H.P.
HALF a DEUCE vs. a DEUCE and a HALF
Just a few updates on my build log for the Half a Deuce truck conversion:
Everything went according to plan meaning that I DID have to build a custom driveshaft to run between the White transmission and the GM transfer case. One thing I did not count on was that I would also need a special length driveshaft to run from the transfer case to the front axle drive. I lucked out however, in that a spare rear axle GM driveshaft worked just fine so my spare parts box once again paid off!
I took a few small liberties with the build however; First, I had a spare front bumper from a WC-51. It fit so perfectly - all the mounting brackets on the bumper matched with the frame spacing of the Scout Car so when I first dry fit the bumper it stayed in place just by mere friction, AND it looked good, so I went with that. Second, the individual pioneer tools on the Revell kit are so poorly done and oversized that I substituted the Tamiya tool rack from the Dragon Wagon. (I happen to think the Tamiya offering is one of the best plastic tool sets you can find in 1/35th!)
And of course I substituted the new Fuel and Water “Jerry” Cans from Tasca for the horrible ones that come with the Scout Car.
Finally I added a rack with two more Tasca water cans installed under the load box, between the GM gas tank and the back of the cab. a.k.a. British practice. I figured what the heck, this is a maintenance shop conversion so the shop foreman can do whatever he wants. Besides this vehicle was employed in North Africa so the extra water capacity would probably be welcome. I did not add any fuel cans to the external stowage because this vehicle already has THREE gas tanks: the GMC tank mounted to the frame and two installed inside the armored body by White Motors.
I will be posting finished photos tonight!
Sorry still rounding up the appropriate decals so nothing yet on proper markings but the truck is running and more than drivable!![]()
John did I see you mention the International again?
Sorry to say but it is still right where I left it, as is the almost finished Studibaker AND the CCKW / locomotive conversion!
I think my next project will probably be the 2 axle, 1.5 ton, Chevy military fire truck with scratch built front mounted water pump. I just found some vitally needed parts among the railroad modelers that had been holding up the project.
Well I didn't really want to make my Studibaker a Russian soldier anyway and thanks to you my Studi is now going to join the US Navy!![]()
p.s. Should it be Semi-Gloss or matte for Navy service?
Hi Mike, I mentioned it in connection with the picture of your son in the halftrack, and wondered if it was an IHC M5.
John
