A13 Mk.I/Cruiser Tank Mk.III
St. Petersburg, Russia
KitMaker: 397 posts
Armorama: 397 posts
Posted: Sunday, March 15, 2020 - 07:00 AM UTC
Well you need something to do when you are stuck at home, quarantined or avoiding Covid, and unable to go out.
I like this idea
Best regards!
Artyom Nikolaev
KitMaker: 397 posts
Armorama: 397 posts
Posted: Tuesday, March 17, 2020 - 07:24 AM UTC
Best regards!
Artyom Nikolaev
KitMaker: 397 posts
Armorama: 397 posts
Posted: Friday, March 27, 2020 - 02:03 AM UTC
Best regards!
Artyom Nikolaev
New South Wales, Australia
KitMaker: 1,476 posts
Armorama: 1,463 posts
Posted: Friday, March 27, 2020 - 10:33 PM UTC
Yes Artyom we all have plenty more time for modelmaking & you’re making good progress here. It’s beginning to look like when it is finished there will be nothing remaining from the original kit! Do you think it would have been easier to completely scratchbuild it?! Be healthy yourself too
KitMaker: 397 posts
Armorama: 397 posts
Posted: Saturday, March 28, 2020 - 01:01 AM UTC
Hi,Tim! Unfortunately you are right. Almost all details were upgraded. Definitely this is the hardest my project by this time.
I think I have no such skills to do all by myself or maybe it's just a psychological problem and I only need a fulcrum.
Best regards!
Artyom Nikolaev
KitMaker: 397 posts
Armorama: 397 posts
Posted: Tuesday, April 21, 2020 - 09:35 PM UTC
Best regards!
Artyom Nikolaev
KitMaker: 3,353 posts
Armorama: 3,121 posts
Posted: Tuesday, April 21, 2020 - 11:25 PM UTC
Sensational Artyom. Almost as if a full scratch build would have been better!
On the Bench:
KitMaker: 397 posts
Armorama: 397 posts
Posted: Wednesday, April 22, 2020 - 06:29 AM UTC
You are too kind Peter! Thank you! Aluminium foil is quite delicate material.
Best regards!
Artyom Nikolaev
KitMaker: 397 posts
Armorama: 397 posts
Posted: Thursday, May 14, 2020 - 06:23 AM UTC
Best regards!
Artyom Nikolaev
KitMaker: 397 posts
Armorama: 397 posts
Posted: Tuesday, May 19, 2020 - 06:39 AM UTC
Best regards!
Artyom Nikolaev
KitMaker: 397 posts
Armorama: 397 posts
Posted: Wednesday, June 03, 2020 - 02:19 AM UTC
Best regards!
Artyom Nikolaev
Posted: Thursday, June 04, 2020 - 12:14 AM UTC
KitMaker: 397 posts
Armorama: 397 posts
Posted: Thursday, June 04, 2020 - 03:28 AM UTC
Hi, Tim! Thank you! I am glad too. I've suggested that it will be easier for me to use putty. I satisfied with this work and it is a realy rare phenomenon
Best regards!
Artyom Nikolaev
Posted: Thursday, June 04, 2020 - 08:26 AM UTC
So sculpting is another of your skills Artyom. They look great.
On the Bench:
KitMaker: 397 posts
Armorama: 397 posts
Posted: Monday, June 08, 2020 - 07:18 AM UTC
Hi,Peter! I wish I could better=)
Best regards!
Artyom Nikolaev
KitMaker: 397 posts
Armorama: 397 posts
Posted: Monday, June 08, 2020 - 07:20 AM UTC
Best regards!
Artyom Nikolaev
KitMaker: 397 posts
Armorama: 397 posts
Posted: Friday, June 19, 2020 - 06:33 AM UTC
Greetings,friends! I've started work I always hated =)) Yes, track links in progress. They consist of two parts. Plastic is hard and doesn't glue well. I work with great patience. In comparison tracks for Renault R-35 from Modelkasten. Renault is really smaller than A13 but tracks has similar dimensions. After all of that I will continue to make details on upper hull.
Best regards!
Artyom Nikolaev
Posted: Friday, June 19, 2020 - 11:58 PM UTC
Top-quality hinges on the top plate Artyom, even if they don’t work they look like they should! And the tracks seem to fit perfectly round the drive wheel, that’s one less problem. What’s the error on the headlight box? Looking forward to seeing more hull progress
KitMaker: 397 posts
Armorama: 397 posts
Posted: Monday, June 22, 2020 - 02:50 AM UTC
Hello,Tim! Good to hear you! It took time to do all well (hinges and the tracks initial work) Headlight has incorrect angles and too narrow. My variant is better but also has mistake. It seem to me that angle between lower and upper plates is wrong.
Best regards!
Artyom Nikolaev
Posted: Monday, June 22, 2020 - 07:07 AM UTC
It looks fantastic Artyom. Really stand out details.
On the Bench:
KitMaker: 397 posts
Armorama: 397 posts
Posted: Tuesday, June 23, 2020 - 12:21 AM UTC
Hi,Peter! Thank you. Much more details ahead. I hope you will like it.
Best regards!
Artyom Nikolaev
KitMaker: 397 posts
Armorama: 397 posts
Posted: Wednesday, July 08, 2020 - 01:03 AM UTC
Best regards!
Artyom Nikolaev
Posted: Wednesday, July 08, 2020 - 08:08 AM UTC
The hang on the tracks is really well done Artyom.They may have been a trial to deal with, but I believe it is better than the alternative- other modellers reported the kit vinyl tracks are too tight to fit!
The v shaped guide horns would have meant moulding them all separate to the pad for attachment later, which by the sounds of it, would be a problem in itself. Also it was not done much back then. The open guide horn is also probably why Fruil never made a set for the A13.
I can appreciate that drilling them out, then trimming with a knife was not an option for you... you would get old before you got to the last link.
Then again, I once drilled and trimmed out the early Dragon Panther track guide horns - my friends still make fun of me for that.
On the Bench:
KitMaker: 397 posts
Armorama: 397 posts
Posted: Wednesday, July 08, 2020 - 05:45 PM UTC
Hi Peter! I really satisfied with the result. No matter how many efforts had been done. And I perfectly understand why there are no such tracks in metall and resin. You are right - too difficult,too small and the main thing I think - small demand.
Maybe 5-10 years ago I've tried to drill out all tracks. But when you grow up you getting lazy.
But 10 years ago T-35 tracks made me a legend in Russia. I driller every Friulmodel track and put there split pin from 0,15mm wire.
Friends still remember that like yours.
Best regards!
Artyom Nikolaev
Posted: Wednesday, July 08, 2020 - 06:02 PM UTC
Now that is impressive - crazy, but impressive
On the Bench:
