Victoria, Australia
KitMaker: 1,314 posts
Armorama: 1,217 posts
Posted: Tuesday, April 19, 2016 - 04:42 PM UTC
Gray,
Those rear lights are just a thing of pure beauty!!
Not sure if this will help or not just had a look in my wwp books & on the right hand side as in how our cars are, the 55's in the book have two track tensioners, but couldn't get a clear view on the drivers side, but just checked the new takom kit of the 55 AMV & from the instructions looks like yours with only one on that side.
Mike
On the work bench: To many started & nothing finished!!
T55 ( Libyan)
S-Boat
BRDM 2 (Syrian)
BM21-Grad (Iraqi)
Victoria, Australia
Posted: Tuesday, April 19, 2016 - 04:44 PM UTC
Ps but the takom kit is based on a Russian built version, so maybe differences there as well between the polish & Russian versions??
T55 ( Libyan)
S-Boat
BRDM 2 (Syrian)
BM21-Grad (Iraqi)
Auckland, New Zealand
KitMaker: 1,042 posts
Armorama: 871 posts
Posted: Wednesday, April 20, 2016 - 11:38 AM UTC
Thanks Karl.
Mike. I'm not aware of anvehicle built in teh factory as a T55 having twin idler adjustment mechanisms on either side.
T55AM on primeportal -
http://data3.primeportal.net/tanks/thomas_voigt/t-55am2b/images/t-55am2b_026_of_146.jpghttp://data3.primeportal.net/tanks/thomas_voigt/t-55am2b_1/images/t-55am2b_1_19_of_79.jpgMaybe the ones in your book are rebuilt T54s?
Meanwhile, the kit's headlight guard certainly needs to be redone. I used copper wire here bent to shape and soldered together...
Gary
Victoria, Australia
Posted: Wednesday, April 20, 2016 - 01:22 PM UTC
Hi Gary,
That is entirely possible being a rebuild in the book, so much to learn so this thread is great for that!!
I will keep on looking & learning.....& taking notes!!
T55 ( Libyan)
S-Boat
BRDM 2 (Syrian)
BM21-Grad (Iraqi)
Armorama: 871 posts
Posted: Wednesday, April 27, 2016 - 11:12 AM UTC
Thanks Mike.
Not much progress of late as life keeps getting in teh way of modelling
Lights are 'tarted' up to better represent real life examples....
Gary
Arizona, United States
KitMaker: 304 posts
Armorama: 293 posts
Posted: Wednesday, April 27, 2016 - 04:24 PM UTC
Gary,
Your scratch building skills are great. This is just amazing work.
Robert
Armorama: 871 posts
Posted: Thursday, April 28, 2016 - 11:51 AM UTC
Thank you Robert
Headlight unit completed along with wiring...
Gary
Armorama: 871 posts
Posted: Friday, April 29, 2016 - 03:00 AM UTC
Working to assemble the second fender - again constructed from Evergreen styrene. The two verticle strips on the hull sides are temporary to ensure correct alignment when the fender is cemented into place...
Gary
Armorama: 871 posts
Posted: Saturday, April 30, 2016 - 03:03 AM UTC
Fender attached to hull and new styrene bracket supports added. Beware that the Voyager brackets don't appear to be accurate - compared to the Bovington example at least...
Gary
Victoria, Australia
Posted: Saturday, April 30, 2016 - 03:47 AM UTC
Gary,
Looking fantastic as usual, just pure beauty!!
Makes me wish I was back home so I could see it two hours earlier every day!!
Mike
T55 ( Libyan)
S-Boat
BRDM 2 (Syrian)
BM21-Grad (Iraqi)
Armorama: 871 posts
Posted: Saturday, April 30, 2016 - 08:10 AM UTC
Cheers Mike.
Front fender section from Voyager is added. Note that when fitting the underside support bracket (W35), Voyager have it fitted too far back. It should be at the leading edge directly below the hinge...
Onto the rear guard next - parts shown on the bench ready to go above.
Gary
Armorama: 871 posts
Posted: Saturday, April 30, 2016 - 08:55 AM UTC
Rear guard complete....
Gary
Germany
KitMaker: 254 posts
Armorama: 253 posts
Posted: Saturday, April 30, 2016 - 12:28 PM UTC
It is a pure pleasure to watch this build! I follow it closely and the moment my T-55 conversion from legend arrives (the one for the yellow czech VT-55A) I will surely read it another time. Keep on building and posting.
Armorama: 871 posts
Posted: Saturday, April 30, 2016 - 01:14 PM UTC
Thank you Michael. The Legend kit is a fun build but does need a little TLC in places. Hopefully you'll blog it here
Front fender section completed with armour block and convoy lights etc...
Rear convoy lights and wiring have also been added and now time to start on the fuel tanks. The one on the right has been prepped in readiness for detaling...
Gary
Armorama: 871 posts
Posted: Sunday, May 01, 2016 - 11:06 AM UTC
The mounting brackets are made from Aber PE and 10amp fusewire soldered together. The 'threaded rod' will be trimmed down at a later date. The U brackets are attached to the fender supports with heat stretched sprue. Each end of the sprue 'pin' is then flattened with a heated blade to secure it in place. This means the assemblies can be fully articulated to suit when the fuel tanks are fitted...
Gary
Lower Austria, Austria
KitMaker: 633 posts
Armorama: 599 posts
Posted: Sunday, May 01, 2016 - 02:48 PM UTC
Fabulous work with so much detailwork.
I like this very much, it is a stunning model and proof of your scratch building skills.
Walter
Armorama: 871 posts
Posted: Monday, May 02, 2016 - 10:44 AM UTC
Thank you Walter
Fuel cells are detailed using PE from Aber, 5amp fuserwire, lead foil and a styrene bolt head from Meng...
Gary
Armorama: 871 posts
Posted: Tuesday, May 03, 2016 - 11:03 AM UTC
Made a start on the pipework....
Pipes are simply brass rod with the joiners made from brass tube and the hose clamps from the Aber set. I use brass as everything can be easily soldered together.
Gary
Armorama: 871 posts
Posted: Tuesday, May 03, 2016 - 01:37 PM UTC
Remaining pipework WIP....
All dry fitted with hose clamps yet to be added. Note the different layout due to the Enigma not having the 3rd tank fitted towards the front.
Gary
Armorama: 871 posts
Posted: Wednesday, May 04, 2016 - 01:29 PM UTC
A plumbed and secured in place...
Gary
Armorama: 871 posts
Posted: Thursday, May 05, 2016 - 02:58 AM UTC
Aber's toolbox WIP....
Gary
Armorama: 871 posts
Posted: Friday, May 06, 2016 - 05:36 AM UTC
Tool box completed...
Gary
Noord-Holland, Netherlands
KitMaker: 764 posts
Armorama: 742 posts
Posted: Friday, May 06, 2016 - 05:46 AM UTC
Rhode Island, United States
KitMaker: 833 posts
Armorama: 601 posts
Posted: Friday, May 06, 2016 - 06:00 AM UTC
Most impressive work!
----Nothing is "idiot proof" because they will always build a better idiot.------
----Never try to teach a pig to whistle. It wastes your time and it annoys the pig.----
Armorama: 871 posts
Posted: Friday, May 06, 2016 - 10:18 AM UTC
Thank you gentlemen
Bit of a leap forward here. I've decided to go with OMSh tracks on my VT-55 vehicle, so simply pinched the already made drive sprocket and Modelkasten RMSh tracks from that kit...
I have yet to add the 4 plates each side which prevent the track from 'slapping' the underside of the fenders.
Gary
