Campaign Info
Post Progress Here!!
What If
matt
KitMaker: 5,957 posts
Armorama: 2,956 posts
Posted: Wednesday, June 10, 2009 - 11:34 PM UTC
Sudzonic
KitMaker: 2,096 posts
Armorama: 1,983 posts
Posted: Wednesday, June 10, 2009 - 11:45 PM UTC
Hay all and we are go for the what if campaign can't wait to see what you lot come up with.
casualmodeler
KitMaker: 702 posts
Armorama: 665 posts
Posted: Sunday, June 14, 2009 - 06:36 AM UTC
Hi all!
Seems I have the honour being first to post.
Here´s E-25 so far: I added front extra-armor to lower front hull using styrene and boltheads from the other, rear upper hull plate. Extra track links on front are gonna be some additional etxra-armor too.
Here´s the rear. No radical changes, I´m gonna use those Voyager PE parts for tools, which I can assemble....
View from above. I had difficulties to deside, which roof part to use but I think this one it´s gonna be. Track links on roof are most likely another extra-armor for hull. Location is not final.
All comments are welcome.
PantherF
KitMaker: 6,188 posts
Armorama: 5,960 posts
Posted: Sunday, June 14, 2009 - 07:01 AM UTC
Wow! You did all that in 14 days?
casualmodeler
KitMaker: 702 posts
Armorama: 665 posts
Posted: Sunday, June 14, 2009 - 07:11 AM UTC
Wow! You did all that in 14 days?![]()
Yep! Can´t believe it my self too.
To be honest, there´s not much scratchbuild at all, just some selfmade handles. Tracks caused the most of pain for me...
gcdavidson
KitMaker: 1,698 posts
Armorama: 1,563 posts
Posted: Sunday, June 14, 2009 - 10:53 AM UTC
BOBCAT II, RCAF Regiment.
Well, this one is actually done, since I thought we started about 2 months back! Here's what it began life as, an Italeri LAV 8x8 cut doen to a 6x6 hull.
SteveReid
KitMaker: 212 posts
Armorama: 159 posts
Posted: Sunday, June 14, 2009 - 02:33 PM UTC
Kimmo-casualmodeler-
E-25 looks good! I like the supplemental armor on the lower front hull- I just think you should carry it up onto the upper front as well.
And I would use the MG turret on the roof as well....
But Hey! If the fit of both roof panels is good you could paint/weather both and interchange them whenever you like.
Good to see some stuff getting posted on this!
Greame -stormfront-
OK you owned up to your mistake- now lets see the progress! Start on the 6X6 hull looks promising.
Steve
Greame -stormfront-
Steve
Kastanova
KitMaker: 150 posts
Armorama: 135 posts
Posted: Sunday, June 14, 2009 - 03:12 PM UTC
Here the E10, Sturmgrenadierwagen ausf B, armed with a belt fed 20mm flak 38 on a battery powere inverted mount. ive filled the vison block as its imposible to see frough it with the suspension iterior arm covers installed. also i have replaced the kits return rollers with dragon panzer IV ones and hve moved their supports higher soit can lower without getting stuck.
I have stared to fashion out seat from the covers and have placed the divers seat in postion. next to will be the drivers vison block,controls and flak 38 firing controls.
Cheers mat
Cheers mat
Nito74
KitMaker: 5,386 posts
Armorama: 4,727 posts
Posted: Sunday, June 14, 2009 - 10:34 PM UTC
Progress on the E100:
- wheels build and painted.
- Hull details done
- suspension done.
- Started working on the turret.
I'll use a JagdTiger 12,8 metal gun barel for this one
Will try to add some details, some clear parts from the spare boxes might work for the vision ports and also, since this is a "What if" situation, add some Leopard smoke grenade lauchers in the process..
- Hull details done
- suspension done.
ppawlak1
KitMaker: 1,973 posts
Armorama: 1,843 posts
Posted: Sunday, June 14, 2009 - 10:57 PM UTC
The "What if?" WWII 1948 Centurion is started - no pics yet
Lower Hull completed with the wheels - it needs a coat of paint now.
Upper Hull 90 % completed.
New tracks ordered (AFV) after I melted the 70's era Tamiya Vinyl tracks when I took to them with a hair dryer after priming
. Lol ...They're not really melted, they're just REALLY warped !!
I have the 120 mm thermal wrapped cheiftain barrel ready for dry fitting, although I may use a LionMarc Chally 2 Barrel instead.
"Konigstiger" and E-100 killer anyone ??
I'll probably add the Cheiftain IR equipment to the turret, and perhaps the commanders cupola if I feel the need to carve up the Centurion that way.....I'll think about that one.
casualmodeler
KitMaker: 702 posts
Armorama: 665 posts
Posted: Monday, June 15, 2009 - 01:13 AM UTC
Steve
Thanks, Steve.
You know, I spent two days wondering and looking at the E-25 with same idea you said and which roof panel to use.
John_O
KitMaker: 569 posts
Armorama: 322 posts
Posted: Monday, June 15, 2009 - 06:13 AM UTC
Those who want can follow my build log of the E-100 (according to Panzer Tracts - or at least as close as my abilities allow me to):
https://armorama.kitmaker.net/modules.php?op=modload&name=SquawkBox&file=index&req=forums/140482&page=1#1178461
As soon as I've something to look at I'll post it here too. And when I get bored or stuck with the E-100 I might just start working on my E-25 Kügelblitz.
John
John
gcdavidson
Posted: Monday, June 15, 2009 - 08:28 AM UTC
In addition to the 6x6 hull chop, an Oto turret was added and fitted with a range-only radar and M-61 cannon. Ammo feed chute made from apoxie sculpt. 3 x Starstreak missiles are stowed externally on a firing platform that pivots, rotates, and elevates. The bottom image shows an empty tray in the transport / convoy force protection mode. This was made poseable using a series of press fit poly caps. Maple Leaf Models Michelin XML tires were added. The rest was scratchbuilt.
SteveReid
KitMaker: 212 posts
Armorama: 159 posts
Posted: Monday, June 15, 2009 - 11:58 AM UTC
Thanks, Steve.
You know, I spent two days wondering and looking at the E-25 with same idea you said and which roof panel to use.![]()
But I started to hesitate, if more additional armour would cause lack of power for tank. Well. let´s see what I come up to.
Kimmo- even in reality- the late war German armor was up-armored beyond the engines capabilities. This is "What-If" man- GO WILD!
Matthew- Nice looking APC! As I was looking at it I was thinking how cool that would look with the bridge treadways the Germans used to carry on their Hanomags.
Greame- I love that! You have inspired & raised the bar at the same time! Very, very, much in the same vein as what I am working on- but I can tell already yours will be better. Nice!
If this is what this campaign looks like after 14 days- This is going to be fun to watch.
Steve
VenomOrca
KitMaker: 209 posts
Armorama: 169 posts
Posted: Monday, June 15, 2009 - 12:26 PM UTC
Can it be something that has been languishing on the back burner for a while?
'Cuz I have one...
'Cuz I have one...
Sudzonic
Posted: Tuesday, June 16, 2009 - 05:43 AM UTC
'Cuz I have one...
I don't see why not?
Great work so far every one keep it up.
Nito74
Posted: Wednesday, June 17, 2009 - 12:44 AM UTC
Some more progress on the E-100.
Some troubles fixing the 12,8 cm Metal gun barrel on the mantlet but with some superglue I hope it's fixed.
Will work on the infra-red system and finish the weathering on the wheels
gcdavidson
Posted: Wednesday, June 17, 2009 - 09:52 AM UTC
'Cuz I have one...
Someone beat you to it!
VenomOrca
KitMaker: 209 posts
Armorama: 169 posts
Posted: Wednesday, June 17, 2009 - 10:24 AM UTC
Heh...Someone took a pic of my vehicle at an R.I. Bong club meet.
The vehicle is an Abrams modified to carry energy weapons.
I call it an M1A4 EWV (Energy Weapon Variant)
Sudzonic
Posted: Thursday, June 18, 2009 - 03:48 AM UTC
Well thought i better let you in on what i have planed for the campaign first of all i will be doing a centurion (thanks to Paul for the inspiration) based round one used by the royal orkadies armoured corps circa the early 90's (more to follow on that..)
I have two others in the planing stage one based on a armoured orkadies Humvee ether in Afghanistan or possibly in north Korea as a peace keeping vehicle in the not to distant future.
Now for the bigie i will give you a few hints as to what i am thinking........
Take one of these
Add one of these
And finally add one of these
Take one of these
Add one of these
Nylonathatep
KitMaker: 58 posts
Armorama: 56 posts
Posted: Friday, June 19, 2009 - 08:15 PM UTC
Sudzonic
Posted: Saturday, June 20, 2009 - 07:30 AM UTC
Hay all i have made a start on my orkadies cent i am useing a few bit from an aef conversion set.
ppawlak1
Posted: Saturday, June 20, 2009 - 12:21 PM UTC
Good work Scotty !
What base kit are you using ?
I've started kit bashing my turret. I have the Tamiya Cheiftain Mk V Commanders Cuppola fitted (lots of chopping, filing, and puttying there), and the Large Chieftain IR spot light fitted to the LH side of the Turret (a fair bit of Styrene and Putty involved there also).
The next step is to fix the texture and gaps with some Mr Surfacer (when it arrives), and add the other bits and pieces to the turret (eg: Commanders IR light, Tasca 50 cal, smoke grenades, and the other bits and pieces).
The Chieftain Gun fits Ok - but I'll try the Chally 2 one when the post man delivers it !.
I won't be using reactive armor on mine - maybe a few extra tracks, that's it.
Posted: Saturday, June 20, 2009 - 12:34 PM UTC
Hay all and we are go for the what if campaign can't wait to see what you lot come up with.![]()
Scott, I just primed an E100 yesterday, though the kit has been built awhile back. Can it still qualify? Thanks. Tat
