The differences as per Takom:
Adam
Hi,
I am jumping to the front for a while – as said before first I will put together the hull before adding any detail...
The mine plough attachments are incorrect in the instructions, they suggest it as seen on the box art:
They add the short arms to the upper side, and nothing to the lower but this is incorrect. I will depict below the three correct options out from box. Please note that nothing is glued and positioning is approximate only – please use your references.
1) – no attachment points: just fill the gaps marked.
2) – ”early” configuration: add the arms as per the instructions and add 8 attachment points to the lower plate, you will have 4 separately in the box, the other 4 should be cut from the T-55 front plate which is also included in the kit (as a bonus both types are in the box: the square and rounded ones – so if not used you will have spares for two vehicles).
3) – ”late” configuration: use the 4 separate attachment points on the upper hull and use the T-55 lower front plate – either add the special T-54 welding to this piece or remove all attachment points and add them to the T-54 front plate. Also you will need to add the two rods next to the fenders.
That’s all for now, some more work was done but I have no photos yet.
Also news of today that Takom is releasing a corrected T-54B lower hull as currently the kit has the T-55 one which is not correct since the two are not the same. They promise replacement to every buyer, so hats off to Takom! To me it’s too late already...
Adam
My Takom T-54B arrived yesterday. It has the T-55 lower hull. Does anybody know how Takom is going to manage to send the replacement hull to the ones we bought the kit?
Javier
I just ordered Takom's Type-59,so this one of the blogs I will be following closely.Everything is looking great so far.
