Thank you Tim and Cheyenne. Thanks for following. I haven't had much time to work on the project lately. This weekend I will work on it for a bit.
Can anyone suggest how to make a steel rolling shutter? I have a couple of ideas but maybe there is a simpler way out there.
Syria dio
zorrolobo
KitMaker: 1,457 posts
Armorama: 1,440 posts
Posted: Tuesday, May 08, 2018 - 11:06 PM UTC
jrutman
KitMaker: 7,941 posts
Armorama: 7,934 posts
Posted: Wednesday, May 09, 2018 - 06:10 PM UTC
If the shutter is going to be closed then just use a piece of plastic card. I would use a scribing tool and cut the horizontal lines in it to the right depth. Clean up the edges and paint.
J
J
Tank1812
KitMaker: 1,112 posts
Armorama: 886 posts
Posted: Wednesday, May 09, 2018 - 06:40 PM UTC
I think a lot depends on the type of steel roller look you want and open or close.
Jerry's idea would work.
A second option is what Nick did. Looks like a sheet of plastic and smaller strips to give the rolled effect.
https://armorama.kitmaker.net/forums/246554&ord=&page=3
A third option is a more corrugated look which this might make your life easier.
https://masterpiecemodels.com/product/35th-the-corr-u-gator/
zorrolobo
Posted: Thursday, May 10, 2018 - 07:05 AM UTC
Thank you Jerry and Ryan. I think I am going to go with a homemade version of the corr-u-gator, and go to the arts and crafts store to get some metal sheets for embossing. I want to get a damaged look on the shutters. Something like this:
Tank1812
Armorama: 886 posts
Posted: Thursday, May 10, 2018 - 04:33 PM UTC
I wouldn't think a homemade version would be too hard to make for thin metal sheets. Don't know if the thin metal can handle the extra wear for battle damage. Might be a case of making the holes first then embossing the sheet. Interested to see how this turns out.
Late find...K+S has premade corrugated sheets. 16134 might be the best option. As HO = 1/87 and O = 1/48.
http://www.ksmetals.com/31.html
zorrolobo
Posted: Thursday, May 10, 2018 - 08:19 PM UTC
Thank you Ryan. lets see how my attempt works out. If it does not, Ksmetals could be an option. Thanks
zorrolobo
Posted: Saturday, May 12, 2018 - 03:42 AM UTC
Ok, here is the result:
Dioramartin
KitMaker: 1,476 posts
Armorama: 1,463 posts
Posted: Saturday, May 12, 2018 - 06:38 PM UTC
Strange coincidences, I’m playing with this kind of metalwork right now too – looks great although I’d just query the holes – assuming they’re entry holes the metal around the hole could a bit more concave? Yours almost look like exit holes…from inside the garage? Whatever, excellent work
zorrolobo
Posted: Saturday, May 12, 2018 - 08:40 PM UTC
Thank you Martin. Actually I did the holes from the "outside" to the "inside".
I primed the shutter and you can see it better. Here are some closeups:
Outside:
Inside:
Outside:
Inside:
zorrolobo
Posted: Monday, May 14, 2018 - 05:58 AM UTC
Did a couple of filters on the inside to give it a more aged look. Added tile to the upper floor, and painted the rolling shutter a base color of dark steel gray/rust brown to do chipping with the next coat of color. Also started building window shutters.
zorrolobo
Posted: Tuesday, May 15, 2018 - 01:14 AM UTC
Going on a trip for a couple of weeks, so this is it till I get back.
zorrolobo
Posted: Monday, June 11, 2018 - 05:56 AM UTC
Picking up where I left:
Used the salt method un the shutter:
Dioramartin
Posted: Tuesday, June 12, 2018 - 12:05 AM UTC
Good to see someone else back in the saddle Marcos, it’s been a lonely ride recently. Great progress, very distressing, but even better that it’s restrained too. Love that door handle – is the key on the other side?
Tim
Tim
jrutman
Posted: Tuesday, June 12, 2018 - 01:24 AM UTC
Ditto what Tim said !
J
J
zorrolobo
Posted: Tuesday, June 12, 2018 - 02:33 AM UTC
Thank you Tim and Jerry. good to be back. Now getting ready for some serious weathering!
zorrolobo
Posted: Sunday, June 17, 2018 - 03:19 PM UTC
zorrolobo
Posted: Sunday, July 08, 2018 - 11:04 AM UTC
Almost done with the interior of upper floor:
Made a slab of hydrocal tinted as concrete ond then added the ceiling and roof colors to make debris:
deathdork
KitMaker: 314 posts
Armorama: 296 posts
KitMaker: 314 posts
Armorama: 296 posts
Posted: Sunday, July 08, 2018 - 05:16 PM UTC
2nd story really impressive!!!
cheyenne
KitMaker: 2,185 posts
Armorama: 1,813 posts
Posted: Sunday, July 08, 2018 - 08:44 PM UTC
Nicely done , I like it !!!
jrutman
Posted: Monday, July 09, 2018 - 01:27 AM UTC
The floor tiles on the damaged upper floor really take it up a notch I think,
J
J
zorrolobo
Posted: Wednesday, July 11, 2018 - 09:43 AM UTC
Thank you Deathdork, Chayenne, and Jerry.
Some more pics:
Added some pices of "broken glass" under window:
Some more pics:
jrutman
Posted: Thursday, July 12, 2018 - 01:25 AM UTC
The glass and magazines are a nice touch.
J
J
zorrolobo
Posted: Friday, July 13, 2018 - 05:13 AM UTC
Thanks J.
Dioramartin
Posted: Monday, July 16, 2018 - 03:20 AM UTC
Very nice flooring & details –I’d suggest the breaks in the floor are a bit too neat though, some of the rubble piled up around them might look better resting in the metal rebar that’s holding it together – & heaps more dust/fragments over everything. Excellent work, I’m sure it hasn’t been easy...& I’m still looking for the key to that door
zorrolobo
Posted: Wednesday, July 18, 2018 - 02:28 AM UTC
Thank you Tim. I still have a lot of work ahead. Much more debris, and haven't even started with pigments. I still have to define how big the base will be, etc. Just finnished an A/C unit. I have been away from home so not much time to work on the dio. And I guess I will have to make a key for that door!
