Working that M-10 with armor top plates into a city Ambush Diorama. Using the same technique describe in my article, first I
1. lay-out a plywood base and drilled random depth 1/4 wide holes every 1-1.5 inches.
2. Pouring Durhams Water Putty, mixed with a little white glue and tinted dark gray with black acrylic paint, on top and shaking to release any air bubbles, I cover the base and then pour on extra rubble I have stored ina mason jar. (extra from old projects and freshly made from Druham.)
NOTE: I always sprinkle on some dry Durhams to the still wet base. it tends to collect in a great dirt/gradually pebble effect in the area were larger rubble does not cover the wet water putty.
3. Dry for 24 hours and shake off the excess (save extra for later)
4. I add various washes of Midnight blue, Black, Burnt Umber and Forest Green to give depth and texture to my rubble.
5. Dry brushing begins
5. Adding detail - floor joist, flooring, debris, wire, trash, etc.
I am about 70% done with this one... more debris, rubble, some crew members (1-2 Visible), camo Net and personal gear /Tools on the back of the M-10 need to be done.
Comments appreciated.
Neill
