Decals are done and some detail painting has started.
Enjoy
Dan
Can I point out 2 things? The figure is wearing later war boots -- at a time when the M3 Stuart wouldn't have been a front line fighting vehicle. Maybe switch out? Also, make sure your co-axial .30 cal MG is co-axial to your 37mm main gun. From your pics (which are great to find minor flaws in one's own work), they are not in line with each other. Hope these help.
Quoted TextCan I point out 2 things? The figure is wearing later war boots -- at a time when the M3 Stuart wouldn't have been a front line fighting vehicle. Maybe switch out? Also, make sure your co-axial .30 cal MG is co-axial to your 37mm main gun. From your pics (which are great to find minor flaws in one's own work), they are not in line with each other. Hope these help.
Cheers Roy, I'll have a look for another pair of boots now, didn't know that so thanks for pointing it out. The Co-ax is still to be glued in place and it's a little loose in the housing, hence the offset look, once I get some glue on it it should be set at the right angle.
Many thanks
Dan
