Over the past few days I have been steadily working on this project and I had to make some more decisions; should I go for the original picture or should I open up the vehicle and load out the interior. After contemplating for a long while, I went for the first option, since this build is in the Build a photo-campaign and I already have taken some liberties with the figure and the not covering up of the TOW sight and battery.
So again I stuck with the plan.
Analyzing the picture I concluded that this was a hastily and sloppily overpainted vehicle, meaning it would have the standard 3-tone camouflage underneath. It also looks as if 3 bands have been deliberately left unpainted. Why I do not know. Furthermore the vehicle appears to be on guard duty and lacks the overloading with gear. It actually is bare, except for 1 backpack. Even rear shows loose hanging straps.
So first things first. I used Tamiya paints predominantly. NATO green XF-67 + Olive drab XF-62 (because I ran out of NATO green, so had to cheat), NATO brown XF-68 and NATO black XF-69 (which is more of a dark gray instead of flat black!) as a base, followed by tape and hairspray, over which I applied a mix of Desert yellow XF-59 and Dark yellow XF-60 1:1 mix. This mix in the end turned out to be too dark. I should have used Buff XF-57 instead of Desert yellow.
I ended up spraying to much brown, though.
And now for the scary part; I am doing the hairspray technique for the first time! And I do rub too hard on some spots, making the plastic come through! It took a while to figure out that I had to let the water soak in a little, before removing the paint and hairspray.
But in the end I am actually rather pleased with the result.
After this was done I set it away to thoroughly dry, before I toned down the harsh contrasts with a very diluted wash of Vallejo Dark sand. I then assembled the rest of the vehicle and coninued weathering. However in my eagerness to get the build done, I forgot to add a few parts BEFORE I started painting and weathering... such as the hatchet and the mirrors. The battery and backpack were added and at long last also an antenna, made by stretched sprue. The end is drawing near on this one!
