Matt, Karl, thanks guys! Glad your both still tuned in, we are nearly there
Al, cheers bud, yep your copper wire came in handy, ta very much!
Dio sounds good but I dont think I have it in me to go put one together before the IMSS show.
I have this to finish, plus two figures to build and paint never mind a simple base to put her on, all this before mid May will be tight by itself
..must hook up soon and catch up my friend!
Got off early today from work so made some good progress with the build!
Last night I had poured resin liquid into the seat cast to let it set overnight
Today I removed the seat, you can see it here next to the cast. I'm happy with the result!
I didnt bother casting a second seat because the original seat I used for the mold will do perfect!
I still have some detailing to do with these seats, more on this later..
Next I added some tools to the bonnet (front hud).
I was working on the passanger side weapons mount and letting a few bits dry when I decided I'd attach the wing mirrors, only to discover they are incorrect to the Irish F-350!
So working with what I had I scratched new mirrors from the old ones. I'll have to make new arms tomorrow..
Next I finished the passanger side weapons mount with swinging arm.
But before i go straight to the photos though I'll expalin what happened next.
Whilst the weapons mount was drying I started building the storage bins where the doors usually are.
I was having some major problems gluing some brass bars to PE plate so I decided to prime them first.
After spraying the parts and having the primer out anyway I decided to crack on with giving the entire model its first coat of primer! I got into at all the nooks and cranny's and left it to dry. The benfit of this is now I can see more clearly where I have to clean up (some places obviously more than others!).
I went on to finish the door side storage bins and aligning frame steel.
here is almost everything so far
Lastly today I scratched the rear panel behind the driver/passanger seats. This has an Amp/fuse box for regulating power to the com sets etc and above that is a speaker (I got the speaker from the Pro Arts set mentioned earlier).
..now I'm off for a few pints! (glug glug
