Hello
@Biggrip74, the 1/35th FT-17 looks great, I guess you'll be using it as a "benchmark" for the standard of finish you are aiming for with your current smaller build. The KV-8 tracks are a bit uneven on these PST kits, I built one of their KV-1s a few years back, I know what you mean. You just need to tidy some of the edges with a file to get a good look to them
@naimbrain - thanks for the tip on removing tiny pieces, beats repairing or scratching replacement parts
@Firefly74 - the Vickers is looking very tasty.
& if you are thinking of getting a BA-64 I wouldnt try to dissuade you. As ACE kits go, this is one of the better, needs a little filler on hull joins and for a couple of sink marks on the hull roof, and at the rear, & a bit of sanding to fit some parts. The detail is almost non existent on the axle leaf springs, but they are not much seen anyway. I'll buy another to make the alternative 'rail' version
@tread_geek - looks like you are well on the road of "turning a pigs ear into a silk purse" . I have the MW 1/72nd SU-76i kit, moulded in injected plastic, and the cast detail is as indistinct as your resin one, plus it has fit & accuracy issues with the hull and parts provided in the kit... looking forward to seeing how yours turns out when all done, I'm sure mine will be pretty awful, if I ever get the masochistic urge to build it
@tatbaqui - looks like the postman treats your mail the way mine does here ! Boxes arrive squashed and/or wet due to what looks like being a prolonged rainy season here. Good luck with the build
here is an update on my build
I attached the rail wheels front and rear, but they stick out too far, as in first picture below
I found another picture of this vehicle in the book "'Soviet Tanks and Combat Vehicles of World War Two' by James Grandsen and Steven Zaloga. It shows no rear mudguard on the other side, and no tools, and as the other photos show, no headlamps, or turret MG.
I trimmed the front and rear rail supports, they are much closer to the rubber wheels as per the two bottom pictures below,this one is now finished the build stage. Turret needs to be affixed to its base, so it sits square and even, and the whole model witha fine file, and smooth some edges & imperfections a bit.
And also need to wait for 'the big wet' to end before I'm prepared to paint
