Hi all,
Not so much progress today, but what little there was is shown below,
Today I have started on the upper hull and, more-or-less, from the outset I have gone off-piste. There are so many small fragile pieces, e.g. lights and guards, that I have decided to add the major components first, along with any smaller items that I feel are unlikely to get broken off during further handling/construction…not sure if this is the best approach, but hopefully I won’t live to regret it,
The front top plate incorporating the driver’s hatch had some very faint ejector pin marks, these may have been hidden by paint at a later stage but I decided to sand them off (see image below).
In Step 8, the instructions have you insert the glacis plate (including fragile headlights etc.) and then add the top plate incorporating the driver’s hatch in Step 10. However, when dry-fitting these elements I was left feeling a tad concerned about how well the glacis plate would marry-up with the sloped bottom hull plate.
Finally, I decided to add the top plate incorporating the driver’s hatch first as its location was well defined. I then glued only the top edge of the glacis plate to it, thus leaving the area of glacis plate between the mudguards dry fitted. This permits the glacis plate to move and will allow me to adjust the glacis when fitting the upper and lower hulls together. I have dry-fitted the top and bottom hulls to each other and this appears to allow me to mate the two front elements together neatly.
I accept that the above might be overkill and that my inexperience is showing, but completely gluing the glacis at this point feels as if there is a risk of misalignment at a later stage,
There is a small gap in between what I presume is an armoured cable that changes direction at the top edge of the glacis and adjacent to the drivers hatch (see image below), this will be filled and sanded.
Not sure if this is an error on my part...probably is,
. Damn! i have also noticed on that image that there is an ejector pin mark to the bottom left of the driver's hatch...i did say they were faint,
I have also begun to construct and fit the various hull stowage boxes (see images below). I found these a tad fiddly, especially the smaller ones, as they are quite flimsy and are each made up from 5 parts (4 sides and 1 lid/top).
Here I find I might have made an error in fixing the larger stowage boxes to the hull already. Having looked at a number of photographs of the real tank the lids of these boxes do not appear to have a joint around the perimeter, i.e. the lid over-sails the sides as opposed to sit within them as occurs with the model parts, so I will need to fill and sand…could get messy,
Shame the parts weren’t designed so that the sides sat beneath the lid as opposed to the lid sitting between the side…hey, ho!
You can see in the image above the gaps between the lower part of the glacis plate and the mudguards where i haven't yet applied glue.
Please feel free to comment on the above notes, particularly if you disagree with my approach in any way, this is all a learning curve for me.
Thanks, and regards,
G
