Every time that I look in on your post you have something new for us to see. The last time I dropped by you were in the process of detailing your Panzer IV flatcar and now you’ve managed some camouflage and have moved onto building a quad 20. I like the modifications that you undertook on the quad 20 and again a good friend of yours has come to the rescue with some high quality photo-etch items to enhance your build. Your friend sure knows his deal and has come up with some very well detailed photo-etched items that are far better than what’s currently available on the aftermarket scene. Looks like you can position the quad 20 just like on the real deal, how cool is that!
Nice job on the case. I read through your step-by-step on how you went about putting together the acetate case. I have a suggestion if you are going to put another case together in the future. Instead of using a Stanley knife try using a P-cutter. I’ve used it for cutting acetate without having to apply the type of pressure you mentioned using with the Stanley. The P-cutter and blades are relatively inexpensive and available at most hardware stores. The blades are also available in a few different widths; the blades remove material as you move them across the acetate leaving a small trench on the first pass that will help guide the cutter on the seceding passes. I use it for cutting styrene sheets. I provided you with a photograph of the one I use.
Again, keep it coming; I’m really enjoying this build.
-Eddy
