Thanks so much for the invite, and all of the advice you are providing. You have already kept me from making several errors, and I cannot tell you how valuable an asset your build log is for the community.
As for your comments on the Griffon kit, I could not agree more, especially with regard to the hinges. For the rest of this build I also plan to use many of the kit parts, as some just look better to my eye. I have also learned, the hard way, that annealing almost all of the Griffon PE with a cigarette lighter will save you a lot of heartaches; especially if you make a mistake and have to rebend or straighten one of the small "ears" on some of the PE boxes and brackets.
Because I chose to model the early variant of the M16 (just couldn't resist the White heater box and the resevoir tank), I thought you, and the folks following along might like to see what the early variant parts look like. I have also included a photo of a great product I use to hold small PE parts for gluing to the model. It's called "Clear Museum Gel", and it beats the heck out of tweezers. I take a small ball of it and place it on the end of a cut-off toothpick, grab the item, add glue to the bottom of the part, and slowly guide it into the desired location. This stuff has just enought tack to hold the part when it is being attached, but easily releases it when the glue starts to set. I also use it to temporarily attach small parts when test-fitting them to the model. You can find it here: http://www.quakehold.com/safety-during-earthquakes-safety-preparedness-safety-furniture-straps/safety-preparedness-safety-furniture-straps-collectibles.html
Congratulations on your accomplishments - Keep up the good work Tarheel!
All the best, Don
