No worries. If you REALLY want to be cool(and accurate) next time model some,if not most, of the pouches empty.
J
Dioramas
t-26 and trench diorama
jrutman
KitMaker: 7,941 posts
Armorama: 7,934 posts
Posted: Tuesday, March 26, 2013 - 03:55 AM UTC
lespauljames
KitMaker: 3,661 posts
Armorama: 2,764 posts
Posted: Wednesday, March 27, 2013 - 10:40 PM UTC
Dave, its all vallejo paints.992Neutral grey for trousers, and 830 German field grey ww2 . I'll be going into detail in my figure sbs over the next week.
Jerry. I had never thought of that. How would I go about it ?
I'm at a loss on how to border the dio. Keep it earth. Or do something?
Posted: Wednesday, March 27, 2013 - 10:52 PM UTC
Ola James
Great work all round mate. figures look top.
As for bordering the base. I usually make a border of 1mm thick styrene that is the height of the foam base with all the elevations in it which I spray black. But I usually do this early on in the project while I'm creating the groundworks. Because that way I can close the gap between the styrene and the foam with spackle or whatever I'm using for groundworks
jrutman
Posted: Thursday, March 28, 2013 - 01:43 AM UTC
Jim,
You get out your trusty epoxy putty or majic sculpt and make one from scratch! An easy way to start would be get a kit plastic ammo pounch and cut off two of the pouches or at least grind down their fronts to create a backstop. Then build the empty pouches onto that. Open flaps can be made with putty or with lead foil from a good wine bottle(bonus here is you get to consume said wine)
J
panzerconor
KitMaker: 1,271 posts
Armorama: 1,253 posts
Posted: Thursday, March 28, 2013 - 05:43 AM UTC
If you snatch one of Dragon's Gen2 figure sets, some of the ammo pouches come opened up. It would still take some work like Jerry said but at least you wouldn't need to worry about making your own flaps
Unless you want to, if that's the case then this redundant haha.
The only downside is that there's only 2 open pouches for each type (2 open Kar 98, Stg 44, MP40, G43), and you would be buying the whole kit for that one feature.
