Ok guys, i wrote some time ago that i would make an update in a day or so, apparantly the *or so* won. I admit, i am working every day on the dio but i am a bit lazy to do updates, don't know why,
While i am already some hundred work hours ahead i am showing you some pictures about the mount of the roof truss, a small SBS of sort.
The height of the roof is determinated mosty visually by comparing photos and getting a pleasant look. So as seen on this pic i am simply finding the right height by playing with two sticks.
The height and the first lenth fixed , i am building the first beams. All is done with those sticks from firecrackers. (sorry for some inappropriate english here, those terms are not in my normal use)
From her on i let speak the pictures
As the roof is to be seen from the inside i am doing real planks all around, Balsa wood, 1 mm, cut in long stripes, as from the inside you will not be able to see where the planks would stop (always nailed on th beams) and from the outside it will be tiled anyway.
As the dormers would also be partially destroyed i needed to build some a bit like the real ones.
I build three dormer windows out of plasticcard, one of them without with frame and window separted as the would brake off. The forth one desintegreted in the blast.
For now that's a base to work with as i need to see how this should be looking when i am about to tile (or not) this part.
The small front dormers are not going to be detroyed so i am doing the structure with plasticcard in which i glued some bals on the inside.
I am going to start the tiling tomorrow.
Meanwhile, with the help of Bradley oi finished 80 % of a Sherman ( no pics, it's a Sherman with some PE and pics are blurry). I also am doing a extensively detaied destroyed interior.
Pics are coming one of this days - or so
Hope you like the little tutorial
Claude
