@ Pawel & Keith: Thank you, gentlemen!
@ Jeff & Dave: Ring-ring...
Hullo, Jigs-R-Us. How may I help you?
A jig for what..?
Of course we have a jig for that.
We have a jig for everything!
You guys are killin' me, I tell ya, killin' me...
Seriously, though, the appearance of functionality is a factor of replicating the prototype as closely as I can. All of these lines and components are present on the real tank, so the modeled parts naturally look right.
@ Jer: Sorry to disappoint, but there's no magic, no jigs, and dancin' to get those lines straight. Just .010 lead fly-tying wire straightened out by pulling it through my fingers. Most of the bends were made in place around toothpicks and / or a piece of thick brass rod.
The lines are held in place by CA and small L-shaped "clips" made of lead foil. The L's are glued in place and folded over the lines as I formed them.
(You can actually see a few of the L-clips in place for the electrical wiring harness yet to be installed.)
The compression fittings are Grant Line #127 hex head nuts drilled through with a pin vise and bit while still on the sprue. The drilled out hex castings were cut from the sprue and slipped over the lines before I installed them.
Anyhow, I've airbrushed the preliminary base colors in the compartment and on the various separate subcomponents.
All of the airbrushing for this was done with Floquil Model RR Colors reduced with lacquer thinner (since Diosol has gone the way of the dodo...).
The colors chosen were matched, more or less, to the photos in Montgomery's Haynes book and website. He's very adamant about the white interior and green gearbox. (When it comes to the detail painting, though, I think that I will go with steel-colored hard lines vice the copper lines that Montgomery has used in his restoration based on strategic material shortages assumptions.)
The colors used and the sequence I sprayed:
(After washing and drying)
1. Used strips of blue tape to mask off a few gluing lines and attachment points on the various parts and inside the compartment.
2. Sprayed Light Gray Primer over all.
3. Sprayed Box Car Oxide Red over the areas to remain in "factory primer". Also, used this color on the rear cooling air grates and upper rear hull plate.
4. Masked the primer red areas in the hull.
5. Sprayed Reefer White in the hull and on the bulkhead wall. I allowed some of the gray primer to work as pre-shading.
6. Cut and applied two hole masks for the main brake drums.
7. Sprayed Rail Brown on both the main and steering brake drums.
8. Sprayed Weathered Black on the air compressor and the final drive muff couplings. Also sprayed a little of this same color on the centers of the brake drums. The intended effect will be that the brake drums were painted black and have rusted around their circumference from heat.
9. Masked around the circumference of the steering brake drums.
10. Sprayed a mix of Pullman Green, NYC Jade Green, and Rail Box Yellow (6:4:1) on the actual gearbox and speed change lever assembly.
By the time I was done cleaning my airbrush, the paint had dried enough to remove all the masks.
Here's the result-
The detail painting, weathering and assembly will be done in the following (planned) sequence -
1. Detail paint and weather the inner hull and bulkhead wall to include the hard lines and generator. I will then install the flexible drive shaft from the speedo drive wheel and the electrical wiring harness.
2. The gearbox and speed change lever assembly will be weathered and assembled. I will measure and add the drive belts for the generator and speedo drive wheel to the power pulleys on the gearbox. I'm going to use elastic Easy Line for these belts, and the plan is to slip them over the generator and drive wheel after the gearbox is glued in place. (We'll see how that works...).
3. Paint the fan.
4. Install the gearbox, fan and bulkhead wall. Add the forward deck support cross member.
5. Fabricate the final pneumatic lines and install the air compressor onto the gearbox.
6. Paint and install the fuel fillers along with their fuel return lines.
7. Add the rear deck support cross member the rear cooling air outlet grates and upper rear hull.
Hopefully the next updates will show all of this coming together as planned...
Happy modeling!
