How about some IJN AA weapons in 1/350 scale? I know some already exist in PE and turned brass, but they tend to be over-engineered, and totally impossible for my old eyes. 13 mm MG's, and 25 mm in single, double, and triple mounts would be welcome. Fine Molds made some easy-to-assemble and good-looking examples, but they're hard to find (except on eBay), and a 3D print will look even better than them.
Looking for ideas for what to 3D Print
Biggles2
Quebec, Canada
KitMaker: 7,600 posts
Armorama: 6,110 posts
Posted: Thursday, May 11, 2017 - 08:05 PM UTC
MikeyBugs95
KitMaker: 2,210 posts
Armorama: 1,712 posts
Posted: Friday, May 19, 2017 - 12:18 AM UTC
Hmmmmmmmmmmmm...without having to go through the other 34 pages of this thread, I'm gonna step out there and suggest that you give the T-34, T-55, T-62 and T-72 road wheels a beat up/chipped/gouged to the rubber look, a shot!
Wouldn't it be cheaper to use resin or plastic parts and just take a sharp xacto knife or a Dremel to it? Road wheels tend to cost quite a lot.
3D Model Parts makes the single, double and triple 25mm gun in 1/700 and you could email them to ask if they can scale them up to 1/350. I can try the 13mm guns. Do you have any resources for them available?
MikeyBugs95
Posted: Monday, May 22, 2017 - 08:19 AM UTC
Does anyone have any dimensions for the TA-312 field telephone?
And I realized that the LVT(A)-5 support rollers weren't showing up in the shop. This is because I needed to edit them to make them printable. They've now been edited and are being reuploaded.
Posted: Monday, May 22, 2017 - 05:47 PM UTC
Mike,
I found dimensions of 12 x 7 x 4 for the actual phone w/o the carrying case on the TA312.
jjcadenhead
KitMaker: 32 posts
Armorama: 10 posts
KitMaker: 32 posts
Armorama: 10 posts
Posted: Monday, May 22, 2017 - 06:46 PM UTC
Mike did some custom work for me. He was fantastic. I highly recommend him.
john
john
MikeyBugs95
Posted: Thursday, May 25, 2017 - 02:41 PM UTC
So far, no work has been done in a week. But I am going back through the store to check out the model prices to see what can be done. The good news is that many models now have a lower price. All the VIC models have a significantly lower price. The Abrams M256 gun barrel has been lowered by more than half. The RIWP is now $20 cheaper and the cans/bottles sets are also now less expensive. I'll go thru as see if I can lower the price on some models further. I'll also have pictures of the Abrams gun barrel coming soon.
vettejack
KitMaker: 1,277 posts
Armorama: 1,254 posts
Posted: Thursday, May 25, 2017 - 05:56 PM UTC
Quoted TextHmmmmmmmmmmmm...without having to go through the other 34 pages of this thread, I'm gonna step out there and suggest that you give the T-34, T-55, T-62 and T-72 road wheels a beat up/chipped/gouged to the rubber look, a shot!
Wouldn't it be cheaper to use resin or plastic parts and just take a sharp xacto knife or a Dremel to it? Road wheels tend to cost quite a lot.Quoted TextHow about some IJN AA weapons in 1/350 scale? I know some already exist in PE and turned brass, but they tend to be over-engineered, and totally impossible for my old eyes. 13 mm MG's, and 25 mm in single, double, and triple mounts would be welcome. Fine Molds made some easy-to-assemble and good-looking examples, but they're hard to find (except on eBay), and a 3D print will look even better than them.
Well damn... ...no road wheels for me!
Posted: Thursday, May 25, 2017 - 08:13 PM UTC
Mike,
Yes! There are some references here also for the phone...
http://radionerds.com/images/b/be/TM_11-5805-201-12.pdf
http://radionerds.com/index.php/TA-312~PT
MikeyBugs95
Posted: Friday, May 26, 2017 - 06:48 AM UTC
Thank you for the measurements, they should help greatly. I also updated the LVT roller supports and the Chameleon CREW devices to better reflect the new pricing changes. I've gotten the supports down to less than $10 and the Chameleons are down to less than $15. I sprued these parts so they are now one single part. Nearly every model in the shop has now gone down in price. Even the (very) expensive NM-116 tracks. These went from $91 down to $60. The QF 183mm L4 gun barrel was over $150 and is now just over $50. Still expensive. But now more reasonable than before. The RIwP has also gone down by nearly $16 in FXD.
The various trash cans are also now available in the Strong and Flexible and Strong and Flexible Polished materials. These provide a similar quality to Frosted Detail plastics (at least for these models) at a much lower cost. There's also a single square can in case you don't want a set of 4.
If you want to check out the 183mm gun barrel, you can do so here:
https://www.shapeways.com/product/272567AUZ/1-35-qf-183mm-l4-gun-barrel
Posted: Tuesday, May 30, 2017 - 04:36 AM UTC
The LVT(A)5 support rollers arrived and the level of detail is achieved is amazing. There is no way I could have accomplished this with styrene or resin relying on my skills.
However, there is a slight issue. Essentially this is two sets for the port side of the LVT. The sand/mud guards are in the same place on all four pieces. To make a set for the starboard side, the guard need be positioned on the opposite side.
I attempted to portray what I mean with some rudimentary photoshop skills. The photos of the pieces are set on an LVT I am currently working but shows well how superior the detail of 3D Printed rollers are compared to the kit rendition.
Amazing detail!!
Amazing detail!!
Posted: Tuesday, May 30, 2017 - 05:45 AM UTC
Michael, I know this is asking a lot, but is there any way you can redesign the Chameleon with a removable front? I'd like to be able to hollow out the window opening and replace it with some thin acetate.
Eric
Eric
MikeyBugs95
Posted: Wednesday, May 31, 2017 - 01:39 AM UTC
Sorry bout that Dan. I uploaded a correction set of 2 with the starboard side rollers. I also fixed the model and reuploaded it. It's fixed now.
Eric, what do you mean? The entire front face? The area where the window on the Chameleon would go is hollow.
Posted: Wednesday, May 31, 2017 - 01:47 AM UTC
Michael, thanks. I'll order a set.
Eric
Eric
Johnathan123
KitMaker: 50 posts
Armorama: 50 posts
KitMaker: 50 posts
Armorama: 50 posts
Posted: Wednesday, May 31, 2017 - 02:39 AM UTC
My requests:
1) Syrian Sarab III anti-missile defense for T-62 ect.
2) 2S3 tank barrel
3) Type 62 tank barrel for Trumpeter kit
4) 120mm wine bottles and WWI accessories to go with those Verlinden
figures and Takom tanks
5) 1/35 Japanese antiaircraft gun for Japanese trucks/tanks
2) 2S3 tank barrel
MikeyBugs95
Posted: Wednesday, May 31, 2017 - 11:56 AM UTC
Do you have any references or drawings for the Sarab III, the gun barrels, and the IJN guns?
Photo of the M-ATV radio rack:
Posted: Wednesday, May 31, 2017 - 06:25 PM UTC
Cool beans! Ordered the correction as well as couple extra sets.
Would it possible to scale these down to 1/72? I can provide the wheel width/diameter to include as it would be silly to keep it separate in that small a scale (IMHO).
Also, I attempted to order the slave cable ends. However, the 1/35 option is not available from the drop down.
MikeyBugs95
Posted: Wednesday, May 31, 2017 - 10:44 PM UTC
Sure I can scale it down. I'd need to thicken the walls and lose some detail but it can be done. And I fixed the issue with the cable ends. I had hid the 1/35 version because I had to fix something but forgot to unhide it.
Posted: Thursday, June 01, 2017 - 04:06 AM UTC
Cool beans!
Totally understand the necessary loss of detail when reducing the scale. Willing to bet it will still come out better than the detail offered on the kit’s rendering of (old style) support rollers. But as you can tell from the previous pics, the old and new rollers are significantly different and the 3D-Printed parts will be extremely helpful, even in 1/72.
I took measurements directly from the kit wheels. The wheel is 0.0705-inches wide (and centered in the brackets) and 0.1405-inches in diameter.
MikeyBugs95
Posted: Friday, June 02, 2017 - 11:48 AM UTC
Finished the M-ATV radio rack. Surprisingly, Shapeways says this is mostly printable.
This is based on the Panda PE. I measured it directly off the frets.
MikeyBugs95
Posted: Saturday, June 03, 2017 - 05:18 AM UTC
For the return rollers, I think something is off. When I modeled the wheel it was much thinner than the space in the supports. It also looks wider than what my program is showing me.
Posted: Saturday, June 03, 2017 - 06:48 PM UTC
They are tiny in 1/72 and perhaps even undersized. It appears as though the mounting brackets are molded a bit over sized in attempt to make up the difference. Although, not well/wide enough as there shouldn’t be that much “wiggle” room between the wheel and brackets.
MikeyBugs95
Posted: Friday, June 09, 2017 - 03:23 AM UTC
Thanks for the info. I'll have to go ahead and guesstimate it then. Also, for some reason, there are more models that are hidden for some reason. I'm going through and unhiding them now. I've also updated the VRC-12 sets to better reflect the pricing changes. There's a set that includes the VIC-1 intercom and a set that doesn't. I am also removing the "Assorted Soda Bottles" set product number 035. It's the set with the misshapen bottles that are larger on the bottom. The M-ATV radio is also now available in case anyone wants to buy it.
Just letting you guys know, check back into the shop; there are a lot of products that have been hidden for some reason.
skyshark
KitMaker: 703 posts
Armorama: 499 posts
KitMaker: 703 posts
Armorama: 499 posts
Posted: Friday, June 09, 2017 - 11:13 PM UTC
How about 1/72 Modern US aircraft pilots.
MikeyBugs95
Posted: Saturday, June 10, 2017 - 12:19 AM UTC
I can't do figures. Beyond my skill level and program abilities right now.
MikeyBugs95
Posted: Tuesday, June 13, 2017 - 06:08 AM UTC
My requests:
4) 120mm wine bottles and WWI accessories to go with those Verlinden figures and Takom tanks
120mm wine bottles are done and are up on the site. It's a set of 16 assorted wine bottles. 4 each of 4 different style bottles.
And the 1/72 return roller supports are also being uploaded.
