Dragon 35th scale Jagdtiger
KitMaker: 803 posts
Armorama: 793 posts
Posted: Wednesday, July 06, 2016 - 06:16 PM UTC
A bit of pre shading
Dark yellow next
Dan
KitMaker: 4,403 posts
Armorama: 4,078 posts
Posted: Wednesday, July 06, 2016 - 06:42 PM UTC
VERY NICE! Following with much interest!
KitMaker: 803 posts
Armorama: 793 posts
Posted: Wednesday, July 06, 2016 - 08:57 PM UTC
Thank you Dennis,
I've managed to get the base cam colours down for the Ambush scheme, still loads of tweaking to do.
Dan
KitMaker: 2,275 posts
Armorama: 2,233 posts
Posted: Wednesday, July 06, 2016 - 09:07 PM UTC
Nice job. Fun kit to build...I also used the Friul tracks.
KitMaker: 803 posts
Armorama: 793 posts
Posted: Tuesday, September 20, 2016 - 10:51 PM UTC
Indiana, United States
KitMaker: 6,188 posts
Armorama: 5,960 posts
Posted: Tuesday, September 20, 2016 - 11:47 PM UTC
Wow, is THIS amazing or what! I don't know where to start on what I like the most so I'll just say it's very impressive all around.
Jeff
KitMaker: 803 posts
Armorama: 793 posts
Posted: Wednesday, September 21, 2016 - 03:03 AM UTC
KitMaker: 658 posts
Armorama: 629 posts
Posted: Wednesday, September 21, 2016 - 04:54 AM UTC
G'day Dan
Very interesting and great work, particularly as I'm building the same kit (look on the Tank Hunters campaign).
Depending on when your JT entered service, you might like to check references regarding jack blocks and jacks, as I think you will find most, particularly late JTs, didn't have either, or even the brackets.
Regards
Rob
KitMaker: 803 posts
Armorama: 793 posts
Posted: Wednesday, September 21, 2016 - 06:04 AM UTC
Cheers Rob,
I didn't know that buddy so thanks for the info, I'm not building any particular vehicle so I'll probably go ahead and fit the jack block to my build.
I just popped over and took a quick peak at your build, coming along nicely indeed fella, I was unlucky enough to spend some time at Iserlohn during my time in the Army, during the Cold War period it was a British military hospital. I broke my leg on exercise and spent 4 days at the BMH
One pointer for your build buddy , you are aware that kit gun barrel is in recoil and to short? Dragon measured up the JT in the USA which had the gun spiked my the crew, they drained out all the oil from the recuperators and fired it thus rendering useless.
I used a barrel from Armourscale which correct in length and sits right in the mantlet.
Regards
Dan
KitMaker: 803 posts
Armorama: 793 posts
Posted: Wednesday, September 21, 2016 - 03:49 PM UTC
Just test fitted the jack and block to see what it looks like.
Dan
Posted: Wednesday, September 21, 2016 - 04:39 PM UTC
Hi, Dan!
VERY NICE!!!
Happy to see that you didn't paint your towing cables and tools in the way that so many other modellers do- NO warm, sexy, multi-toned Browns with varnished handles on your tools, as if they were lovingly crafted overnight by the magical Teutonic elves working in Opa's Moebelgeschaeft, and your cables are over-sprayed in the same Dunkelgelb as the rest of the vehicle! Quite right! I also like the fact that you didn't "over-weather" your model, either...
I'm a firm believer in "less is more"...
Very nicely done, and a welcome change from the run-of-the-mill AFV that looks like something that's been parachuted into a hundred-foot-deep mud bog, and overloaded with enough rust on it to convey the impression that it's been pickled in a salt water brine for a hundred years!!!
I LIKE it!!!
Posted: Wednesday, September 21, 2016 - 04:47 PM UTC
KitMaker: 730 posts
Armorama: 616 posts
Posted: Wednesday, September 21, 2016 - 07:13 PM UTC
love your built, mine wasn't so good is yours, still needs final touches to get out off hands
KitMaker: 803 posts
Armorama: 793 posts
Posted: Thursday, September 22, 2016 - 12:42 AM UTC
KitMaker: 803 posts
Armorama: 793 posts
Posted: Thursday, September 22, 2016 - 03:28 AM UTC
Whilst waiting for the pigments to dry
I've painted up the MG-42,
The ammo belt is a WIP to get it hanging right.
Cheers for looking
Dan
KitMaker: 730 posts
Armorama: 616 posts
Posted: Thursday, September 22, 2016 - 03:57 AM UTC
What can I say, lovely. Will be following with great interest
KitMaker: 803 posts
Armorama: 793 posts
Posted: Thursday, September 22, 2016 - 01:48 PM UTC
Cheers Bat,
The pigments have fully dried now and are looking good.
It should look good
KitMaker: 658 posts
Armorama: 629 posts
Posted: Thursday, September 22, 2016 - 02:00 PM UTC
Cheers Rob,
G'day Dan
Yes, I was aware of the problem with earlier model kits of the JT, particularly Tamiya's, but I think you'll find that DML have fixed the problem for this kit. I checked drawings, and the length of the barrel after the mantlet should be 108mm, and it is precisely that.
Just a by-the-by - the crews did not like the JT. The barrel was eight metres long, and if the vehicle was driven without the barrel locked in place, the optics and barrel were very soon out of alignment. The solution, of course, was to use the barrel lock while travelling, but it could only be released from outside the vehicle! Bit inconvenient when people are shooting at you!
Regards
Rob
Regards
Rob
KitMaker: 803 posts
Armorama: 793 posts
Posted: Thursday, September 22, 2016 - 09:45 PM UTC
HI Rob
It was a beast of a wagon that's for sure, I did read about the gun and cross country fighting, poor crewman who had to unlatch the gun
So I had to test fit one track just to see.
top tip, mask the wheel axels before paint, other wise they are a real pain to fit
Dan
KitMaker: 803 posts
Armorama: 793 posts
Posted: Thursday, September 22, 2016 - 10:21 PM UTC
Making a start on the track guards,
not fitting all of them but this one is the first.
KitMaker: 803 posts
Armorama: 793 posts
Posted: Thursday, September 22, 2016 - 11:05 PM UTC
And a couple more.
Enjoy
Dan
KitMaker: 803 posts
Armorama: 793 posts
Posted: Friday, September 23, 2016 - 03:21 AM UTC
Oklahoma, United States
KitMaker: 2,493 posts
Armorama: 2,344 posts
Posted: Friday, September 23, 2016 - 03:40 AM UTC
Extremely nice job Dan! Very inspiring
KitMaker: 658 posts
Armorama: 629 posts
Posted: Friday, September 23, 2016 - 05:28 AM UTC
G'day Dan
Yeah, I knew about the wheels problem - same applies to Tigers, King Tigers and Panthers. That's why I have a set of short pieces of plastic tube which I slip over the axles before painting (and a rat tail file to make the holes in the wheels bigger when required).
Any attempt to force the wheels usually breaks the axle concerned!
Regards
Rob
KitMaker: 803 posts
Armorama: 793 posts
Posted: Friday, September 23, 2016 - 06:52 PM UTC
Cheers Roy,
To late buddy, been there, done that
Finished the track guards, both sides now.
Cheers all
Dan
