Hi Guys,
I had some time to work on the tracks.
Each link requires more or less clean-up, but nothing major. However 13 pieces were broken/deformed out of 193, and 184 are needed per side. That leaves me with -4 track links, however Takom was quick to provide a handful of replacements which should be on its way by now. Alternatively you can use Masterclub resin ones to replace the missing bits as they fit perfectly to the Takom offering (I do not have any extra currently).
As said earlier, I normally use either rubber band or workable track links so this is my very first attempt to glue track links.
I am doing three sections per side, using Tamiya Extra Thin Cement to have some time to align them into position.
First section is from under the first roadwheel to the top of the sprocket, the second is from here to to idler, the third will be a short one to finish the front part. As far as I know the plastic cement might cause some shrinkage so I will allow a few days for drying before adding the last section.
Assembly is easy however the glue dries very quickly (not sure if it is normal or it is just Takom's plastic) so I had issues with the long runs, I did not achieve the look I was looking for, the track is just not as flexible as I was hoping it would be.
See it for yourselves:
Actually after taking the photos I made some small corrections as I have realised that it is relatively easy to remove a link if only a tiny amount of glue was used. But it is too dark now to take pictures.
Adam
