have you clocked the fact that the Small pack has separate L-straps which connect to the pack by tabs on the top of the back of the pack and by buckles at the bottom? At the corner of the "L" there is a flat hook that clips into a fitting at the top of the front pouches. That's why the buckles are seen high up on the back. This arrangement meant that the pack could be taken off easily without removing the whole set of webbing equipment.
sk
Simon,
Very glad to see you chime in again. You have provided extremely useful intel in the past and maybe you can clear things up again for me concerning the small pack.
I gleaned from my pics of the real deal so far about the attachment clips above the ammo pouches. Got that part on my fig. I have the straps going under the arms back to the small pack. If I understand you correctly there is where I go astray? With the attachments to the small pack?
I have a learning curve going on here as this is the first time I spent a lot of effort on a Commonwealth figgies' webgear. I want to get it right so the subsequent figs I have planned are acceptable.
So...am I correct in saying the l straps were attached to the small pack with buckles top and bottom. These straps remained attached to the small pack with the wearers arms passing through the open part of the L so the only thing needed to do when dropping said backpack was to pop the snaps above the ammo pouches?
If this is the case then I need straps running over the top of his webbing over his shoulders?
Long winded query,sorry,but I want to nail this down,as I said.
Curious as to why no one has released a set of PE for commonwealth personal gear. There are at least three different sets available for the German stuff?
Here are the only Brits I've ever done. No small packs.
So I hope,if anything,that my Commonwealth "feel" has improved?
J
