Accurate Armour Spartan CVRT
KitMaker: 803 posts
Armorama: 793 posts
Posted: Sunday, February 15, 2015 - 10:38 PM UTC
Working on the GPMG, replaced with the Live Resin
version.
Mount is almost done.
Kit part nest to the un modified version.
Dan
KitMaker: 803 posts
Armorama: 793 posts
Posted: Sunday, February 15, 2015 - 11:35 PM UTC
Mounted for the first time, still the cocking mech to do yet and a bit of tidying up.
Enjoy chaps
Dan
Napier, New Zealand
KitMaker: 1,049 posts
Armorama: 841 posts
Posted: Sunday, February 15, 2015 - 11:53 PM UTC
Nice build, I'm enjoying watching the work with the figures too.
Brent
Available for commissions,visit my Flickr Albums and modelling/painting blog to discuss .......
http://houseofqueeg.wordpress.com/
https://www.flickr.com/photos/134514258@N04/albums
KitMaker: 803 posts
Armorama: 793 posts
Posted: Monday, February 16, 2015 - 03:51 PM UTC
Thanks Brent, chuffed that you are following along.
the hard part will be painting DPM
So I've added the firing solenoid to the mount and removed the pistol grip.
Should look good under a coat of paint, I'll have a crack at adding the cast on part numbers to the ammo box outer using the Archer Decals later, more pic's later.
Dan
KitMaker: 803 posts
Armorama: 793 posts
Posted: Monday, February 16, 2015 - 04:54 PM UTC
And the cast serial numbers, not correct at all
as I couldn't get the right combination of numbers and letters but better than nothing?
Raised resin printed onto decal paper, careful with the paint I think.
Dan
KitMaker: 331 posts
Armorama: 320 posts
Posted: Monday, February 16, 2015 - 05:01 PM UTC
Hi Dan,
GPMG's fitted to Spartans have their pistol grips still attached, as they are lowered into the gun cradle the trigger guard contacts an L shaped trigger bar which swings another piece into contact with the trigger.
http://data3.primeportal.net/apc/dan_hay/spartan/images/spartan_073_of_107.jpg You can see the piece I mean on the link above just above the link exit chute. It is the rod with the two prominent bars protruding. The trigger guard contacts the left hand one which rotates the right hand one inside the trigger guard.
Cavalry add style and panache to what would otherwise be just another s**tfight between grunts.
KitMaker: 803 posts
Armorama: 793 posts
Posted: Monday, February 16, 2015 - 05:05 PM UTC
Cheers Max,
That will teach me to use photo's from a restored Civi wagon !! oh well I'll put it back on later.
http://leicestermodellers.weebly.com/fv103-spartan-apc.htmlDan
KitMaker: 331 posts
Armorama: 320 posts
Posted: Monday, February 16, 2015 - 05:51 PM UTC
Easily done though mate. You can actually see the trigger bar above the electrical connection on one of the pics.
Max
KitMaker: 803 posts
Armorama: 793 posts
Posted: Monday, February 16, 2015 - 07:23 PM UTC
Trigger mech and pistol grip added, I downsized the solenoid as the first one was a little big and caught the side of the pistol grip. Thanks Max for the advise fella. the GPMG set up on the 432's were a lot easier to use.
Added the FFD pocket to commanders arm and the section commanders arm .
Dan
KitMaker: 803 posts
Armorama: 793 posts
Posted: Monday, February 16, 2015 - 09:59 PM UTC
KitMaker: 803 posts
Armorama: 793 posts
Posted: Tuesday, February 17, 2015 - 05:09 PM UTC
Castoff front bins added.
Dan
KitMaker: 803 posts
Armorama: 793 posts
Posted: Wednesday, February 18, 2015 - 08:23 PM UTC
KitMaker: 2,092 posts
Armorama: 1,607 posts
Posted: Wednesday, February 18, 2015 - 11:51 PM UTC
Great work. Especially the GPMG rework.
I thought the front bins only came with the LEP upgrade.
KitMaker: 803 posts
Armorama: 793 posts
Posted: Thursday, February 19, 2015 - 12:34 AM UTC
Hi Paul,
Cheers for the comments fella, means a lot , I've seen a few non LEP Spartans with the bins so I thought why not
Dan
Napier, New Zealand
Armorama: 841 posts
Posted: Thursday, February 19, 2015 - 11:15 AM UTC
Tis starting to look ready to roll now with the tracks on, well one side anyway. The crew changes worked well too I think ....
Brent
KitMaker: 803 posts
Armorama: 793 posts
Posted: Thursday, February 19, 2015 - 01:56 PM UTC
Thank you chaps,
So I remade the convoy light and bracket, the back door mould wasn't up to much and the kit convoy light was just a blob of resin, this was removed and a new one fabricated from PE scrap and plastic rod. I've also added the rear recovery bars and just need the chains added for the retaining pins.
The bracket for the Axe was also chipped so I used magic sculpt to repair this.
Dan
KitMaker: 39 posts
Armorama: 38 posts
Posted: Tuesday, February 24, 2015 - 02:27 AM UTC
Looks good, some great work going into it!
Simon Oliver.
"Sometimes, it's better to let someone think you're stupid, rather than open your mouth and remove all doubt."
KitMaker: 803 posts
Armorama: 793 posts
Posted: Saturday, February 28, 2015 - 07:59 PM UTC
Thanks you Simon,
So a bit of a break away due to work going in in the house,
so just a few more bits done.
Headlights are drilled out ready for MV lens to be fitted.
Chieftain tank bin added.
missing bracket added to the NBC pack door
Winky pot and mount
D10 cable reel and bracket
And the headlights wired up.
Enjoy
Dan
KitMaker: 803 posts
Armorama: 793 posts
Posted: Tuesday, March 17, 2015 - 06:12 PM UTC
Another quick update, bit of an issue with primer
which has pushed me back slightly, but here is where I'm at.
Cheers all for looking
Dan
Western Australia, Australia
KitMaker: 679 posts
Armorama: 409 posts
Posted: Wednesday, March 18, 2015 - 06:54 AM UTC
Excellent work Dan. :-)
What paints did you use?
Marty
In 1809 trying to reach the carnage of Talavera,
the Light Division had marched forty two hilly miles in twenty six hours and had arrived in good order, weapons primed and ready to fight.
KitMaker: 803 posts
Armorama: 793 posts
Posted: Wednesday, March 18, 2015 - 12:36 PM UTC
Thanks Martin, the mix is Tamiya XF-81 and XF-58 with a touch of deck tan to fade it out.
Dan
KitMaker: 679 posts
Armorama: 409 posts
Posted: Wednesday, March 18, 2015 - 01:26 PM UTC
Cheers for that, colourwise pretty much spot on as i remember it.
Marty
KitMaker: 803 posts
Armorama: 793 posts
Posted: Saturday, March 28, 2015 - 06:30 PM UTC
South Carolina, United States
KitMaker: 1,240 posts
Armorama: 1,192 posts
Posted: Saturday, March 28, 2015 - 07:08 PM UTC
Very nicely done mate. Keep up your excellent work and standards.
So many interesting British vehicles worth building.
Looking foreward to you next update.
Keith.
AMPS Member, certified field judge & Always something on the workbench!
KitMaker: 803 posts
Armorama: 793 posts
Posted: Monday, March 30, 2015 - 09:43 PM UTC
