Short break of two and half years, and time to finish this off. Such a long pause created some problems. There was a little damage to some of the paintwork, and though I had noted that that I used Deck Tan and Desert Yellow, I don't know what the brown was.
One of the brackets on the rear bar armour had also snapped off and disappeared, so a new one was made from card and rod:
I also noticed that the launcher on the right hand side should have a bit of Deck Tan:
That was masked and added, and the turret damage was touched up, and then the launchers were attached:
The lower side armour was added. This went on quite easily, I just drilled out the holes a little to make sure it went all the way in, and made sure the cement made good contact:
The tow rope was also attached, again, fitted well, just a question of removing the paint for the cement:
The bar armour also fitted well, despite my imperfect scratched bracket - the brackets on the rear plate engage with those on the armour between the two pairs of pegs, then it's a question of ensuring it is vertical and sets that way:
So I realise that since the previous post with photos I had done a lot of the pinwashing and filters, and more of that was done. Also here, the upper side armour is now in place. This revealed something that I should have dealt with much earlier, and something for anyone building it to look out for, which is that there are ejector marks on the side that faces in, the tops of which are just visible in some places.
