Not the easiest to come up with innit? it's sort of like making your bath at an okay temperature while having 4 taps.
-the Albatross tap
-the Alexander tap
-the Anatoli tap
-the boat tap.
Now the boat is easy to position as I already cut it according to its final position.
But now something about it is VERY important: 12 mm of it will be below the water level, so that i can get enough transparency with the body etc.
As there is some slope about the way the boat is on the water that will mean there will be less of the boat visible.so more sea and this will change a lot the VERTICAL balance.
Now is Alexander too much to the right? maybe not if there is some sea wave occupying some space on the right.
Then, is Anatoli not enough to the left? this is actually the one that worries me the most. And then the Albatross must not be outside the action. Actually he must be like an angle of death above the 2 corpses. So i absolutely must placing him at the right position -*between* them on a top position?
And then we are speaking of right or left, but that's according to the fact we consider the diorama from a "front" point of view, what about viewed from each side? and in between each side? It's SO complex to do the balance of a diorama because it must work either vertically or horizontally and basically from each and every angle you can think of.
So the final position will really decide by the end of the work but thanks for all suggestions Pat.
Thanks Primož -can't wait to see what you will do with your ice on the stream
Looks like my compressor troubles are over. Here is the boat with some basic airbrush work.
I will try to work on light. The front of the boat will be white slowly fading to a more yellowey colour. Most of the rear areas will be of a mix of grey and purple.
You can't seem much the yellowey colour with my terrible camera. believe they are there.
The reason why I didn't glued ion place neither the Romanov eagle and the letters is because they've been airbrushed in gold elsewhere.
