You guys don't have to destroy an expensive model to learn these techniques. Any primed flat surface will work and if you must paint on a vehicle? Why not a cheap plastic toy tank or car etc... ? Just a thought?
BH
Painting AFV's, enroll and volunteers please
jonnysocko
KitMaker: 192 posts
Posted: Saturday, April 01, 2006 - 07:36 PM UTC
WingTzun
KitMaker: 853 posts
Armorama: 515 posts
Posted: Saturday, April 01, 2006 - 07:42 PM UTC
Personally, a separate class, or inclusion of, dealing with resin or photoetch would be a great bonus. Especially for me!! (okay, being a bit selfish)
Be selfish Mike, I'm with you on that all the way!
Posted: Saturday, April 01, 2006 - 10:57 PM UTC
Right, Time to get organised...
I need some idea as to when people like to kick off.
Hawkeye (Eth) will do the first class, which will start with the basics. Preparing the model for painting, and the use of primer, if and when needed. He has two models, one plastic OOB and one with Resin and PE, to show where these extra parts would need extra attention. It will NOT be neccessary for the class to have two models aswel, either type will be sufficient.
In this case I would suggest to use a simple model, as the next class will then carry on with a basic one colour coat. So you can use this model for subsequent classes. AS has been stated before, the basics are much the same for base coats, so if you use a German AFV and the next class is done with an Allied AFV, that should not be a problem.
To give us all time to get ready and gather all the neccessary bits and pieces, I think starting in about three weeks would be o.k., between around Sunday April 23.
I'll compile a list of items that are needed, and will post more details as and when there are any..
Henk
Henk
Javlin813
KitMaker: 336 posts
Armorama: 191 posts
Posted: Monday, April 03, 2006 - 04:56 AM UTC
I'd like to join - I need all the class I can get!
Scott
Scott
Posted: Monday, April 03, 2006 - 08:00 AM UTC
Then you're welcome Scott, there's no limit on class size here.. the more the better.
Henk
Henk
slynch1701
KitMaker: 340 posts
Armorama: 290 posts
Posted: Monday, April 03, 2006 - 08:20 AM UTC
the 23rd sounds fine to me. The only hang up for some maybe that the AMPS nationals are the week after and will be getting ready for that.
Sean
Sean
JimF
KitMaker: 717 posts
Armorama: 621 posts
Posted: Monday, April 03, 2006 - 09:39 AM UTC
The 23rd works for me.
BillyBishop
KitMaker: 347 posts
Armorama: 167 posts
Posted: Monday, April 03, 2006 - 08:00 PM UTC
Cool, I am curious if a small scale tank would be ok for this class?
I have both a Sherman and a hetzer already built in braille scale but both need painting...
Cheers, Michael
Cheers, Michael
Clanky44
KitMaker: 1,901 posts
Armorama: 553 posts
Posted: Monday, April 03, 2006 - 10:06 PM UTC
Hi Michael,
I would suggest a 35th scale or 48th scale model for these classes. 72nd scale brings on additional challenges to painting that I consider to be for the experienced modeller. A very good command of your airbrush is needed to make one of these little models stand out. With this said, I'm currently building the Revell Germany ATF Dingo 1 in 72nd as a foundation to what will hopefully be a hard-edge camo class using silly putty as a masking agent. (This technique has recently been highlighted in the April 2006 copy of Fine Scale Modeler).... but in the end, if you feel confident enough, then by all means, use your 72nd model as a base for the lessons.
Frank
Frank
spongya
KitMaker: 2,365 posts
Armorama: 1,709 posts
Posted: Monday, April 03, 2006 - 11:07 PM UTC
'd like to join,too. I'll be out of town from mid April to mid May, though.
Violetrock
KitMaker: 831 posts
Armorama: 791 posts
Posted: Monday, April 03, 2006 - 11:43 PM UTC
Hi,
count me in, too.
I´d like to suggest another date to start.
It´s a little selfish, I know, but I would be so happy to join, but let me explain:
May 1st would be better for me, because I have to pass some audits until May 3rd. To catch up two days would be easier than more than a week.
Second, over here in Europe we have Easter holidays, that means, some of us are on vacation, stores are closed, etc.
May 1st would give us a little more time to prepare.
Third, the one who begins with the first "lesson" should announce the vehicle he uses for demonstration ASAP. I expect that some of us need to pick it up and build it first before starting the class.
Thomas
count me in, too.
Thomas
FNG
KitMaker: 92 posts
Armorama: 54 posts
Posted: Sunday, April 09, 2006 - 11:48 AM UTC
Sounds good! I'm in. April 23rd. Looking forward to it. J.C.
TheLosers
KitMaker: 47 posts
Armorama: 28 posts
Posted: Tuesday, June 19, 2007 - 05:11 AM UTC
As a padawan learner....i know its a bit late......count me in....for the next class.....if theres any......or PM me...
Galwitz
KitMaker: 498 posts
Armorama: 406 posts
Posted: Tuesday, June 19, 2007 - 07:27 AM UTC
The initial class is either deeply in progress or over already, I assume. Is there any archive available? Or some other post-class material for late-comers to dig thru...?
Thanks
Thanks
paxtonm
KitMaker: 89 posts
Armorama: 61 posts
Posted: Tuesday, June 19, 2007 - 07:34 AM UTC
Please count me in!!
psilocyber
KitMaker: 78 posts
Armorama: 49 posts
Posted: Tuesday, June 19, 2007 - 08:37 AM UTC
fantastic:) sign me up,,i could need some teaching..
spongya
Posted: Tuesday, June 19, 2007 - 09:35 AM UTC
So where do we stand now?
I'm lost...
