Hello Forum,
Here are some early shots of my newest project, the mighty Pershing. The model will be built mostly OOB with some refinements here and there.
The build will be featured in a future issue of SCALE MILITARY MODELLER INTERNATIONAL.
www.sampublications.com
OK let's get started...1st up, a nice head on shot.
Visible are the new snap clasps(?) I added to the bow MG...the kit had them molded on but, I wanted them a little larger and more defined.
Next one, another overall shot....note: the turret from barrel tip to back is nearly the entire length of a Sherman hull!
Last one, upper Turret....replacemant handles where made with a "grab Handeler" tool, further the Spot light was capped off and the Hatch hinge was replaced with plastic rod.
Thanks
Ryan
Constructive Feedback
Orange Box Pershing (T26e3)
The3rdPlacer
KitMaker: 430 posts
Armorama: 407 posts
KitMaker: 430 posts
Armorama: 407 posts
Posted: Monday, September 07, 2009 - 02:47 AM UTC
The3rdPlacer
KitMaker: 430 posts
Armorama: 407 posts
KitMaker: 430 posts
Armorama: 407 posts
Posted: Sunday, September 13, 2009 - 11:14 AM UTC
Hello All,
The turret is 95% finished, with some simple joint filling here and there left to do (aside from the texturing). I wanted to shoot a few before I textured the turret and covered up all of my extra work.
The MG pedestal was replaced with one included in the Academy US MG set, it was simply better detailed than the one in the box. The real chore of the entire build has been the part clean up.... ahh if we could just slap them together with out cleaning mold seam lines.
On to the pics...
*Edit* Better Shots!
Thanks Ryan
On to the pics...
Thanks Ryan
The3rdPlacer
KitMaker: 430 posts
Armorama: 407 posts
KitMaker: 430 posts
Armorama: 407 posts
Posted: Sunday, September 13, 2009 - 11:31 AM UTC
I decided to model the missing dust cover assembly on the mantlet and the tiny clasps that hold it down...there was billion of those clasps to add, well not really, only 52!
The clasps where punched out of palstic sheet with a Reheat Punch, and the strip assembly was built from Evergreen strip. The radius strip was made by winding it around a paintbrush handle then secured little by little with Tenex. The clasps where dipped in a puddle of Testors liquid glue then dropped in place using a sharp Xacto blade.
Tamiya primer was brushed into all joints and gaps, then sanded smooth to blend into the surface of the model.
The spare tracks on the side of the turret had deep ejector pin marks that I filled with a styrene disk I punched with the reheat set followed up with a small amount of Tamiya putty.
*edit* Better shots...
Thanks
Ryan
Thanks
Ryan
The3rdPlacer
KitMaker: 430 posts
Armorama: 407 posts
KitMaker: 430 posts
Armorama: 407 posts
Posted: Sunday, September 13, 2009 - 11:59 AM UTC
Welds were added to the joints seen in the pic below with Tamiya putty shaped with a flat tooth pick, then a rough cast texture was added to the exhaust created with Tamiya primer applied with a old brush.
The Kit came with out the tow cable, bit with the brackets moled in as raised rectangles.
Before I clipped them off, I drilled into the blocks to help me remember the location. I'll scratch some new brackets as well as the tow cable.
Ryan
Ryan
Posted: Sunday, September 13, 2009 - 12:56 PM UTC
Ryan I just posted up a number of ref pics of the M26 at Bovington on KC amps, they may be of use to you.
The3rdPlacer
KitMaker: 430 posts
Armorama: 407 posts
KitMaker: 430 posts
Armorama: 407 posts
Posted: Sunday, September 13, 2009 - 01:18 PM UTC
Thanks Darren,
I'll check em' out, I love that site...mucho inspiration!
Ryan
Ryan
210cav
KitMaker: 6,149 posts
Armorama: 4,573 posts
Posted: Sunday, September 13, 2009 - 01:19 PM UTC
Ryan- outstanding work! Keep it up.
DJ
DJ
msteenstra
Missouri, United States
KitMaker: 32 posts
Armorama: 31 posts
KitMaker: 32 posts
Armorama: 31 posts
Posted: Sunday, September 13, 2009 - 02:44 PM UTC
Hello Ryan
The Pershing is looking great!!!!
I plan to watch your build as it progresses.
Michael
Michael
The3rdPlacer
KitMaker: 430 posts
Armorama: 407 posts
KitMaker: 430 posts
Armorama: 407 posts
Posted: Sunday, September 13, 2009 - 02:53 PM UTC
Thanks DJ, and welcome aboard Mike!
Thanks for looking.
Ryan
Thanks for looking.
Ryan
russamotto
Utah, United States
KitMaker: 3,389 posts
Armorama: 2,054 posts
Posted: Sunday, September 13, 2009 - 02:55 PM UTC
I like all the small details. Great work.
Grizzly
Arizona, United States
KitMaker: 347 posts
Armorama: 223 posts
KitMaker: 347 posts
Armorama: 223 posts
Posted: Monday, September 14, 2009 - 02:12 AM UTC
Very nice work!! I too will follow this closely as I have just recently purchased this kit too.
skyhawk
KitMaker: 1,095 posts
Armorama: 743 posts
Armorama: 743 posts
Posted: Monday, September 14, 2009 - 02:26 AM UTC
Damn! your additional detail to the turret really looks good. Guess you dont need the square stock from me now?
Cant wait to see this in the flesh.
Andy
Andy
The3rdPlacer
KitMaker: 430 posts
Armorama: 407 posts
KitMaker: 430 posts
Armorama: 407 posts
Posted: Monday, September 14, 2009 - 03:43 AM UTC
Thanks guys,
Thomas good luck, it has some rough edges but will hammer out into a good looking kit.
No Andy, I broke down and bought a couple of packs of strip to detail it out....I'll bring it to the meeting Tuesday.
Ryan
Ryan
The3rdPlacer
KitMaker: 430 posts
Armorama: 407 posts
KitMaker: 430 posts
Armorama: 407 posts
Posted: Wednesday, September 23, 2009 - 04:02 PM UTC
Update time, more progress tonite.
Earlier I clipped of the the ends of the shackle pins, I've replaced the end of each with a punched styrene disk. I'll replicate the handle at the end of the pin later after I texture the Hull.
The periscope guards were cleaned up and attached, but they need further clean up once they are dry. Way easier to clean them up mounted to the model than trying to hold them in your hand to clean them up.
Also shown is a nice close up of the styrene strip I notched into the nose to fill the gap present. Tamiya tape and putty replicated the metal lip in this area as shown.
The rear of the Hull is coming along, as with the front I replaced the shackle pin ends and went ahead and added the handles since I'm not going to texture the rear as much as the front. Nice close ups of the added welds also.
The travel lock was added as well as the hitch, the later shown in the stowed postion to the left of the lock. I left the travel lock loose as I have seen pics of it free swinging over terrain, when locked it would be tight to the rear plate.
Thanks
Ryan
Thanks
Ryan
The3rdPlacer
KitMaker: 430 posts
Armorama: 407 posts
KitMaker: 430 posts
Armorama: 407 posts
Posted: Sunday, September 27, 2009 - 01:16 PM UTC
Nice update tonite, I finished the turret and hull texturing. I used the mind numbing combo of my dwindling supply of Tamiya putty and Testors cement mixed into a stucco like paste.
Applied with a old brush it sure looks the part. I'll lightly sand it tomorrow to knock down some of the high spots. The front shackle retainer was also added this evening after the texture was applied.
And the turret...
Ryan
And the turret...
Ryan
The3rdPlacer
KitMaker: 430 posts
Armorama: 407 posts
KitMaker: 430 posts
Armorama: 407 posts
Posted: Sunday, September 27, 2009 - 01:31 PM UTC
The rear transmission covers were textured and I scratchbuilt the missing oil filler ports on the bottom inboard side of these units. A white punched disk finishes off the modification.
The multi piece Academy MG set is being used instead of the kits 50' cal, as seen in the pics, it has great detail missing from the kit item. The ammo box even includes it's retainer to hold it tight to the tray that the box rests in.
Some headway is being made on the indivdual track links...these ain't no Majic Track set! Each link must be clipped and cleaned, Iv'e about got (1) side finished.
(Note: The Korean War version option in the kit has the single length, flexible DS track NOT the individual ones, they are only used for the WWII version which I'm building)
Plenty of ugly ejector pins marks will need filling as well.
The last item for tonight is the sheet of Archer casting numbers I'm going to use to add a few missing details to the model, first time using these so it will be fun to see how they work out.
Ryan
Ryan
Removed by original poster on 09/28/09 - 00:58:47 (GMT).
Posted: Sunday, September 27, 2009 - 01:57 PM UTC
Nice work so far Ryan. I am looking forward to seeing your finished product. Don't forget if there are any pictures you need I may be able to help.
The3rdPlacer
KitMaker: 430 posts
Armorama: 407 posts
KitMaker: 430 posts
Armorama: 407 posts
Posted: Sunday, September 27, 2009 - 02:47 PM UTC
Thanks Darren,
I did check out your pics....that display vehical seems to be the real thing (T26) not some Korean War M26 repop.
Ryan
Ryan
Posted: Monday, September 28, 2009 - 01:36 AM UTC
It is my belief it was most likely a vehicle on trials with us Brits.
skyhawk
Armorama: 743 posts
Armorama: 743 posts
Posted: Monday, September 28, 2009 - 04:13 AM UTC
Damn ryan, that texture is Serria Hotel. Nice work, cant wait to see it in person!
The3rdPlacer
KitMaker: 430 posts
Armorama: 407 posts
KitMaker: 430 posts
Armorama: 407 posts
Posted: Monday, September 28, 2009 - 01:15 PM UTC
Andy,
Not sure what "Serria Hotel" means, but I guess you like it.
Hopefully by the time you see it in person I'll have paint on it....you know deadlines!!
Ryan
Ryan
skyhawk
Armorama: 743 posts
Armorama: 743 posts
Posted: Tuesday, September 29, 2009 - 02:50 AM UTC
Andy,
Pheonetic Alphebet for "S" "H", or "S**t Hot"
The3rdPlacer
KitMaker: 430 posts
Armorama: 407 posts
KitMaker: 430 posts
Armorama: 407 posts
Posted: Saturday, October 03, 2009 - 02:21 PM UTC
Update city tonight!
This evening I fitted the Archer casting numbers, wow what a product, you can really go to town with these sets. I applied representations of the actual numbers...one could research the specific numbers If so inclined. The set I have was researched for Sherman casting numbers so I cut these up here and there for variety.
The sand shields are about 90% done, I had trouble getting a smooth fit and ended up sanding of some of the molded on bolt heads. A miniture punch was used to replace the missing bolt heads and while I was at that I just sliced off the rest and replaced them too.
The fit at the rear skirt was a little long, I'll have to trim these up before attaching them to the hull.
Ryan
Ryan
The3rdPlacer
KitMaker: 430 posts
Armorama: 407 posts
KitMaker: 430 posts
Armorama: 407 posts
Posted: Saturday, October 03, 2009 - 02:46 PM UTC
Hold up, not done yet!
The most time consuming exercise of today was at the rear hull. I as reported earlier in the post, Dragon chose to mold the tow cable brackets as simple blocks on the back of the hull....and not even represent the cable itself! One wonders why some things are chosen to be excluded on production kits, when thay are (in this case) really part of the characture of the Pershing.
OK off the 1/35th scale soap box, and back to the build. The brackets are simple "L" shaped units, I figured I could scratch them out of .005 brass sheet. Once the dimensions were transfered to the brass they were cut out wth shears. I used the Etchmate to true up the sides and fold them into shape.
The new brackets were secured with liquid cement first then spot glued with super glue. Texture was added to the rear plate to tie everything together.
The nylon cable and white metal tow ends were supplied by "Skyhawk", thanks Andy! Using reference photos I wound the cable around my brackets just like the prototype.
Super glue soaked, blue painters tape and a punched disk represent the collar attaching the cable end to the hull. Also visible are some more black casting numbers.
It was a lot of work but I'm glad the cable and brackets are now on the model!
Ryan
Ryan
