KitMaker: 264 posts
Armorama: 263 posts
Posted: Sunday, February 17, 2008 - 12:37 PM UTC
KitMaker: 1,158 posts
Armorama: 950 posts
Posted: Sunday, February 17, 2008 - 05:30 PM UTC
While you are on the wheels, I believe the center hubs of those you painted green would still be sand. Take a look at the spare roadwheel, only what you see on the spare would be green when mounted on the hub, which would remain the basic tank color.
Manitoba, Canada
KitMaker: 1,021 posts
Armorama: 805 posts
Posted: Monday, February 18, 2008 - 11:08 AM UTC
Thomas is correct about the wheels. I found some pictures that might help illustrate his point.
A closer look at the spare wheel still mounted on the turret.
And the spare wheel in use on the same tank.
And a couple more shots of spare wheels on tanks.
If you want to be really accurate paint a ring of silver (where the bolts are) and then paint the hub sand. I think the picture below shows it best.
With my Abrams I tried to paint the silver ring but it was a really tricky area to get at. Especially with all those bolts, so I didn't bother. I just painted the sand part which is easy to do.
And here's a good shot of what the clear part looks like.
Note the rust in the very center of the wheel hub. It isn't all clear. Maybe paint the inside of the clear part with a really dark grey or Tamiya smoke with a drop of brown. Heck experiment and see what works.
I hope this helps. Keep going yufkey. She keeps getting better and better.
-Matt
It seemed she viewed guys on the same level as potatoes.
-Kyon
Manitoba, Canada
Armorama: 805 posts
Posted: Monday, February 18, 2008 - 12:48 PM UTC
Me again. Well you know how I typed that I had tried and failed at trying to paint the ring of silver. Well I figured I'd try one more time and I think it turned out ok. Good enough that it wasn't a disaster anyway. Here's my attempt. I used a 10/0 brush to paint the area in between the bolts.
It was tricky since the wheels are already attached to the model but it can be done. I practiced on a couple of wheels from my M1A2 kit first before potentially ruining my "good" wheels. Of course if I really screwed up I could've just repainted the whole wheel sand.
Anyway sorry for hijacking your blog. The stowage turned out quite good. Oh and if you want to help blend in the chips you could spray to whole model with a very thin coat of sand. Like the base colour. This would act like a filter. It's effects are very subtle. Not like a layer of dust. It should be basically a clear coat with only one or two drops of paint. Obviously I would recommend trying this out on a spare kit first.
I'm really looking forward to seeing yours all done. It's one of the nicest Abrams I've seen.
-Matt
-Kyon
Singapore / 新加坡
KitMaker: 517 posts
Armorama: 382 posts
Posted: Monday, February 18, 2008 - 09:59 PM UTC
Very nice work you've got there.
Lead, follow, or get out of the way.
KitMaker: 264 posts
Armorama: 263 posts
Posted: Wednesday, February 20, 2008 - 07:53 AM UTC
Manitoba, Canada
Armorama: 805 posts
Posted: Friday, February 22, 2008 - 11:00 AM UTC
Working on the wheel hubs. Dullcoat. MIG filters. That's what I'm doing today!
-Matt
-Kyon
KitMaker: 264 posts
Armorama: 263 posts
Posted: Monday, February 25, 2008 - 08:23 AM UTC
KitMaker: 240 posts
Armorama: 233 posts
Posted: Monday, February 25, 2008 - 10:09 AM UTC
This is looking really nice. I have a DML M1A2 SEP in the stash and I'm tempted by your build to dig that out next...
Ian
Newbury Scale Model Club -- http://www.newburyscalemodelclub.org.uk/
NewMod 2013 -- http://www.newmod.co.uk/
KitMaker: 1,558 posts
Armorama: 1,159 posts
Posted: Monday, February 25, 2008 - 01:45 PM UTC
I like it a lot, Yufkey! Great job!
Singapore / 新加坡
KitMaker: 517 posts
Armorama: 382 posts
Posted: Monday, February 25, 2008 - 04:33 PM UTC
This tempts me to do an Abrams...
Manitoba, Canada
Armorama: 805 posts
Posted: Monday, February 25, 2008 - 08:58 PM UTC
Fantastic job on the weathering. It's easy to screw up (as I did the other night and now have to fix
) but yours looks spot on. The exhaust staining really caught my eye. The stowage looks super. And I think the chips look better now too.
Keep going Yufkey. Almost there!!
-Matt
-Kyon
Removed by original poster on 02/26/08 - 11:37:07 (GMT).
KitMaker: 264 posts
Armorama: 263 posts
Posted: Monday, February 25, 2008 - 11:36 PM UTC
Thanks everyone, I used the different colored rust oils from Mig to create the exhaust stain. Then I went back over it with some black pastel chalk
Hawaii, United States
KitMaker: 69 posts
Armorama: 58 posts
Posted: Tuesday, February 26, 2008 - 08:49 AM UTC
Awesome!!!
Warszawa, Poland
KitMaker: 4,342 posts
Armorama: 3,938 posts
Posted: Tuesday, February 26, 2008 - 10:23 AM UTC
Nice job! Congrats!
I wonder if you could still make one small correction? There is one error in your model and I'm sorry to admit that it is my mistake, not yours... Well, actually it's a mistake of the DML person who prepared instructions, but I missed it (and several other errors...) when I was checking them, so I apologize for it! Anyway, the error is in placement of rear exhaust grilles - you attached them as indicated in instructions, but it is unfortunately wrong. The widest one should be on the left side of the tank and the slightly narrower one should be in the center. The one in the center should "fit" inside the exhaust deflector flange when you look at the tank from the rear, not stick to the sides as it does in your model. I don't know if it is possible to swap these two parts on the real tank - maybe it is, but standard position should be like I described, not like instructions show. It is relatively small error, but maybe you can still correct it?
Pawel
Pawel "Vodnik" Krupowicz
Professional Certified Rivet Counter.
KitMaker: 264 posts
Armorama: 263 posts
Posted: Thursday, February 28, 2008 - 08:13 AM UTC
Manitoba, Canada
Armorama: 805 posts
Posted: Thursday, February 28, 2008 - 10:22 AM UTC
The low angle shot "from the curb" is my favorite so far. You keep adding detail after detail. I thought you would have been done a while ago but you keep adding more. I'm sure you must be having as much fun with this model as I am. The replacement wheels are great too. The silver is a tough area to paint and it isn't easy getting it to look right but you nailed it.
-Matt
-Kyon
Posted: Thursday, February 28, 2008 - 02:23 PM UTC
Way to go, Yufkey! It looks great!
My favorite view so far is the top view, but the curbside view is a close second.
I really like the way the exhaust deflector came out. Very realistic.
Connecticut, United States
KitMaker: 1,165 posts
Armorama: 1,105 posts
Posted: Friday, February 29, 2008 - 08:06 AM UTC
Very nice job Lufkey. I really like your process and your photos are spectacular. Superbly done and, nice weathering job too.
On da bench
Dragon Tiger I Early
Takom T-55A
Three Takom Mark IV's
KitMaker: 251 posts
Armorama: 232 posts
Posted: Friday, February 29, 2008 - 10:34 AM UTC
KitMaker: 264 posts
Armorama: 263 posts
Posted: Friday, March 07, 2008 - 08:32 AM UTC
Manitoba, Canada
Armorama: 805 posts
Posted: Friday, March 07, 2008 - 10:05 AM UTC
Damn that looks sweet Yufkey!
It looks like you have been having as much fun with the wheels as me. I did the same thing. Tried using a wash with enamels only to ruin the wheel and repaint it. They look perfect now. The clear hub caps look the part too.
So other then adding the two large antennas what do you have left to do? I can't wait to see it all done. Looks like we might finish our tanks at almost the same time. Long live the mighty Abrams.
-Matt
-Kyon
Warszawa, Poland
Posted: Friday, March 07, 2008 - 10:23 AM UTC
Not so large! Currently used antennas on M1s are in fact relatively short and thin.
Pawel
Manitoba, Canada
Armorama: 805 posts
Posted: Friday, March 07, 2008 - 11:34 AM UTC
You're right Pawel. The correct length is 8 feet in real life and about 2 and 3/4 inches in 1/35 scale. At least that is what I have been told. That's the measurement I went with and it looks right to me.
-Matt
-Kyon
