Happy Father's Day to all!!
Got up early,wife got me a really nice Notre Dame polo shirt. My alma Mater!
She decided to go swimming,so I was able to spend all day working on the ladders of the K-5E Leopold. These ladders have been so
frustrating. Why did Dragon make the ladder rungs so flimsy and impossible to cut of the sprue!!! WHY WHY WHY?
Ok, I bought the Eduard photo-etch and tried t drill larger holes.ruined it,went on e bay and bought a second one and put it together and I .it looked like crap.Pic 1,2,3,.
I mean bad! I looked at my stash and got out my Plastruct 90725 .5 mm x 2.5mm flat . It is a bit bigger than te Photo etch but thinner and more to scale than the kit. I also got some thin rod. I made a jig to drill ladder rung holes and using my Dremel I drilled out the ladder rung holes. Pic 6,7,8,9,10,and 11.
After lots of breakage finally got them done. Rounded corners ,were made by cutting the square and sanding.I used plastic weld cement with this siphon dripper thing. Worked very well, They may look a bit well not perfect but when I paint them and sand them they should look ok. After all in combat things get damaged and beaten up. I remember jeeps and guns etc after a fight. Broken windshields, fenders atc. Holes. Very few in me thank heavens.
I bought another Verlinden ammo kit. I want to post the gun as if there are ready for multiple fire missions I put them on my sprue paint jigs and painted them with Tamiya RLM Dark Grey Acrylic paint.Pics 12 &13. I painted the shell canisters with Rustoleum Gold metallic paint from a spray can I had in garage. Much better than the brass acrylic. I then paint the other 4 canisters the same, I think they look 99% as good as the brass ones I got from Germany!
While waiting for the ladder kits to arrive,I decided to try the German Uniform Archer Dry transfers and decals.After prepping with Future,letting it dry overnight, I put the Black,red white shields on each helmet, also the German eagle on the other side. They went on ok but my hands are too big and I am glad they give you extra.I used some of the dry transfer shoulder boards, , I put a thin layer of Elmers glue Too, Then I carefully cut out decal shoulder boards and put them over the dry transfers. They looked pretty good. Then I put on collar boards and hat emblems, also the division cuff things, even an iron cross or two, , NCO chevrons etc. For purists please note used some SS and others insignia,I used insignia that shows up best. Pics 12 ,13, 14 ,15 ,16, 17, 18 ,19 and 20.
I don't think I will glue the ladders on until just before I display the gun, they break too easy,
I plan on touching up/improving the soldiers,arranging the ammo pallets. etc. I a;so have to buy a shelf to hold the completed gun! Hope this helps if you are planning to build this baby!
