Great looking figures, Alan!
Tell us how you did the Indian figures and post some close ups if possible...
Because you took a headstart, you need to do 2 more figures AFTER 01-01-2010...
That's your punishment for being a naughty and impatient boy!
Hi Ron,
Cruel, very cruel
. I have some time this week and as things will be very busy when I get back to work thought I'd make use of it.
Well having washed the figures I primed them with Tamiya XF 52 flat earth, not for any particular reason other than I have several pots of that colour left over from when I switched to Vallejo English Uniform. The Tamiya paint holds well as a base coat and for the Greatcoats I used Vallejo 70921 English Uniform.
Trousers were painted with Vallejo Buiff 70976 and the webbing with Tamiya Buff XF 57.
For the faces I used life colour paints and starting off with a flat base gradually added many layres of slightly darkening colout until I got what I though was a reasonable approximation of the right facial colour.
The greatcoats were given some depth/contrast by adding light touches of some Vallejo burn't umber and the bottomm of the coats treated with some Mig pigments.
The webbing less the bandolier was treated with some Mig filters.
There are a few bumps/dips in the arms that need sorted out, I had to fatten them up a bit with milliput from Battle Dress to Greatcoat thickness and I'm not much of a sculpter so they could be better.
Still some more work to do on them and I will try and get some better pictures when the light improved but it is a very dull/wet day to day so not much good for photography.
Al
