Armor/AFV: Modern - USA
Stryker M1127 RV & M1126 ICV w/ SLAT - WIP
18Bravo
KitMaker: 7,219 posts
Armorama: 6,097 posts
Posted: Tuesday, March 23, 2010 - 05:48 AM UTC
I noticed some planks of wood for whatever purpose....as well as..those metal v-bars attached.. (can't remember what they're called) Believe it's for fencing barb wire..
They're pickets, and looking at the fourth photo, they look great. How did you do them? I know how I would, but since the real things are not exactly at right angles, I never really fooled with doing them.
jon_a_its
KitMaker: 1,336 posts
Armorama: 1,137 posts
Posted: Tuesday, March 23, 2010 - 06:08 AM UTC
Any particular brands for the weak acid you can recommend?
Some Brits swear by Acetic Acid, commonly called chip-shop Vinegar,
WArning side-effect of making you hungry!
Wine vinegar or Balsamic Vinegar won't do, though.
Same caveat as Coke, don't leave it in too long!
A club member bought himself an Ultrasonic cleaning bath thingy...
Jaw dropping work by the way...
martyncrowther
KitMaker: 1,548 posts
Armorama: 1,407 posts
Posted: Tuesday, March 23, 2010 - 06:33 AM UTC
Brilliant work Nick! Love all the scratch work.
Anirudharun
KitMaker: 597 posts
Armorama: 530 posts
Posted: Tuesday, March 23, 2010 - 08:13 AM UTC
Brilliant work Nick, the stretcher looks excellent. The lead foil net is just what I need to make for my Dumvee.
Looking forward to your next update!
Boggie
Newfoundland, Canada
KitMaker: 1,370 posts
Armorama: 1,331 posts
Posted: Tuesday, March 23, 2010 - 09:41 AM UTC
Nick, beautiful scratching as we have all come to expect from you. Hope you are making molds?
Regards
Bill
AngryDog
Singapore / 新加坡
KitMaker: 1,114 posts
Armorama: 900 posts
Posted: Tuesday, March 23, 2010 - 06:29 PM UTC
Thanks for the comments guys!
With .005" stryrene sheet, srcib and fold... I will post a How-To over here soon as I can.
Jon... I went with Mr Muscle cleaner...found it's the best since it removes and degreases.
Anirudh...make sure you roll out the lead foil to as thin as possible..
Regards
William, thank you...I'm glad to live up to expectations!
No molds yet, but yes to the Masters..which are consolidating for later.
Right now it's about "what I can afford" so I have my $ focused in limited run kits for my BIG E Hanger Decks https://armorama.kitmaker.net/forums/150497#1258624
AngryDog
Singapore / 新加坡
Armorama: 900 posts
Posted: Monday, May 10, 2010 - 02:16 AM UTC
Some pics again.. Now in weathering process and it's tough since the main coat is just boring green...
SO much for my 1-piece Slat option..had to remove because alignment was off just a tad.
scratch the wheel since legend's tire was empty..
AngryDog
Singapore / 新加坡
Armorama: 900 posts
Posted: Friday, September 17, 2010 - 08:21 AM UTC
Like the humvees..finished this some time back...
The Rhino is positionable with the help of 2 custom pins. I have to admit the Slat was a B*itch to come together..more so because it's difficult to handle the beasty in the process..
I have another 2 RVs to build, one a partial scratch for a customer and another is Milo's newer kit from RealModel. Both will have Interiors from BlackDog and Dtoys...
jwest21
KitMaker: 3,374 posts
Armorama: 3,126 posts
Posted: Friday, September 17, 2010 - 08:49 AM UTC
Holy CRAP is that nice!!!!!!!
Burik
KitMaker: 1,437 posts
Armorama: 1,303 posts
Posted: Friday, September 17, 2010 - 10:50 AM UTC
Beautiful. This is an inspiration to get back to mine.
Boggie
Posted: Friday, September 17, 2010 - 11:19 AM UTC
One of the nicest I've seen, a real inspiration.
Regards
Bill
Citizinsane
KitMaker: 463 posts
Armorama: 450 posts
Posted: Saturday, September 18, 2010 - 12:27 AM UTC
Nick,
great stryker you've got there!
is the front CIP part of any of the pe sets you used, or is it scratch built? I can't recall having seen that detail on any other stryker so far... keep up the good work.
Cheers, Max
AngryDog
Singapore / 新加坡
Armorama: 900 posts
Posted: Saturday, September 18, 2010 - 03:00 AM UTC
Thanks guys for the kind words.. I'll be posting another WIP on the other 2 RVs next month or so.
BTW, the heading of this present blog includes an ICV version, that one had to be canceled til later.
Max, the "CIP" you're referring to is what I believe is actually a protective thermal blanket...from of IEDs...if memory serves..
It's scratch built from 0.3 styrene sheet. Quite common on the Stryker pics I've seen.
Had a little time today so here's some more pics and info :
1st off, the Sinsengumi camo decals, I used these decals on EVERY camo gear for both my Stryker and Humvees.
A good gloss coat with Future floor polish, Microscale setting solution and a hair dryer will do the job to get them in place, takes some patience and a little skill with water-damp cotton buds, , but I think it's worth it.
A note though, I have all the modern US sets, some of the colors are "off", pretty obvious in the digital camos and in the "sand" color for the older desert scheme...however, with some weathering, you won't notice it immediately.
For my future builds I may very well create my own digital camos...see how it goes.
Rhino anti-IED, if you're careful and do some planning, you can locate it in the various positions, with the help of 2 "pins". I made these with styrene rod and glued the "pin-attachment end" whateverthehellit'scalled that came as a photoetch bit in Realmodel's convrsion.
I opened up the 2 hole in the bar for easy slotting of the pins. I also used 0.5mm black wire from Tuner model Factory (detailing for cars) I flattened and twisted the wire a bit with a steel ruler as it seems more like the real thing.
Vision Blocks, I used Metallic Decoration tape (thin and easy-peel,cut and stick!) from a $2 shop here, only 7 colors : red, purple,blue,greens,gold and silver. I only used red,purple and blue, seemed OK.
Weathering, exclusively Vallejo range, various tones made with ightening and darkening the base color, as well as mixing with Olive drab and Reflective green. Oil washes, MIG pigments brushed on, used with Vallejo matt varnish, and for streaks,etc painted on using with water. Dry brushing done with grey or / and gunmetal mixed with base color..
The scratches on the gun shield,etc was done with a fine tip brush and grey color...
BLACKWATER
Yunnan, China / 简体
KitMaker: 449 posts
Armorama: 441 posts
Posted: Saturday, September 18, 2010 - 03:10 AM UTC
非常了不起的制作,无与伦比。向您学习了。
A very remarkable production, unparalleled. You learned.
Anirudharun
KitMaker: 597 posts
Armorama: 530 posts
Posted: Saturday, September 18, 2010 - 03:24 AM UTC
Once again you've produced a masterpiece. The details are awesome.
If you do a Stryker in Afghanistan you won't need to add slat armour!
Citizinsane
KitMaker: 463 posts
Armorama: 450 posts
Posted: Saturday, September 18, 2010 - 03:44 AM UTC
Hey Nick,
according to Robert Burik it is a CIP, but that's just some kind of thermal cover anyway
think I forgot 'bout half a sentence, I was referring to other models lacking that detail. that what makes your build stand out
Cheers, Max
AngryDog
Singapore / 新加坡
Armorama: 900 posts
Posted: Saturday, September 18, 2010 - 06:10 AM UTC
Blackwater, 欢迎到论坛
I saw your scratch built Achzarit ..Very nice.
I built the one from Legend Productions http://picasaweb.google.com/AngryDogProductions.Nick/IsraeliArmorAchzarit#
Anirudh, Are you refering to the new armor packaged Strykers?
Thanks for that Max... I thought otherwise. The CIP is an easy scratch btw.
Anirudharun
KitMaker: 597 posts
Armorama: 530 posts
Posted: Saturday, September 18, 2010 - 08:34 AM UTC
Er... I'm not sure what they're called, but I have seen the occasional photo of Strykers operating with Blast panels and some armour packages, but no slat. I believe Sam Dwyer is building one, and may have more photos.
Hope this helps
flugwuzzi
Lower Austria, Austria
KitMaker: 633 posts
Armorama: 599 posts
Posted: Saturday, September 18, 2010 - 09:58 PM UTC
Nick, your project comes reallly great.
Learned a lot from your descriptions - especially for soldering pe parts. Also your approach to deal with dacals for the camo-stowage is inspiring.
Thanks for posting and keep on your great work.
Walter
BLACKWATER
Yunnan, China / 简体
KitMaker: 449 posts
Armorama: 441 posts
Posted: Sunday, September 19, 2010 - 03:01 AM UTC
谢谢Nick
我做的Achzarit还有很多的错误和瑕疵,不值一提。
还有您的作品正好为我提供了很好的参考。
Thank you Nick
I do Achzarit there are many mistakes and flaws, not worth mentioning.
Your work there just for me to provide a good reference。
AngryDog
Singapore / 新加坡
Armorama: 900 posts
Posted: Monday, September 20, 2010 - 01:25 AM UTC
Thanks Anirudh, I'll pm Sam...Would love to build one without Slat.
Walter, glad to be of service.. One change I will make is to replace the photoetch bars for styrene ones from Evergreen. Soldering them flat and straight makes all the difference on how the whole Slat package lines up in the end.
Blackwater, none the less your Achzarit build attempt is inspiring, I hope to see more of your work here in the forum.
无欠你的Achzarit建立试图鼓舞人心的,我希望能看到更多的论坛在这里你的工作.
sam_dwyer
Victoria, Australia
KitMaker: 294 posts
Armorama: 291 posts
Posted: Monday, September 20, 2010 - 01:39 AM UTC
Hi Nick,
I do have some shots of Strykers in Afghanistan without the full slat armour package - shoot me an email and i'll pass them on
Sam
AngryDog
Singapore / 新加坡
Armorama: 900 posts
Posted: Monday, September 20, 2010 - 02:01 AM UTC
Hi Sam, glad to know you're watching my blog...pm sent
HILBERT
Zuid-Holland, Netherlands
KitMaker: 4,808 posts
Armorama: 1,069 posts
Posted: Monday, September 20, 2010 - 02:20 AM UTC
That's more PE I ever can imagine! Nicely done!
