Hey Gang!
Well, it's been one week over half a year and I finished her up tonight! I did a mad dash to get her down to the AMPS show in SC and probably rushed it a little, ended up with a Silver in the Advanced category and came back with a few pointers to hopefully get gold next time! (Also came home with an SUV full of new kits and accessories!)
It's late, so I'm going to give you a short narrative of the last few stages, hitting the highlights and lowlights, and just post a mess of pictures.
So, inpreparation for airbrush weathering, I painted the roadwheels in Floquil "Weathered Black"
And here are some pics before I cranked up the airbrush
For the weathering, I used all Tamiya, cut with 70% rubbing alcohol. First, "Flat Earth, heavy on the lower 1/3 of the vehicle, then "Desert Yellow" light on the lower 1/3, heavier on the middle 1/3, then "Buff" light on the middle 1/3, heavier on the top 1/3. IMHO this gives a nice realistic graduated look.
I don't like the look of the molded antenna that came with the kit, so I cut off the top piece, scratched the base from a punched disc and some plastruct, made the spring by winding a strand of speaker wire around a piece of wire and superglued it all together
Made a ration box from the verlinden printout. Bent this sides with my etch tool and glued it together with rubber cement, clamped it with a Harbor Frieght spring clamp
Added a couple Archer data plates to finish up the radio
Ran a wire made of thin solder painted black from the radio box to the antenna.
Mounted the 50 cals. A word of caution here, if the two mounting sides of your turret are not perfectly alligned, your guns won't be parallel. Mine weren't
So I had to do some tedious filing and shimming to get everything true
Thought I would get real cute with the next step. I was bummed that the radiator had lost it's black color with the OD and weathering coats. So I vised her nose up and thought I had a great idea on how to paint the radiator through the armored grill slats
But my hand wasn't as steady as I though and I ended up touching the OD in a few places with this hideous result
After that disaster was dry I repainted the effected ara in OD, cut a mask, and re-weathered using the 3 solor airbrush method. At this point it was 3:00 on Friday afternoon, and we were heading out to dinner with friends at 6:00. Uh-oh...
Down to the tiny details...I had seen some open hood pics that showed a cushion strip where the hood folded down into place, as well as cloth straps on the center hinge. I replicated these with thin strips of masking tape
Then I took the photo etch rounds and added a small strip of masking tape painted white to simulate the canvas belt. I found out at the amps show that the black plastic clips would be more accurate, so they were repainted tonight. I also in my haste left off the ammo bay covers (inexcusable!!) they were added tonight!
Also tonight, a very light dry brush of weathered black on the tracks and wheels to pop out the high spots and a few subtle fuel spill marks on the jerry cans and around the fuel fillers. Then a quick touch up to eliminate all the little spots of shiny brass that had emerged on the 7 hour round trip to Columbia!
That's it my friends! Some 1400 pieces and 200+ hours later, here are some pics of the finished product. I hope you have enjoyed reading this as much as I've enjoyed doing it!
Til next project!
Terry
