Thanks again Zon. Base was made today from a scrap piece of pine I had laying around, & sprayed with a texture paint. Once dry, I'll probably airbrush a stone color on it, allowing it to (hopefully), blend into the scene above, so that they become one, (sort of).
Kevin
35 years ago I started off with nothing; and I've still got most of it!
Jagdtiger46
Missouri, United States Joined: October 26, 2011
KitMaker: 291 posts
Armorama: 256 posts
Now that plaster has dried, a small bit of sanding and a repaint has commenced. I’m shooting for an off white, beat up & worn look, what I consider to be a suitable background for the figure.
Wall painted light gray, then some pastels smeared on.
Finally painted “French White”, and some details painted. Not the best wall around I realize; I may add yet more dirt to it.
Kevin
Jagdtiger46
KitMaker: 291 posts
Armorama: 256 posts
Certainly one concession I’ll have to make is the rubble pile. It seems unlikely that there would be so little rubble as I’ll be displaying, but I don’t want all that “stuff” to dominate the scene. Also, because the figure is molded flat footed, I can’t have him standing on tons of debris. Small blocks of balsa foam have been glued to base to act as a substrate for plaster/debris, with boards, jagged metal shards, wire, and the like glued on afterward.
Kevin
ophelia53
Missouri, United States Joined: March 10, 2010
KitMaker: 254 posts
Armorama: 226 posts
Posted: Wednesday, November 09, 2011 - 04:40 AM UTC
I like the way the scene is coming on Kevin. I think you are spot on in not wanting to have the base massively cluttered- as you said you want the focus on the figure and the background as it stands looks very good. You should maybe consider adding some spent bullet casings too- thin brass rod is an easy way to create them.
My only criticism is that the wall appears quite clean- you mentioned adding some dirt too it and I think that would be a good idea.
Anyway, its coming on great- I'm looking forward to seeing it all put together.
On The Bench:
Ethiopian BMP-1 (Trumpeter 1/35)
AMX-13/75 (Takom 1/35)
Jagdtiger46
KitMaker: 291 posts
Armorama: 256 posts
Posted: Thursday, November 10, 2011 - 04:49 PM UTC
While I tend to agree, I'm somewhat reluctant to make it too dirty, as that may tend to draw attention away from the figure. I'll probably finish figure, add rubble/debris, then determine if wall needs additional work to fit the mood of the little scene.
Kevin
