Building the T-10 M Heavy Tank by Meng
KitMaker: 2,663 posts
Armorama: 2,649 posts
Posted: Wednesday, July 29, 2015 - 05:21 AM UTC
Started my track assembly today but when removing track from jig pins fell out.Must not be doing it right!
Hi Bob,
See Pic. # 98 above. You should trim off the pin sprue attachment while on the jig. You have to snip while pushing in on the track pin. It's all a friction fit. Removing the section from the jig before trimming tends to loosen the pins , and they can come out.
Hope this helps.
Donald
Alabama, United States
KitMaker: 281 posts
Armorama: 273 posts
Posted: Thursday, July 30, 2015 - 02:00 AM UTC
The worst track assembly and jig I have ever seen.I tried the way you suggested and nothing works.The pins will not line up and go where they should.Then when you think you have you take top of jig off and find all pins bent at angles. I am giving up on Meng tack and hope to obtain some of trumpeters T-10 track.Life is to short at 67 for this nonsense.Enough to make me want to give up the hobby of building my kits.
Posted: Thursday, July 30, 2015 - 03:25 AM UTC
I quite agree , maby I didn't explain it quite clearly enough.
The Jig is DIRECTIONAL and can only be used one way.
Here is a Pic,
Note the position of both of the shoes on the Jig.
You have to start at the end with the large pads and work your way up.
If you have the Track Shoes on backwards the pins will not line up with the holes in the shoes and will get bent.
Of course you could always drill out the holes in the track and assemble them like a set of Fruils track (probably mispelled)
Donald
Posted: Thursday, July 30, 2015 - 03:42 AM UTC
I have it finished , I'll have some Pics. this weekend if my internet service holds together.
We had a Huge lightning storm last night and the lightning hit a tree outside my house. I'm lucky it didn't hit the chimney , I was on the way to the toilet when it hit.
If it would have hit the chimney I would be in the great model shop in the sky.
Lucky Donald
#465
Nordrhein-Westfalen, Germany
KitMaker: 398 posts
Armorama: 394 posts
Posted: Thursday, July 30, 2015 - 04:27 PM UTC
Wow, Donald, I'm really glad to hear nothing happend to you (or your house) in that storm. Thanks again for the build log and the invaluable information about the tracks - workable tracks with pins (as opposed to Friuls or clickable tracks) have always been a huge hassle for me (and for lots of others, it seems) - your guide will really be a big help when I start building this kit.
Jerry
Posted: Friday, July 31, 2015 - 12:49 AM UTC
Thanks, I guess I really am lucky.
The Tech man was just here, My modem was partially fried, have a new one now and it's a lot faster.
I'm taking Pics. today, I have to take the wife shopping tomorrow. I'll be posting the Pics. Sunday if nothing else happens.
Lucky Donald
KitMaker: 281 posts
Armorama: 273 posts
Posted: Friday, July 31, 2015 - 03:42 AM UTC
I have been looking for replacement tracks for mine since I am having problems with Mengs pin and link approach.I am thinking of using the plastic tracks from Tamiyas JS-2 and JSU 152 kits.I would like to know if the T-10M and JS series used the same type of track.Will ask that on the Russian forum.
on Mengs track.
KitMaker: 38 posts
Armorama: 36 posts
Posted: Friday, July 31, 2015 - 06:06 AM UTC
on Mengs track.
Bob
I know you're not a fan of these pin type tracks, but I've just used Bronco's similar style tracks for a KV-85......jig and pin arrangement. The approach I found works was put the links into the (lower jig half in your case), and with a small brush apply a drop of white/gator glue then pin one link at a time (get the pins off the sprues).....needle tweezers.....worked well and worst part was clean up links after removing them from sprues.
https://armorama.kitmaker.net/review/8800These are for KV-1S, KV-85, JS etc....not KV-1 as the box states
don't mistake a lack of talent for genius
KitMaker: 281 posts
Armorama: 273 posts
Posted: Friday, July 31, 2015 - 05:40 PM UTC
Thanks but the T-10 used a different type track.Something like was on the JS-4 I have been told.
Akershus, Norway
KitMaker: 1,709 posts
Armorama: 1,581 posts
Posted: Friday, July 31, 2015 - 06:19 PM UTC
Donald, could you please tell me the dimensions of large oil drums? Trumpeter has only small ones and I need to find a suitable replacement as all pics from 1968 show T-10 with large drums as well.
Posted: Friday, July 31, 2015 - 11:57 PM UTC
I just measured the Large Drums in this kit. The size I get is 16.5 mm in Diameter & 23.5 mm in length. I don't know if this is accurate, but this is the size for the Drums in this kit.
Donald
Posted: Friday, July 31, 2015 - 11:58 PM UTC
Now fore the Final Photos.
Posted: Saturday, August 01, 2015 - 12:04 AM UTC
Yes I know, I forgot to paint the Ir. headlight.
Note how the Large Drums fit, the instructions are a bit confusing here.
Posted: Saturday, August 01, 2015 - 12:13 AM UTC
Posted: Saturday, August 01, 2015 - 12:18 AM UTC
The Final 2 Pics.
Final Thoughts.
This kit is really nice, the Track can be a little infuriating at times, but if you follow the method I have shown it should work for you. Hey, if it doesn't you could always glue them together like a set of Dragons Magic Track.
I wouldn't recommend using a solvent based wash for weathering them. The pins are very Delicate and could disolve with a solvent based wash.
Regards.
Donald
KitMaker: 7,219 posts
Armorama: 6,097 posts
Posted: Saturday, August 01, 2015 - 12:46 AM UTC
A strong man stands up for himself; A stronger man stands up for others.
Admit nothing. Deny everything. Make counter-accusations.
He is not Khan who calls himself Khan. Afghan proverb
Akershus, Norway
Posted: Saturday, August 01, 2015 - 01:32 AM UTC
thanks for measurement and congrats on a finished model!
KitMaker: 978 posts
Armorama: 965 posts
Posted: Saturday, August 01, 2015 - 02:08 AM UTC
Donald,
This has been an excellent tutorial on how to deal with this kit; I have the Trumpeter version in my stash but your clear, instructional pictures (and texts) will still prove relevant - not least as Trumpeter provide only smoke canisters - and I will wish to fit fuel drums in due course.
Thanks again for an outstanding review and build log.
Brian
KitMaker: 281 posts
Armorama: 273 posts
Posted: Saturday, August 01, 2015 - 04:40 PM UTC
Great job Donald.Nice pics.
Buenos Aires, Argentina
KitMaker: 1,024 posts
Armorama: 1,013 posts
Posted: Saturday, August 01, 2015 - 07:46 PM UTC
Nice job there!
Now I'm expecting even more anxious to receive mine from Luckymodels....
It's not too much, but it's all we got...
KitMaker: 198 posts
Armorama: 161 posts
Posted: Sunday, August 02, 2015 - 12:38 AM UTC
Awesome job, I cant wait to get started on mine after I clear the current projects on the workbench.
On the workbench
Italeri M32 into M4a1 (76), Trumpeter KV-1 model 1940, Dragon M1A1aim backdated to ODS M1A1hc, Tamiya Tiran 5, Heller Hotchkiss H35.
Posted: Sunday, August 09, 2015 - 11:57 PM UTC
Seine-et-Marne, France
KitMaker: 439 posts
Armorama: 345 posts
Posted: Tuesday, December 29, 2015 - 05:50 PM UTC
Hi Donald,
AWESOME !!!!
I really appreciate your extremely detailed explanations.
I got the kit and will get inspiration from your log :-)
Excellent
Best regards,
Richard
They've send us a message, ... that they can take whatever they want. Well we will send'em a message, that this... this is our land !
