Hi Donald
I would suggest paying a visit to a doctor or hospital just to get yourself checked out. Banging your head can have delayed unintended consequences.
M1A2SEP Comparison Build Tamiya / Dragon
kandahar
KitMaker: 52 posts
Armorama: 52 posts
Posted: Thursday, March 05, 2015 - 04:31 PM UTC
Posted: Thursday, March 05, 2015 - 07:02 PM UTC
Thank you Pawel. Great photo and most timely. Dragon PE part MA1 "vent" is not quite as well illustrated in the kit #3556. Much appreciated!
OldWarloke
KitMaker: 2,663 posts
Armorama: 2,649 posts
Posted: Friday, March 06, 2015 - 01:45 AM UTC
Hi Donald
Thanks for your concern, I was to the emergency room after the fall. I have a concushion and some damage to the nerves in my left arm. My work has slowed as the arm doesn't want to co-operate with me all the time.
I might have some pics. Saturday or sunday.
Donald
cabasner
KitMaker: 1,083 posts
Armorama: 1,014 posts
Posted: Friday, March 06, 2015 - 02:52 AM UTC
Sorry about your fall. As others have noted, please make sure you get yourself looked at! If you're having issues with motion, that, in particular, is something you should not delay in having treated!
That said, I'd like to know which Live Resin sets you got for your tank. I see that the M2 machine gun itself is LRE 35144. However, I'm not sure which set you have for the feed chute and flexible ammunition. I'd really like to duplicate the sets you have. Thank you!
OldWarloke
Posted: Friday, March 06, 2015 - 05:54 AM UTC
The Feed Chutes are a separate set #LVR-35147 you get 4 pieces, they are flexible resin, so you will need super glue to fasten them in place. They cut really easy with a sharp knife. I used thin strips of scrap Photo-etch brass on each end of the run.
Donald
OldWarloke
Posted: Saturday, March 07, 2015 - 12:38 AM UTC
Have some of the Tamiya turret fittings finished.
I used the DEF Models masking on the clear parts, fit is excellent .
Donald
Donald
Ultra_aussie
KitMaker: 197 posts
Armorama: 145 posts
Posted: Saturday, March 07, 2015 - 12:44 AM UTC
Great thread Donald ! I will follow till the end .
OldWarloke
Posted: Saturday, March 07, 2015 - 08:12 PM UTC
And now I present, THE SMOKE GRENADE LAUNCHER ASSEMBLIES
I assembled the DEF Models , Tamiya , & an extra Fron the Dragon kit
I think the DEF Models look the best.
OldWarloke
Posted: Saturday, March 07, 2015 - 08:15 PM UTC
That's it for now.
Donald
pzandt
KitMaker: 68 posts
Armorama: 57 posts
Posted: Saturday, March 07, 2015 - 08:37 PM UTC
Donald:
I'm following your blog with great interest. having just bought the kit, I'm keen to follow your example. I went to the DEF Models website and couldn't find the kit that had the grenade launcher assemblies. Is there a part/kit number for it?
Vodnik
KitMaker: 4,342 posts
Armorama: 3,938 posts
Posted: Saturday, March 07, 2015 - 08:53 PM UTC
They may look good because of the PE mounting brackets, but the angles of tubes are correct only in Dragon launchers. All other 1/35 launchers I saw, including the DEF ones, have too narrow "spread" of tubes. Dragon M250 launchers were designed using the technical and operational manuals of the real things, which among others specify the exact angle of each tube. Note for example that innermost tubes (when launchers are attached to the tank) should fire directly forward (and upward of course - I mean that grenades land exactly in front of the tank). Good luck trying to achieve that with Tamiya or DEF launchers...
EDIT: Sorry, my memory failed me here - the innermost tubes should fire 5 degrees to the side from the direction of tank movement. Still it is angle not achievable with DEF and Tamiya launchers. Full spread of tubes is 50 degrees.
Please keep in mind that the above illustration shows correct angle values, but the drawing itself does not represent the angles correctly.
Vodnik
Posted: Saturday, March 07, 2015 - 09:46 PM UTC
Here is a nice photo of M250s:
Note that the launcher base is lying flat on the ground.
Vodnik
Posted: Saturday, March 07, 2015 - 09:53 PM UTC
By the way, each Dragon "third generation" Abrams kit, i.e. AIM, SEP and SEP V2 (third because, old M1A1 kit was the first generation and M1 Panther II kit was second) includes a pair of extra M250 launchers - a present from me to all modelers
They can be used with other Abrams or e.g. M60 kits
OldWarloke
Posted: Sunday, March 08, 2015 - 05:06 AM UTC
Donald:
Hi Pascal.
The number for the set is DE35006 I don't know if you can get it from their web site.
I purchased it from spruebrothers.com Their number for it is
DEFD35006 M1A2 SET TUSK II Pe. set for the Tamiya kit
Sprue brothers price is $11.99 U.S. Dollars plus shipping.
Hope this helps.
Donald
OldWarloke
Posted: Sunday, March 08, 2015 - 07:23 PM UTC
The smoke units are installed on the Tamiya turret. I had to raise them up a bit to clear the reactive armor mounts.
If I got them wrong, I'm sure one of the experten will let me know.
Donald
pzandt
KitMaker: 68 posts
Armorama: 57 posts
Posted: Sunday, March 08, 2015 - 08:25 PM UTC
Thanks, Donald. Based on your comments about the accuracy, can one combine the DEF mounts with the Dragon launchers?
OldWarloke
Posted: Monday, March 09, 2015 - 12:31 AM UTC
I don't see why not, you wll have to either load the Dragon launchers or drill them out as they have shallow tapered tube openings.
Donald
OldWarloke
Posted: Monday, March 09, 2015 - 05:54 PM UTC
Just finished installing the wheels.
OldWarloke
Posted: Monday, March 09, 2015 - 05:59 PM UTC
These are the track that I'll be using.
The Dragon Track for the Dragon kit. If I remember right I'll have to shorten the track run a link or two.
The Bronco track for the Tamiya kit.
There's a lot of clean up with this one.
Donald
Donald
OldWarloke
Posted: Tuesday, March 10, 2015 - 07:21 PM UTC
I have the track parts all cleaned up. There are 6 parts for each link.
Man this is really going to be a pain in the back side.
I'll have more Pics. when I get some assembly done.
Donald
Donald
pzandt
KitMaker: 68 posts
Armorama: 57 posts
Posted: Tuesday, March 10, 2015 - 07:39 PM UTC
Thank you.
hliu24
KitMaker: 798 posts
Armorama: 797 posts
Posted: Wednesday, March 11, 2015 - 12:24 AM UTC
OldWarloke
Posted: Friday, March 13, 2015 - 10:03 PM UTC
I have the tracks assembled.
This is how I did it, there may be other ways?
The Start.
The Start.
OldWarloke
Posted: Friday, March 13, 2015 - 10:08 PM UTC
You need a total of 75 Track Blocks for the Tamiya Kit.
OldWarloke
Posted: Friday, March 13, 2015 - 10:16 PM UTC
The Tamiya Kit with 75 Blocks.(Bronco Track)
The Tamiya Kit with 76 Blocks (Bronco Track)
The Tamiya Kit with the kit track installed.
Here is the Dragon Kit with Dragons Track at full length.
the same but shortened by 2 links to 76 links
