Modeling mystery #72: After getting my air recognition panel painted and ready to install, I moves some things around on my bench in preparation for mixing my pigments and then couldn't find it. I looked for at least 20 minutes, but it's gone. So I decided to do one from wine foil:
It needs a couple more coats of paint, but it's close.
And speaking of close, here's my pigment mixture, consisting of a medium brown, gray-green and gray:
I needed to get my base color more "gray/green" to better match the IDF sand/gray color from circa 1982, and blend in a little road dirt and masonry dust, which will give you a very good idea of my idea for a base. So after a few applications with flat clear in-between, I'm here:
I would like to darken up the exhaust stains, and possibly show some evidence of paint wear on the stored extra track links, but I may leave them as-is, since they were painted with the tank originally. I also need to add a tie-down to the one end of the tow cable that's not secured to the turret side, but it's getting very close.
Not sure about figs yet, I have a show the middle of Sept and I want to take this one but that may not be enough time to source and prep two turret crew- if not, it'll go with closed hatches as all three are either removable or operable.
Thanks for watching!
