Hello
thanks Eddy, Fred and Alexander for your comments
Alexander thanks for the heads up on the turret - the hole I cut was a bit too tight to let it sit properly, I wanted it tight so it wouldn't fall out, but was a bit too tight, now fixed
Eddy, there will be men on and around this train for sure, just where and how many I haven't decided yet
Fred I have the whole train of 13 pieces. Though I'm going to build it as two half trains, so that its a managable size for display, and so I can try a different camo scheme & setting on the other.
I have seen some of your work on the 'Military Railroad Campaign' forum, looks great
That treadplate issue is a tricky one. There is a 50% chance I'm right or 50% chance I'm wrong. Nearly all the war time photos I can find are side only, and the only one which has a bit of the upper area is of poor quality, it appears smooth, but given the photo quality and light, you couldn't convict on that evidence
, and none of these exist in real life in museums to check. I know other kit manufacturers have not put the treaplate on. I might go a compromise and not put treadplate on the next one I build (which is still in the box untouched yet)
a little more progress done.
I have tried to improve the camo on the train, touching up the green and red brown. The red brown is a bit light, but will darken a bit with a wash or two. I didn't want it very dark like in the Trojca artist's impressions, as dust covering & weathering lightens the colours.
The Panzerjagerwagen has had a light coat of grey to identify any areas that need sanding or filler.
I have bought a 1200 millimetre long shelf x 200 millimetre wide which will be the base for the train display, which leaves a bit of space either side of the train for some scenery, vehicles, people or other details.
I've also bought some clear acrylic sheet 3 millimetre thick to cut to build a 'case' to put over the base.
here area couple of pics, and for me its back to the train
cheers
Neil
