v=BY911xa_xOI&feature=related
In the first video thinning is about 1:1 or 1 part water to 2 parts paint in the second 6 parts water 1 part paint.
More you put water less you control where it goes, you have to unload most of the paint from it on a paper.
My experience is similar to yours, however I found that thinning it with tap water caused it to seperate.
Good for you
I also have to take back my words about reaper paints, they are rubbish.
Tarok
Posted: Tuesday, July 19, 2011 - 12:41 AM UTC
Good for youPaints separate because they have different densities, I don't think tap or distilled water matters that much anyway I'm now using fairly big brush raphael size 1, and I can steer paint a bit when it separates.
:) What works for some... You're probably right about the thinning ability (?) of the different types of water, however the chemicals and additives to tap water must surely have an effect on the paint. South African tap water (which is what I thinned with before changing to distilled) is very drinkable, but only because of all the stuff they add to it to make it thus.
Thanks for the comments on Reaper paints. I've been tempted to try them, but might give them a miss then. I'm somewhat partial to the GW/Citadel paints, except for the stupid, easy-spill container
Back to Jeff's question though... mate, I just found this article which may be of interest. Although more for the AB painter, it might be of use: Types of Thinners .
imatanker
Posted: Tuesday, July 19, 2011 - 01:06 PM UTC
Nice ,nice,nice ,nice ,nice.thanks too much.Just what I needed.Now I have something to work with.Thank again,JeffQuoted TextGood for youPaints separate because they have different densities, I don't think tap or distilled water matters that much anyway I'm now using fairly big brush raphael size 1, and I can steer paint a bit when it separates.
Thanks for the comments on Reaper paints. I've been tempted to try them, but might give them a miss then. I'm somewhat partial to the GW/Citadel paints, except for the stupid, easy-spill container![]()
