Gray,
She is certainly shaping up beautifully with all the additions & love how the lights & fuel tanks look!!
Out of curiosity what was the thickness of the styrene you used for the fenders & tubing??
Mike
T55 Enigma
Tanksami
KitMaker: 1,314 posts
Armorama: 1,217 posts
Posted: Friday, May 06, 2016 - 12:26 PM UTC
gastec
KitMaker: 1,042 posts
Armorama: 871 posts
Posted: Saturday, May 07, 2016 - 02:59 AM UTC
Thanks Mike.
I used .010 sheet (.25mm) for the fenders and .060 x .060 (1.5mm) for the strengthening bars.
Made a start on the side armour blocks next. I began by assembling the 2 kit parts and once the cement has fully cured, carefully cut the blocks into seperate units. The open ends are then filled with a piece of styrene, a layer of Tamiya putty added and then they are sanded smooth. WIP shot...
Gary
Gary
gastec
Armorama: 871 posts
Posted: Friday, May 13, 2016 - 03:36 PM UTC
Further progress with the armour blocks. An saw blade is used to roughen up the edges to replicate the weld seams. Mounting brackets are made from .005 styrene and Meng nuts/bolts...
First side dry fitted...
Gary
Gary
gastec
Armorama: 871 posts
Posted: Sunday, May 15, 2016 - 01:22 PM UTC
Driver's hatch needed a lot of work - ended up using two hatches to create a more accurate one...
Hull is now just about completed I think...
Turret next
Gary
Turret next
Gary
Tanksami
Posted: Sunday, May 15, 2016 - 01:52 PM UTC
Gary,
Just gob smacking amazingly beautiful work!!
The side armour blocks look great.
Question what changes did you make to the drivers, hatch, besides the hinge & why??
Mike
Mike
gastec
Armorama: 871 posts
Posted: Sunday, May 15, 2016 - 02:25 PM UTC
Thanks Mike.
The biggest things of note with the hatch are the small flap which needs to be removed and the lip around the edge. Bovington example shows neither of these.
The 'hinge' bracket which bolts to the hatch is thinned down and two small ridges are added using thin styrene along with new attachment bolt heads. I also added the hatch stops to both teh hatch and the hull roof.
Gary
Gary
JimboHUN
KitMaker: 461 posts
Armorama: 443 posts
Posted: Sunday, May 15, 2016 - 02:52 PM UTC
Hats off Gary!
This is some serious sratchbuilding skills.
Adam
Adam
gastec
Armorama: 871 posts
Posted: Monday, May 16, 2016 - 03:38 AM UTC
Thank you Adam.
I've used the MIG resin mantlet cover here so the gun can be depicted in the elevated position. It had to be modified a fair bit though to enable me to add the cover stips on the leading edges as per a Polish built behicle. The upper part of the cover is remade as Tamiya didn't get it quite right...
New support rods etc were added underneath...
Gary
Gary
gastec
Armorama: 871 posts
Posted: Monday, May 16, 2016 - 09:55 AM UTC
Searchlight is made using a mix of kit parts, stryene and Aber PE. Most of the PE is too thin for some parts, hence the scratch built styrene bits...
Conduit is lead wire with one end hollowed out.
Gary
Gary
gastec
Armorama: 871 posts
Posted: Monday, May 16, 2016 - 01:10 PM UTC
Searchlight linkage made using kit parts and Aber PE. Fully articulating at this stage to allow ease of positioning on vehicle..
And fitted...
Gary
And fitted...
Gary
gastec
Armorama: 871 posts
Posted: Tuesday, May 17, 2016 - 04:55 AM UTC
Work continues with the turret. Voyager PE periscopes are fitted - the moulded on kit one in front of the loaders hatch is cut off in favour of a PE one. Missing bullet splash is added by grafting one on removed from a spare Tamiya Tiran 5 turret. Attachments are being added to loaders hatch/MG mount...
Gary
Gary
stef29
KitMaker: 124 posts
Armorama: 102 posts
Posted: Tuesday, May 17, 2016 - 10:20 AM UTC
I am really enjoying following your work Gary, this is inspirational.
gastec
Armorama: 871 posts
Posted: Tuesday, May 17, 2016 - 11:21 AM UTC
Cheers Bill.
Loaders hatch is now complete...
While working on the commander's side, I notioced something I hadn't seen before. A 3rd perisciope facing rearwards - plain to see on the Bovington example. No idea how common this was, but decided to add it anyway. I also removed the bullet splash around the small flap on the hatch as the Bovington vehicle doesn't have one either...
Gary
Gary
gastec
Armorama: 871 posts
Posted: Tuesday, May 17, 2016 - 01:53 PM UTC
Commander's hatch done and awaiting its searchlight...
Gary
Gary
gastec
Armorama: 871 posts
Posted: Tuesday, May 17, 2016 - 03:58 PM UTC
Searchlight on. Just need to add some cabling...
Gary
Gary
edklingon
KitMaker: 194 posts
Armorama: 173 posts
Posted: Tuesday, May 17, 2016 - 04:54 PM UTC
Incredible amount of details here Gary, I'm amazed!
gastec
Armorama: 871 posts
Posted: Wednesday, May 18, 2016 - 04:01 PM UTC
Thank you Edson.
Small details to add to teh turret rear inclding a 12.7mm ammo box and holder...
Ammo box is from Voyager while the exquisite hoder is from Aber. Can be made to work just like the real thing too
Tie down loops are made from fusewire, grab rail is brass rod while MG stowage holder is from Aber...
Ammo box side brackets have yet to be fitted...
DShK is next up. (WIP) Detailing parts are primarily from Aber. I remade most of the recoli system from brass tube and .010 wire for the springs....
Gary
Gary
jvazquez
KitMaker: 857 posts
Armorama: 811 posts
Posted: Wednesday, May 18, 2016 - 06:59 PM UTC
Wow! Superb work!!
gastec
Armorama: 871 posts
Posted: Thursday, May 19, 2016 - 08:48 AM UTC
Thanks James.
DShK is complete....
Gary
Gary
Posted: Friday, May 20, 2016 - 03:20 PM UTC
That DSHK is by far the most impressive I have ever seen- incredible amount of detail. This build, put simply, is just amazing. I keep looking at all the updates and its just brilliant to see such dedication go into every little area.
gastec
Armorama: 871 posts
Posted: Monday, May 23, 2016 - 04:57 AM UTC
Onto to the rear of turret armour block supports. The bulk of the frame is made up of Voyager PE....
Gary
Gary
Thirian24
KitMaker: 2,493 posts
Armorama: 2,344 posts
Posted: Monday, May 23, 2016 - 05:13 AM UTC
That's amazing amazing detail. So inspiring.
Keep up the great work!!
gastec
Armorama: 871 posts
Posted: Monday, May 23, 2016 - 01:32 PM UTC
Thanks Dustin & Karl.
Rear frame is made up by soldering the stowage box support frame to the sides. I used styrene for the main rear beam for ease - also the same dimensions as the fender beams onto which teh armour blocks attach.
The side brackets which are welded onto the turret are remade in styrene sheet rather than using the PE options. This will make it easier to mount the unit onto the turret with styrene cement...
Voyager provide the brass bolts, but I'll probably swap them for styrene ones from Meng as they are slightly too big IMHO and the insides are nuts, rather than bolts.
Gary
Gary
gastec
Armorama: 871 posts
Posted: Tuesday, May 24, 2016 - 01:00 PM UTC
With the bolts replaced with more accurately sized ones courtesy of Meng, the assembly is attached to the turret. Careful alignment is required here so lots of measuring of angles before committing fully to cement. Welds are made using Tamiya epoxy putty...
Gary
Gary
gastec
Armorama: 871 posts
Posted: Thursday, May 26, 2016 - 02:33 PM UTC
Another stowage box. I added the missing ribbing on one side using heat stretched sprue which is flattened on one face before cementing in place. Lid clamps are a mix of Aber PE and 5 amp fusewire with the screw clamps made from two different diameters of brass pipe soldered together....
And fitted in place....
Gary
Gary
